skins mamba65
Napsal: 14 čer 2016, 21:18
od vusolo2
~ MambasHD_V9_by_mamba65" ~
Fast Full HD 1920 x 1080
For >OpenATV and Vix < Image
<**** Infopanel ****>
- Picon Reference 320x220
<**** Second Infopanel ****>
- Sid,Audio Info,VPid,,,etc
- Infos,,etc
- Channel List / Epg with Scrolll Text
- Picon Info Channel List; Audio/Video Bitrate,Rating,Genre,,etc,
enigma2-plugin-skins-mambas-hd-v9_1.0_all.ipk
Re: skins mamba65
Napsal: 16 črc 2016, 09:42
od vusolo2
MambasHD_V10
~ MambasHD_V10_by_mamba65" ~
Fast Full HD 1920 x 1080 OpenMips Skin
For > OpenATV < Image
~ Infopanel ~
- Picon Reference 420x220
~ How to get your city weather ~
1-Open Weather Plugin from Plugins brwoser
2-Press Memu from Keyboard
3-Press Green Button (Add)
4-Write you city name in (City) option
5-Click yellow buttons (Search Code)
6-Now select your city and press green button (ok)
7-Press green button (ok) again
8-Finish Exit from plugin bu pressing Exit button
With woman wallpaper​
P.S.for member LUCEK SAT ,DONT COPY SCREENS AND SAY IS YOUR IDEA!
enigma2-plugin-skins-mambas-hd-v10_2.0_all.rar
Without woman wallpaper​
enigma2-plugin-skins-mambas-hd-v10_2.0_all.zip
Re: skins mamba65
Napsal: 18 črc 2016, 15:42
od vusolo2
~ UPDATE ~
Without woman wallpaper and NO Wheater Plugin!
~ Infopanel ~
Re: skins mamba65
Napsal: 18 srp 2016, 20:36
od vusolo2
~ Mambas-HD_Red_Shadow_by_mamba65 ~
Fast Full HD 1920 x 1080 Skin
*FOR > OpenATV < Image*
*Screens say everything what is all in Skin...*
*For crash or improvements please a feedback*
* Weather Settings *
*1 Oppen you Weather Plugin plugins browser
*2 Press menu from the keyboard
*3 green button (Add)
* 4 write the name of the city in option (City)
*5 Click on the yellow button (search code)
*6 Now select your city and press green button (ok)
*7 Press the green button (OK) again
*8-Done Quit plugin bu Press exit button
enigma2-plugin-skins-mambas-hd-red-shadow_2.V1_all.ipk
Re: skins mamba65
Napsal: 19 srp 2016, 14:39
od vusolo2
*FOR > OpenPLI < Image*
see all screens up like skin OpenATV ... only is adapted for OpenPLi
Re: skins mamba65
Napsal: 04 zář 2016, 21:08
od vusolo2
FOR OPENPLI
UPDATE
-Instal Skin-
opkg install --force-overwrite /tmp/*.ipk
UPDATE
-Movieplayer
-ChannelList
-InfoPanel
-ProviderPicons
enigma2-plugin-skins-mambas-hd-red-shadow_2.V2_all.rar
Re: skins mamba65
Napsal: 12 lis 2016, 09:21
od vusolo2
~Goliath_RV2_1080p_HD_by_mamba65 ~
*FOR > Open Black Hole 0.6 skins < Image*
*Screens say everything what is all in Skin ...New Menus and new look...*
*4 write the name of the city in option (City)
You are not allowed to Mod and publish my skin without my permission!!
vuplus-images.co.ukenigma2-plugin-skins-goliath-rv2-1080p-hd-by-mamba65_RV2_all.rar
Re: skins mamba65
Napsal: 14 lis 2016, 19:13
od vusolo2
~ Goliath_RV2_1080p_HD_by_mamba65 ~
*FOR > OpenATV and Open Black Hole 0.6 skins < Image*
P.S. For OpenATV, set EPG line to 12!
Für OpenATV EPG zeile auf 12 einstellen!
vuplus-images.co.ukenigma2-plugin-skins-goliath-rv2-1080p-hd-by-mamba65_RV2_all.ipk
Re: skins mamba65
Napsal: 19 led 2017, 19:50
od vusolo2
~ Goliath_RV3_1080p_HD ~
*FOR > VTI 11.01 < Image*
First I have to thank hmmmdada for its excellent converter, which has allowed me!
What is first step to install crash prevention!
Treba dodrzat prilozeny instalacny postup od autora.
1. Updating VTI Image
2. Install EPG Share 3.0 from the feed otherwise crash is pre-programmed
3. In EPG Share in Settings, set: Improve EPG with Extra Data - YES
4. Download EPG Share manually
5. Goliath_RV3_1080p_HD Install skin afterwards and GUI reboot
- New menu with edit mode and picons display
- 2 different InfoPanel
- 4 different SecondInfo panels with Scoller text, SystemInfo, Event, Weather..uvsm ...
- 2 different channel list / epg with scrolll text, event ....
* SkinParts Settings *
General for handling skinparts:
VTi -> ">To activate this, you go to the receiver under Menu -> VTi ->
Settings-Goliath_RV3_1080p_HD in the Goliath_RV3_1080p_HD proactivate to YES
Yellow button and highlight the desired skinpart.xml.
By pressing red, green, you leave the settings and are prompted to restart.
This leads you through and the skinparts are active
* Weather settings *
1 Open weather plugin from plugins browser
2-Press Menu from the keyboard
3-green button (Add)
4-Type the name of the city in option (city)
5 Click yellow buttons (search code)
6 Select your city and press green (ok)
7 Press the green (OK) button again
8-Finished Exit Plugin button Press Exit button
enigma2-plugin-skins-goliath-rv3-1080p-hd-by-mamba65_v3_all.ipk
