Oscam Skylin,Cslink + share problem :)
Napsal: 17 srp 2012, 08:26
Zdravim,
mam takovy problem, snad mi neco dokaze poradit. Mam oscam sat, s kartou skylink + share server.Oscam dal funguje jako server pro dalsi sat po dome.
Problem je nasledujici:
Nejdou mi na tomto receiveru s oscam server programy od cslinku(skylink jsou ok) Na klientech co jsou pripojeni na tento prijimac s oscamem, vse funguje jak cslink tak skylink(pouzivaji mgcamd).
Pripadne mi, jako bu dvbapi proste porad mel jinou druzici podle CAID....
pod z Oscamu:
dvbapi: stoping demux for pmt file /tmp/pmt1_1.tmp
2012/08/16 14:57:45 6211A0 c dvbapi: found pmt file /tmp/pmt1_1.tmp
2012/08/16 14:57:45 6211A0 c dvbapi: [ADD PID 0] CAID: 0D0F ECM_PID: 06BC PROVID: 000000
2012/08/16 14:57:45 6211A0 c dvbapi: [ADD PID 1] CAID: 0666 ECM_PID: 06D0 PROVID: 000000
2012/08/16 14:57:45 6211A0 c dvbapi: [ADD PID 2] CAID: 1817 ECM_PID: 0720 PROVID: 00006A
2012/08/16 14:57:45 6211A0 c dvbapi: [ADD PID 3] CAID: 0100 ECM_PID: 0720 PROVID: 00006A
2012/08/16 14:57:45 6211A0 c dvbapi: new program number: 5158 (AXN Sci Fi [CW2]) [pmt_list_management 3]
2012/08/16 14:57:45 6211A0 c dvbapi: try pids again #1
2012/08/16 14:57:45 6211A0 c dvbapi: overtake: clear pid: 0
2012/08/16 14:57:45 6211A0 c dummy (1817&00006A/0720/5158/64:E26A): rejected caid (0 ms) (0 of 0) (invalid caid 1817)
2012/08/16 14:57:45 6211A0 c dvbapi: try pids again #2
2012/08/16 14:57:45 6211A0 c dummy (1817&00006A/0720/5158/64:E26A): rejected caid (1 ms) (0 of 0) (invalid caid 1817)
2012/08/16 14:57:45 6211A0 c dvbapi: try pids again #3
2012/08/16 14:57:45 6211A0 c dvbapi: can't decode channel
[oscam.dvbapi]
S: PTI pmt1_1.tmp
S: PTI pmt1_2.tmp
S: PTI pmt1_3.tmp
S: PTI pmt1_4.tmp
P: 0D0F
P: 0D96
# P: 0D02
P: 0D03
I: 1870
I: 0100
I: 0960
I: 0653
I: 0D97
I: 0624
I: 0666
[oscam.conf]
global]
disablelog = 0
waitforcards = 1
preferlocalcards = 1
nice = -1
saveinithistory = 0
clienttimeout = 12000
lb_mode = 1
lb_save = 100
lb_nfb_readers = 3
logfile = /var/log/oscam.log
usrfile = /var/log/oscamuser.log
[monitor]
hideclient_to = 15
appendchaninfo = 0
[newcamd]
port = xxxx@0D96:000004;xxxxx{0102030405060708091011121314}@0D0F:000004,000008,400000
allowed = povolena IP
mgclient = 1
[dvbapi]
enabled = 1
au = 1
boxtype = none
user = dummy
pmt_mode = 0
[webif]
httpport = 8888
httpuser = root
httppwd = root
httprefresh = 60
httpallowed = povolena IP
[oscam.user]
account]
user = dummy
pwd =
group = 1
au = 1
Caid = 0D96,0D0F
Ident = 0D96:000000,000004,000008;0D0F:000000,000004,000008
[account]
user = user
pwd = pass
group = 1
au = 1
keepalive = 1
Caid = 0D96,0D0F
[account]
user = user2
pwd = pass2
group = 1
au = 1
keepalive = 1
Caid = 0D96,0D0F
[oscam.server]
[reader]
label = skylink
protocol = stapi
device = SC0
caid = 0D96
detect = cd
mhz = 357
cardmhz = 357
group = 1
emmcache = 1,3,2
[reader]
Label = "cslink"
Protocol = newcamd
Key = 0102030405060708091011121314
Device = ip,port
Account = user,pass
Fallback = 0
Group = 1
Caid = 0D0F
Ident = 000000,000004
[reader]
Label = "skylink ice"
Protocol = newcamd
Device = ip,port
Account = user,pass
Fallback = 0
Group = 1
Caid = 0D96
Ident = 000004,000008
v oscam.srvid a oscam.services jsem zkousel jak mit ten cslink se vsim jak ma byt tak i nechat v obojim prazdne.
Mam OSCAM 1.20-unstable_svn build #6608
Jsem fakt v koncim, nechce se mi pouzivat jeste krom oscamu mgcamd, abych to pripojil....
Predem moc dekuji za postrehy a rady. S Oscamem se zname jen chvili, takze budu rad i za pripadne zmeny v cfg. Nejak jsem to nastavil a jelo to, krom teda ted toho cslinku.
David
pod z Oscamu:
[oscam.dvbapi]
S: PTI pmt1_1.tmp
S: PTI pmt1_2.tmp
S: PTI pmt1_3.tmp
S: PTI pmt1_4.tmp
P: 0D0F
P: 0D96
# P: 0D02
P: 0D03
I: 1870
I: 0100
I: 0960
I: 0653
I: 0D97
I: 0624
I: 0666
[oscam.conf]
global]
disablelog = 0
waitforcards = 1
nice = -1
saveinithistory = 0
lb_mode = 1
lb_save = 100
lb_nfb_readers = 3
[monitor]
hideclient_to = 15
appendchaninfo = 0
[newcamd]
mgclient = 1
[dvbapi]
enabled = 1
au = 1
boxtype = none
user = dummy
pmt_mode = 0
[webif]
httpport = 8888
httpuser = root
httppwd = root
httprefresh = 60
[oscam.user]
account]
user = dummy
pwd =
group = 1
au = 1
Caid = 0D96,0D0F
[account]
user = user
pwd = pass
group = 1
au = 1
keepalive = 1
Caid = 0D96,0D0F
[account]
user = user2
pwd = pass2
group = 1
au = 1
keepalive = 1
Caid = 0D96,0D0F
[oscam.server]
[reader]
label = skylink
protocol = stapi
device = SC0
caid = 0D96
detect = cd
mhz = 357
cardmhz = 357
group = 1
emmcache = 1,3,2
[reader]
Label = "cslink"
Protocol = newcamd
Device = ip,port
Account = user,pass
Fallback = 0
Group = 1
Caid = 0D0F
[reader]
Protocol = newcamd
Device = ip,port
Account = user,pass
Fallback = 0
Group = 1
Caid = 0D96
David
