Oscam L2B
pele1
EnoSat
Re: Oscam L2B
spusti si ten oscam v konzole a mal by si vidiet co mu chyba
chcaldorin
Re: Oscam L2B
Mam image OpenATV
prepisal som binarku,ale nic sa neudialo
tak som postupoval takto:
no a dako sa to rozbehlo.
Vytvoril sa tymito prikazmi ten symlink?
Odvtedy to ide aj po reboote akurat neviem ci som tomu pomohol
Testujem to pre kamaratov box aby mu siel aj RTVS Sport a JOJ Sport na Skylink karte.
Quad PIP ale nejde-iba dva kanaly zo styroch,obraz v obraze ano..taky moj postreh
root@vuultimo4k:~# oscam
-bash: /usr/bin/oscam: No such file or directory
root@vuultimo4k:~# -sh
-bash: -sh: command not found
root@vuultimo4k:~# ln -s /lib/ld-*.so /lib/ld-linux.so.3
BusyBox v1.29.2 (2019-01-19 01:04:48 UTC) multi-call binary.
Usage: ln [OPTIONS] TARGET... LINK|DIR
Create a link LINK or DIR/TARGET to the specified TARGET(s)
-s Make symlinks instead of hardlinks
-f Remove existing destinations
-n Don't dereference symlinks - treat like normal file
-b Make a backup of the target (if exists) before link operation
-S suf Use suffix instead of ~ when making backup files
-T 2nd arg must be a DIR
-v Verbose
root@vuultimo4k:~# /lib/ld-*.so
Usage: ld.so [OPTION]... EXECUTABLE-FILE [ARGS-FOR-PROGRAM...]
You have invoked `ld.so', the helper program for shared library executables.
This program usually lives in the file `/lib/ld.so', and special directives
in executable files using ELF shared libraries tell the system's program
loader to load the helper program from this file. This helper program loads
the shared libraries needed by the program executable, prepares the program
to run, and runs it. You may invoke this helper program directly from the
command line to load and run an ELF executable file; this is like executing
that file itself, but always uses this helper program from the file you
specified, instead of the helper program file specified in the executable
file you run. This is mostly of use for maintainers to test new versions
of this helper program; chances are you did not intend to run this program.
--list list all dependencies and how they are resolved
--verify verify that given object really is a dynamically linked
object we can handle
--inhibit-cache Do not use /etc/ld.so.cache
--library-path PATH use given PATH instead of content of the environment
variable LD_LIBRARY_PATH
--inhibit-rpath LIST ignore RUNPATH and RPATH information in object names
in LIST
--audit LIST use objects named in LIST as auditors
root@vuultimo4k:~# /lib/ld-linux.so.3
in LIST
root@vuultimo4k:~#
The system is going down for reboot NOW!console) (Fri Jan 21 12:36:46 2022):Vytvoril sa tymito prikazmi ten symlink?
T90-45E,42E,39E,36E,28,2E,26E,23.5E,19,2E,16E,13E,10/9E,7E,4,8E,0,8W,4W,8W
VU+Ultimo4K na pozeranie
VU+Uno4K Oscam Server
lobo54
pazitush
Re: Oscam L2B
I use Dreambox 8000 with NewEnigma2 image.
Oscam version 11704.
Have a Skylink prepaid Icecrypt card (0D96 & 0624).
Clears well all my channels except the Hungarian package.
If I insert the card into original Icecrypt Cam, all is Ok.
What's wrong???
What's wrong???
Re: Oscam L2B
Hungarian package is not working with ICE cards, You need to use M7 card (pure Irdeto) and patched oscam for this card.
pazitush
Warder
Re: Oscam L2B
Do you think Oscam is like ADIDAS ? The more strips (Higher version of OSCAM) so the more ADIDAS !
edob
Re: Oscam L2B
Dobrý deň všetkým, mám VU+SOLO SE V2 a nainštalový soft VTi od Ellano aby mi fungovala Irdeto karta Skylink v internej čítačke. Všetko je OK až na program RTVS šport, ktorý mi nedekóduje. Údajne by to mal vyriešiť oscam L2B, ale neviem ako ho nainštalovať aby mi ostal funkčný soft od Ellano pre čítanie karty. Naviac v tom oscame sú po rozbalení dva rôzne súbory a neviem ktorý treba použiť. Poradí niekto ako na to?
9000peter
Re: Oscam L2B
Ten oscam kde ti beží karta stačí nahradiť ( premenovať a prepísať) binarkou oscamu ktorá podporuje l2b.
Warder
Re: Oscam L2B
Pred tym si vsak ten Oscam musi najprv zastavit, inak premenuje a prepise leda tak TRT.
9000peter
Warder
Re: Oscam L2B
Jaaaj Pater, ved sam dobre vies ako to v skutocnosti je ked ti potom vypisuje, ze si mu zle poradil a ze jemu to nejde.
edob
Re: Oscam L2B
Dobrý deň všetkým. Po pripojení cez Telnet dostanem túto obrazovku https://ulozto.cz/tamhle/ZWIDCSygmJRu/n ... MkBQtkLt==. Poradí niekto ako pokračovať pre nahranie oscam-u?edob píše: ↑12 úno 2022, 15:08 Dobrý deň všetkým, mám VU+SOLO SE V2 a nainštalový soft VTi od Ellano aby mi fungovala Irdeto karta Skylink v internej čítačke. Všetko je OK až na program RTVS šport, ktorý mi nedekóduje. Údajne by to mal vyriešiť oscam L2B, ale neviem ako ho nainštalovať aby mi ostal funkčný soft od Ellano pre čítanie karty. Naviac v tom oscame sú po rozbalení dva rôzne súbory a neviem ktorý treba použiť. Poradí niekto ako na to?
Warder
Re: Oscam L2B
V boxe si zastavis Oscam cez VTI-Centrum, novu binarku oscamu s podporou L2B nakopirujes (povodny subor co tam mas teraz prepises tymto novym) do /usr/bin/ a znovu Oscam cez to Centrum CAM spustis.
Ze namas zac.
Ze namas zac.
