Zkus druhou flešku.xino píše:Caute
Skusal som nahodit enigmu podla postupu do granteca
no zastavil ma azup ked dosielk patch.cramfs Created
naskocilo okno no a tam File not found - Unable To Complete Request
No a ked som klikol na OK tak tam bolo ze vypnut zapnut azbox a skusit znova
skusil som a k ničomu som sa nedostal stale to iste
Na satpimps som nasiel nejaky navod ako tam dostat of firmware ten som zatial neskusal
a este tam bolo ze azup nemoze byt nainstalovany v programfiles no ale toto mi nepomohlo
Viete mi poradit ako tam dostat of firmware
lebo cez azup tam nedam ani e2 ani of firmware
Vdaka za pomoc.
E2 na azbox HD
formis
Re: E2 na azbox HD
Re: E2 na azbox HD
Dobra sprava zo satpimps:
"Hello,
Premium+ drivers also fixed and today You can expect new version of Enigma 2 for Elite/Premium/Premium+ ."
"Hello,
- Juraš
Re: E2 na azbox HD
Posledí info:
There is some fixes, like Mute/Unmute and Volume control, for p+ users FAN control enabled and activated, plus few more fixes.
I told very clear that I work on p+ tuner drivers STV090X and STV6110X and it take me all the time for that, now when I have this working and p+ users can join us in this E2 testing for Azbox receivers, I will now go back and start fixing problems.
Vu+ Uno 4k SE DVB-S2X, AZBox HD Premium + ,,tuning" / Open RSI 3.0, WD 1 TB WD10EVDS Green Power. WD 500GB for AV in NAS Zyxel NSA310 / Ferguson Ariva 203 / TV LG 60PZ250, Panasonic TH-42PX80EA / E85 multifocus 1W+13E+19,2E+23,5+28,2 Skylink
xino
Re: E2 na azbox HD
vymena flasky nepomohla
skusal som ten azup spustit jak na windows 7 aj na XP a nič stále ten isty problem a box nemožem "oživiť"
neberie ani E2 ain oficialny firmware
tak co s tym?
nieco okolo tohto problemu sa riesilo tu
Vedel by mi to niekto zrozumitelnejsie vysvetlit?
mam AZbox premium v nom HDD a na internet respektive siet je pripojeny kablom cez router
Tak prosim o nejake rady
Vdaka
tak co s tym?
http://www.satpimps.com/showthread.php?p=761987mam AZbox premium v nom HDD a na internet respektive siet je pripojeny kablom cez router
Vdaka
AZBOX Premium HD, Openrsi 3.0 (30.6.2013), Kernel 3.3.1, Seagate Pipeline HD 500 GB,Internal,5900 RPM,3.5" (ST3500321CS), Irdeto Cryptoworks Eurocam modul
Re: E2 na azbox HD
flashku treba zasunut do zadneho usb portu...
Re: E2 na azbox HD
Ja som Premium upgradoval s USB v prednom - takže to je asi jedno.
Re: E2 na azbox HD
Mne v prednom vypisovalo v AZup-e, ze mam nespravny fw a nejaku chybu. Ale to bolo asi v predoslej verzii, teraz uz to ide aj mne z predneho. Ale pokial sa chce vratit na offico fw, tak urcite treba pouzit zadny usb port.
Re: E2 na azbox HD
Asi tiež nie. Vrátil som sa z tiež predného :)
Re: E2 na azbox HD
Zaujimave, ale vsak nech skusi zadny, mozno mu to prejde...
005jon
- Dostal poděkování: 210 poděkování
Re: E2 na azbox HD
Tiež mi to vyhodilo chybu pri spustený AZup ale stačilo Azbox z reštartovať počkať na IP a už to išlo
xino
Re: E2 na azbox HD
škoda
no ale toto čo tu spominate som skusal aj z predneho aj zo zadneho usb a nič stale to iste
no a to stym vypnutim/zapnutim azboxu pise aj azup (off/on and try again) ale nič stale dookola to iste
no a čo sa tyka ip je stale ta ista
existuje este nejaky iny sposob jak tam natlaciť aspoň ten oficialny firmware ked mi uz ta E2 nejde vdaka
lebo teraz je box doslova nefunkcny a nemat este iny sat prijimac tak som s tv skoncil
xino
Re: E2 na azbox HD
Tak čo nikto nevie nič poradiť
Či ten firmware nejde dostať cez FTP alebo dajak inak
Neviem pozerali ste na satpimps tam bol nejaky navod s Telnetom a niečo s ftp ale neviem nerozumiem tomu ako tam ten FW dostať viete poradiť prosim chcel by som to rozchodiť
Vďaka
Vďaka
Re: E2 na azbox HD
Návod tu samozrejme je, nečakaj však že Ťa niekto bude viesť za ručičku.
Tak či tak by si bol sklamaný. Ak bude E2 pre AZ HD tak dobrá že bude mať význam používať ju bez nejakých zbytočných komplikácií tak sa to dozvieš.
theruck
Re: E2 na azbox HD
tak as me dvaja. mam ten isty problem
xino
Re: E2 na azbox HD
Dobre dempsey chapem ťa ale prosim ťa nemožeš tu dať aspoň nejaky link kde by som to tu na fore mal najsť
prešiel som tie rady čo tu su ale nič som nenašiel
no a ked už ide o tu Enigmu nejde mi o to ju dostať do prijimača kľudne aj počkam len aby som tam dostal aspoň ten oficialny firmware
tak je toľko tu dať nejaky stručny navod čo a ako zrobiť aby som prijimač rozchodil?
Vdaka
Vdaka
