Re: SAPRO Image Octagon SF8008 a SF8008mini
Moderátor: zilizila
- Blackfire
Tak napriek tomu, že som nič nemenil, youtube prestal fungovať, odinštaloval som, stiahol som 893, vyhľadávanie ide, ale nespustí, ostane čierna obrazovka. A aj mkv filmy akonáhle spustím vyhodí modrú obrazovku. Mam warder img.
AZBOX Premium, LNB Inverto Black ULtra, SG2100, Gital, WI-FI, Interny HDD wd 2.5" scorpio blue 500gb, plazma Samsung PS50, pes
Ahoj, poradí mi někdo prosím, jak přidat tuto kameru mezi ostatní CZ/SK webcam v image ? Přes dreamboxedit umím přidat nebo editovat, ale nepřehrává video...
Adresa kamery https://www.ipcamlive.com/5ebb8fa6c018e
EnoSat
- Dostal poděkování: 20 poděkování
EnoSat
dnes
vcera
link sa dynamicky meni (aby sa nedal jednoducho kopirovat/pouzivat)
https://s2.ipcamlive.com/streams/02mgcvhxj5l0cxeza/stream.m3u8
https://s2.ipcamlive.com/streams/02bkv4nqrz2waditu/stream.m3u8
Danko79
SAPRO Image 3.1 for Octagon SF8008 + SF8008mini
New
- Update Enigma2
- Update pre-installed plugins
Use distro: OpenATV 6.4
Enigma version: 10-02-2022
Kernel version: 4.4.35
DVB version: 05-01-2022
GStreamer version: 1.18.5
Python version: 2.7.18
Resolution mode: 1080p
Default language: Czech
Default skin: HD Glass 17
OSCam: r11704 - port 8888 - 0624
Oscam: local - port 8888 - M7 - read local cards only (no sharing - neither in nor out)
Pre-installed plugins:
- AJPanel - 4.0.0
- ArchivCZSK - 1.3.8
- Chocholousek picon - 5.0.220121
- CoolTVGuide - 7.7.0
- CSFD - 16.0
- CSFDLite - 1.9
- DreamSat Panel - 1.3
- Filmon - 1.6
- HBBTV - 2.0-r0-48
- MediaPortal - 2020070101
- Multi-Stalker - 1.3
- Netflix - 4.0
- Streamlink - 3.3
- SubsSupport - 3.3.0
- webradioFS - 20.06
- XStreamity - 3.56
- Youtube - git994
- YoutubeTV - 1.0 - the maximum video playback resolution is 1080p !
- Kodi 18.9
- under Kodi Skylink Live TV - 1.7.3
- under Kodi Netflix - 1.12.8
- under Kodi Stream Cinema - 1.3.28
- under Kodi Stream Cinema Community - 2.5.31
Pre-installed skins:
- HD Glass 17 - 7.10
- Metrix-ATV - 3.0-git2001
Login :
Password: sapro
Installation:
- copy the file to a USB stick and install via Online image change.
Download:
You can download version for SF8008 from https://mega.nz/file/xscxAQYK#ujR6nbOiN ... myRd36u1uE
You can download version for SF8008mini from https://mega.nz/file/YlkGHSbI#tbSV8ggmZ ... jiZBWPsQr0
New
- Update Enigma2
- AJPanel - 4.0.0
- CSFD - 16.0
- CSFDLite - 1.9
- Filmon - 1.6
- HBBTV - 2.0-r0-48
- Netflix - 4.0
- Streamlink - 3.3
- XStreamity - 3.56
- Youtube - git994
- Kodi 18.9
Login :
Password: sapro
Installation:
Download:
Danko79
SAPRO Image 3.4d-py3 for Octagon SF8008 + SF8008mini
New
- Updated Enigma2
- Updated pre-installed plugins
Use distro: OpenATV 7.0
Enigma version: 19-04-2022
GStreamer version: 1.18.6
Python version: 3.9.7
- AJPanel - 5.0.0
- ArchivCZSK - 1.4.6
- CSFDLite - 2.0
- EPGImport - 1.0
- HasBahCa - 1.4
- HBBTV - 2.0-r0-64
- Multi-Stalker - 1.3 ( plugin have save problem when changing configuration ! )
- Netflix - 4.0
- Streamlink - 3.2
- SubsSupport - 3.3.1
- XStreamity - 3.64
- Youtube - git1019
- Kodi 19.4
- under Kodi Netflix - 1.12.9
- under Kodi Stream Cinema - 2.2.01
- under Kodi Stream Cinema Community - 2.5.40
- HD Glass 17 - 7.12
- Metrix-ATV - 3.0-git2316
Pre-installed cams:
Login :
Password: sapro
Installation:
- Copy the file to a USB stick and install via Online image change.
Download:
You can download version for SF8008 from https://mega.nz/file/o11BxITY#S6hOGCVL9 ... OgIqhJd9xQ
You can download version for SF8008mini from https://mega.nz/file/hlEwxYrK#7IpQSei3g ... jhJHQXsiF8
New
- Updated Enigma2
- AJPanel - 5.0.0
- CSFDLite - 2.0
- EPGImport - 1.0
- HasBahCa - 1.4
- HBBTV - 2.0-r0-64
- Netflix - 4.0
- Streamlink - 3.2
- XStreamity - 3.64
- Youtube - git1019
- Kodi 19.4
Pre-installed cams:
Login :
Password: sapro
Installation:
Download:
Danko79
SAPRO Image 3.4-py2 for Octagon SF8008 + SF8008mini
New
- Updated Enigma2
- Updated plugin ArchivCZSK ( upgrade API 1.3 to 1.4 as well as all modules because of support Python3 )
Enigma version: 14-04-2022
- AJPanel - 4.3.0
- ArchivCZSK - 1.4.5
- CSFDLite - 2.0
- EPGImport - 1.0
- HasBahCa - 1.3
- HBBTV - 2.0-r0-50
- Netflix - 4.0
- Streamlink - 3.3
- XStreamity - 3.64
- Youtube - git1017
- Kodi 18.9
- Metrix-ATV - 3.0-git2006
Pre-installed cams:
Login :
Password: sapro
Installation:
Download:
You can download version for SF8008 from https://mega.nz/file/VpFjGCyT#o--tSqZvm ... vs1hWosGqM
You can download version for SF8008mini from https://mega.nz/file/U4N33QRK#Yg36qrtmX ... MUKZrWIn9c
New
- Updated Enigma2
- AJPanel - 4.3.0
- CSFDLite - 2.0
- EPGImport - 1.0
- HasBahCa - 1.3
- HBBTV - 2.0-r0-50
- Netflix - 4.0
- Streamlink - 3.3
- XStreamity - 3.64
- Youtube - git1017
- Kodi 18.9
Pre-installed cams:
Login :
Password: sapro
Installation:
Download:
Ahojte. Rád by som si stiahol tento image kedze mi zazracne prestalo prehravat filmy na OPENATV 6.4 , no link nieje dostupný. Môžem požiadať o obnovu linku? Ďakujem
Warder
- Dostal poděkování: 71 poděkování
A aku verziu by si si prial ?
Mozes si vybrat z bohateho aktualneho denneho menu :
SAPRO-basic - zaklad postaveny na OpenATV 6.4
SAPRO-3.5-py2 - postaveny na OpenATV 6.4 a Python2
SAPRO-3.5-py3 - postaveny na OpenATV 7.0 a Python3.9x
SAPRO-3.5-py31 - postaveny na OpenATV 7.1 a Python3.10.x
Nosce te ipsum.
Ďakujme za reakciu. mám 4k verziu a netuším aký je v ponúkaných verziach rozdiel. stiahol som si z ineho fora verziu pre SF8008. Je funkčná no neviem pridat CCcam. Viete mi s tým pomoct?
Danko79
SAPRO Image 3.6-py2 for Octagon SF8008 + SF8008mini
New
- Updated Enigma2
- Added chromium 2 and its modules Netflix , YoutubeTV, Dazn, Disney + ......
Enigma version: 06-06-2022
- AJPanel - 5.3.0
- ArchivCZSK - 1.4.9
- Chromium 2 - 1.0
- CSFDLite - 2.0
- EPGImport - 1.0
- HasBahCa - 1.5
- HBBTV - 2.0-r0-50
- Streamlink - 3.3
- XStreamity - 3.67
- Youtube - git1019
- webradioFS - 20.08
- Kodi 18.9
- under Kodi Netflix - 1.12.10
- under Kodi Stream Cinema Community - 2.6.67
- HD Glass 17 - 8.01
- Metrix-ATV - 3.0-git2007
Pre-installed cams:
OSCam: r11711 - port 8888 - 0624
Login :
Password: sapro
Installation:
Download:
You can download version for SF8008 from https://mega.nz/file/0g1wFYKD#Cruse1yI1 ... 7Ji-XdiM6s
You can download version for SF8008mini from https://mega.nz/file/Yt1mACrQ#6KysHJWVm ... XXN4K0ng1Y
New
- Updated Enigma2
- AJPanel - 5.3.0
- Chromium 2 - 1.0
- CSFDLite - 2.0
- EPGImport - 1.0
- HasBahCa - 1.5
- HBBTV - 2.0-r0-50
- Streamlink - 3.3
- XStreamity - 3.67
- Youtube - git1019
- Kodi 18.9
Pre-installed cams:
Login :
Password: sapro
Installation:
Download:
Danko79
SAPRO Image 3.7-py2 for Octagon SF8008 + SF8008mini
New
- Updated Enigma2
- Updated settings
Enigma version: 04-07-2022
- AJPanel - 5.5.0
- ArchivCZSK - 1.5.0
- Chocholousek picon - 5.0.220610
- Chromium 2 - 1.0
- CSFDLite - 2.0
- EPGImport - 1.0
- HasBahCa - 1.5
- HBBTV - 2.0-r0-50
- Streamlink - 3.3
- SubsSupport - 3.4.0
- XStreamity - 3.69
- Youtube - git1019
- webradioFS - 21.03
- Kodi 18.9
- under Kodi Netflix - 1.12.12
Pre-installed cams:
Login :
Password: sapro
Installation:
Download:
You can download version for SF8008 from https://mega.nz/file/s5UFQZBR#vhz1dkI7M ... jyRlrg3uRg
You can download version for SF8008mini from https://mega.nz/file/ZldiAbAK#7ixqOPMbm ... lV1hozPlDs
New
- Updated Enigma2
- Updated settings
- AJPanel - 5.5.0
- Chromium 2 - 1.0
- CSFDLite - 2.0
- EPGImport - 1.0
- HasBahCa - 1.5
- HBBTV - 2.0-r0-50
- Streamlink - 3.3
- XStreamity - 3.69
- Youtube - git1019
- Kodi 18.9
Pre-installed cams:
Login :
Password: sapro
Installation:
Download:
Warder
SAPRO Image 3.8-py2 for Octagon SF8008 + SF8008mini
Enigma version: 05-08-2022
New
- Updated Enigma2
- Updated settings - added channels Canal Sport+ 1 and 2
Download:
You can download version for SF8008 from https://mega.nz/file/5xElDZQb#1QqFoKUK5 ... gntlmLTZrQ
You can download version for SF8008mini from https://mega.nz/file/N4VU2QQa#nMfCJfMJP ... CIjfNX1oQg
SAPRO Image 3.8-py3 for Octagon SF8008 + SF8008mini
Enigma version: 04-08-2022
New
- Updated Enigma2
Download:
You can download version for SF8008 from https://mega.nz/file/B18HUAhL#NwO-OOHFh ... BGU2eHKKPs
You can download version for SF8008mini from https://mega.nz/file/NlFCiQJY#C7SQjQNdm ... IA7Q9TVSvM
SAPRO Image 3.8-py31 for Octagon SF8008 + SF8008mini
Use distro: OpenATV 7.1
Python version: 3.10.4
New
- Updated Enigma2
Download:
You can download version for SF8008 from https://mega.nz/file/g910zSBb#KOzfhpdV6 ... NEwMko2noo
You can download version for SF8008mini from https://mega.nz/file/optD1K4D#W6PUAGSTp ... 1B4Abj2TgE
New
- Updated Enigma2
Download:
New
- Updated Enigma2
Download:
New
- Updated Enigma2
Download:
Nosce te ipsum.
