Full HD Glass 17
vusolo2
- Dal poděkování: 40 poděkování
- Dostal poděkování: 63 poděkování
Full HD Glass 17
Full HD Glass 17 ver. 1.44
- aktualizovane: pl, sk, cz, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl,
et, lt, fr
- pridany extra screen 48
- extra screen grafika, sady ikon a ukazky, help aktualizovane v downloade
- opravy/korekcie roznych screenov
- oprava volume typ: farebny posuvnik
- pridane typy vyberu kanalov: PIG5, PIP5, G17 viaceo prog.3 (picon kanal,
provider, sat)
- pridane def. screenov pre pluginy: EMC,Pemanent clock, Infobar tuner state,
AspectRatioSwitch, OpenWebif, Transcoding, EPG Import, EPG Refresh,
Open Multiboot, Foreca
update is available online (setup and website)
Thx@samann
et, lt, fr
provider, sat)
Thx@samann
vusolo2
Re: [OE2.2]Full HD Glass 17
Full HD Glass 17 ver. 1.47
- ponuka stahovania: odobrana moznost stahovania picon 50x30
(neaplikuje sa v images: DMM OE 2.2/2.5, VTi)
- pridany typ vyberu kanalov: G17 (+viacero programov) 2
- ponuka stahovania: aktualizovane - napoveda
- pridany autopatch pre picony vo vybere kanalov (neaplikuje sa v images:
- opravy/korekcie roznych screenov a pridane def. screenov pre dalsie pluginy
dostupna online aktualizacia
Thx@shamann
Thx@shamann
vusolo2
Full HD Glass 17 ver. 1.49
- fix/corections more of screens
- edited renderer extra EPG
- added autopatch for BH image
- added screen definitions for more plugins: autopin, netatmo, ChromiumOS
- fix screens with context menu
- upraveny renderer extra EPG
- pridany autopatch pre BH image
- pridane def. screenov pre dalsie pluginy: autopin, netatmo, ChromiumOS
- oprava screenov s context menu
Thx@shamann
Thx@shamann
vusolo2
Full HD Glass 17 ver. 1.57
- added alternative method to checking of online update
- added autorestart bitrate if is binary bitrate used
- bitrate auto stop limit: added option - None
- fix CAID ECM pids height calculate
- added screen definitions for more plugins: videodb, web browser(deb version only)
- fix detection Oscam if is used any type of ECM in settings of oscam
- added detektion Ultimo 4k, Solo 4k
- added extra screen 43, 44, 45
- icon sets and previews updated in download
- pridana alternativna metoda pre overenie dostupnosti aktualizacie
- pridany autorestart bitrate ak je pouzita binary bitrate
- bitrate auto stop limit: pridana moznost - ziadny
- oprava vypoctu vysky pre CAID ECM pidy
- pridane def. screenov pre dalsie pluginy: vided, web browser(len deb verzia)
- oprava detekcie Oscam-u ak je pouzity lubovolny typ ECM v nastaveniach oscam-u
- pridana detekcia Ultimo 4k, Solo 4k
- pridany extra screen 43, 44, 45
- sady ikon a ukazky aktualizovane v downloade
Thx@shamann
Thx@shamann
vusolo2
Full HD Glass 17 ver. 1.60
- updated: pl, sk, cz, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt, fr
- fix menu type: List and Icons
- fix support extended version of bitrate plugin
- changed update dialog
- color temperature display range changed (-26 to 34 for each 2 degrees color
according to the international scale)
- fix Positioner setup screen (OpenPLi version)
et, lt, fr
- oprava menu typ: list a ikony
- oprava podpory pre rozsirenu verziu bitrate pluginu
- zmeneny dialog pre aktualizaciu
- zmeneny farebny rozsah zobrazovania teploty (-26 az 34 pre kazde 2 stupne
farba podla medzinarodnej stupnice)
dostupna aj online aktualizacia
Thx@shamann
et, lt, fr
Thx@shamann
vusolo2
Full HD Glass 17 ver. 1.63
- fix signal bar (all extra screens where is used)
- added alternative method to detect IPTV stream
- WEATHER: added support of SSL certificates
- OTHER: removed Volume type, user encoding.conf (deb version only)
- added new chapter: VOLUME
- VOLUME: added - Volume type, Mute picture transparency
- help updated in download menu
- fix autopatch for channel selection picons (It does not apply in images:
et, lt, fr
- oprava signal bar-u (vsetky extra screeny kde je to pouzite)
- pridana alternativna metoda detekcie IPTV stream-u
- POCASIE: pridana podpora pre SSL certifikaty
- OSTATNE: odsranene - Typ hlasitosti, user encoding.conf (len deb verzia)
- pridana nova kapitola: HLASITOST
- HLASITOST: pridane - typ hlasitosti, priehladnost obrazka Mute
- help aktualizovana v ponuke stahovania
- oprava autopatch pre picony vo vybere kanalov (neaplikuje sa v images:
Thx@shamamm
et, lt, fr
Thx@shamamm
vusolo2
Full HD Glass 17 ver. 1.66
- fix oscam ymod version detection
- added detection of modulation 16APSK, 32APSK (DVB-S/S2 only)
et, lt, fr
- oprava detekcie oscam ymod verzie
- pridana detekcia modulacie 16APSK, 32APSK (len pre DVB-S/S2)
Thx@shamann
et, lt, fr
Thx@shamann
vusolo2
Full HD Glass 17 ver. 1.74
- Setup of FHDG17: removed numbering of chapters
- fix all Extra Screens: displaying 16APSK, 32APSK modulation
- WEATHER: added option - Animated Weather Icons
- ENHANCED WEATHER: added option - Animated Weather Icons
- DOWNLOAD MENU: added option - Animated Weather Icons
- added extra screen 87
- DOWNLOAD MENU: updated extrascreens graphocs, icon sets and previews
- SETTINGS OF FHDG: changed layout, removed function of blue and yellow button,
splitted function of green and OK button, button OK aktivates function of some
items, press green button to save cfg only
et, lt, fr
- Nastavenia FHDG17: zrusene cislovanie kapitol
- oprava vsetkych Extra Screenov: zobrazenie 16APSK, 32APSK modulacie
- POCASIE: pridana moznost - Animovane Ikony pocasia
- ROZSIRENE POCASIE: pridana moznost - Animovane Ikony pocasia
- PONUKA STAHOVANIA: pridana moznost - Animovane Ikony pocasia
- pridany extra screen 87
- PONUKA STAHOVANIA: aktualizovane extrascreen grafika, sady ikon a ukazky
- NASTAVENIA FHDG: upraveny vzhlad, zrusena funkcia pre modre a zlte tlacitko,
oddelena funkcia pre zelene a OK tlacitko, OK aktivuje funkcie pri niektorych
polozkach, zelene tlacidlo sluzi len na ulozenie aktualnej cfg
Thx@shamann
et, lt, fr
Thx@shamann
vusolo2
Full HD Glass 17 ver. 1.78
- removed displaying Vpid, Apid if bitrate is disabled
- fix default values of FHDG
- WEATHER: added option - Display nigttime icons
- added alternative method to searching of picons
- fix radio screensaver (deb version only)
- added extra screen 89
- added detection of Gcam (after restore icons type will be set to default
type 1, so after update and autorestore you must download icons and previews
and then set/select your prefered icons type)
- DOWNLOAD MENU: updated extrascreens graphics, icon sets and previews, piconCam
- added new chapter LISTBOX FONT SIZE(deb version only)
- LISTBOX FONT SIZE: added - Bigger, Big, Medium, Small, Smaller
- WEATHER: added option - Animation speed (ms)
- ENHANCED WEATHER: added option - Animation speed (ms)
et, lt, fr
- odstranene zobrazenie Apid, Vpid ak je bitrate vypnute
- oprava default hodnot nastavenia FHDG
- POCASIE: pridana volba - Zobrazit nocne ikony
- pridana alternativna metoda vyhladania piconov
- oprava radio screensavera (len deb verzia)
- pridany extra screen 89
- pridana detekcia Gcam (po obnove bude zmeneny typ ikon na 1, nasledne
je potrebne stiahnut znova sady ikon a ukazky a potom zvolit svoj oblubeny typ)
- PONUKA STAHOVANIA: aktualizovane extrascreen grafika, sady ikon a ukazky, piconCam
- pridana nova kapitola VELKOST FONTU PRE LISTBOX (len deb verzia)
- VELKOST FONTU PRE LISTBOX: pridane - Vacsi, Velky, Stredny, Maly, Mensi
- POCASIE: pridana moznost - Rychlost animacie (ms)
- ROZSIRENE POCASIE: pridana moznost - Rychlost animacie (ms)
Thx@shamann
et, lt, fr
Thx@shamann
vusolo2
Full HD Glass 17 ver. 1.79
- fix actual cfg saving
et, lt, fr
- oprava ulozenia aktualnej cfg
Thx@shamann
et, lt, fr
Thx@shamann
vusolo2
Full HD Glass 17 ver. 1.86
- fix mgcamd, gcam detection
- fix setup of FHDG17
- acceleration menu items switching in menu types with icons and pictures
- DOWNLOAD MENU: bigger update of menu icons, menu icons big
- added alternative method to searching of picons (if missing search 1_0_1...,
1_0_16..., 1_0_19...)
- OTHERS: added option - Service scan long list
- LISTBOX FONT SIZE: added auto settings of line hight if font size was changed
- WEATHER: changed "Country" to "Location"
et, lt, fr
- oprava detekcia mgcamd, gcam
- oprava nastaveni FHDG17
- zrychlene prepinanie poloziek v menu pre typy s ikonami a vacsimi obrazkami
- PONUKA STAHOVANIA: vacsia aktualizacia menu ikon, menu ikony velke
- pridana alternativna metoda vyhladania piconov (ak chyba hlada 1_0_1...,
- OSTATNE: pridana volba - vyhladane kanaly dlhy zoznam
- VELKOST FONTU PRE LISTBOX: pridane automaticke nastavenie vysky riadku
pri zmene v nastaveni
- POCASIE: zmeneny "Stat" na "Poloha"
Thx@shamann
et, lt, fr
Thx@shamann
vusolo2
Full HD Glass 17 ver. 1.90
- WEATHER: added altenative checking of the website - provider MSN
- WEATHER: fix main code
- fix screens of the plugin Partnerbox
- added screen definitions for more plugins: nameZAP, Media Center audio
a video player
- fix position of special info: Info ECM by Duriho
- fix devices label (USB,HDD)
et, lt, fr
- POCASIE: pridana alternativna kontrola dostupnosti website - provider MSN
- POCASIE: oprava hlavneho kodu
- oprava screenov pre plugin Partnerbox
- pridane def. screenov pre dalsie pluginy: nameZAP, Media Center audio
a video player
- oprava defaultnych hodnot
- oprava pozicie specialneho info: Info ECM od Duriho
- oprava nazvov pre zariadenia (USB,HDD)
Thx@shamann
a video player
et, lt, fr
a video player
Thx@shamann
vusolo2
Full HD Glass 17 ver. 1.96
- restore cfg: changed to Dir browser with option to choose any .conf file
to restore cfg
- fix screen History
- changed skin of all setup screens
- DOWNLOAD MENU: new skin and the new method of download - you can select items
to downlad and selected items are downloaded all at once
- HDD: added option to enable displaying temperature, size, and free space
to the HDD in emc and movieplayer infobar
- fix renderers using font size
- FHDG SETTING: added current path displaying in directory browser
et, lt, fr
- obnova cfg: zmenena na prehliadac adresarov z moznostou zvolenia lubovolneho
suboru .conf s cfg ktora je pozadovana na obnovenie
- oprava obrazovky Historia
- zmeneny vzhlad vsetkych obrazoviek setup-u
- PONUKA STAHOVANIA: novy vzhlad a nova metoda stahovania - mozete vybrat polozky
na stiahnutie a vybrane polozky su stiahnute naraz
- HDD: pridana moznost zapnut zobrazenie teploty, velkosti a volneho miesta
na HDD v infobare emc a movieplayer-a
- oprava rendererov pouzivajucich velkost fontu
- NASTAVENIA FHDG: pridane zobrazenie aktualnej cesty v prehliadaci adresarov
online aktualizacia(setup and website)
Thx@shamann
to restore cfg
et, lt, fr
Thx@shamann
vusolo2
Full HD Glass 17 ver. 2.08
- dir browser: added path autocutting in title
- DOWNLOAD MENU: changed results layout after files download
- fix line hight auto settings in Channel selection
- fix ECM PID displaying (deb version)
- WEATHER: removed option "Find a city" (in extensions, in menu), added option
"Find a city" activated immediately press OK button
- added screen definitions: change root password, filebrowser generic, mediacenter
mediadatabase, PIP setup, Subtitle quick config
- EXTRA INFOBAR: second picon type additional options: "only weather", "sat and
weather", "provider and weather", "sat, provider and weather", shows current
temperature and icon according to the setting in chapter WEATHER(city, provider)
- DOWNLOAD MENU: added piconWeather white, piconWeather black
- fix "Find a city" Yahoo type searching
- fix infobar type: simple
- TP INFO: extended support of HEVC codec
- FHDG SETTING: added chapter ANIMATION
- ANIMATION: added options: enable animations, infobar - picon, second picon, ECM
line, TPinfo and type, menu - icons (not icon type), channel selection - picon,
prov, sat (not picon in list of channels - services list)
(available-autodetection on HW and images which supports single object animation)
press OK in the setup displaying animation preview again
- added extra screen 57,59
- added Multistream (MS) detection in TP info - appears only if it is in
the chapter: EXTRA INFOBAR enabled option: Show Satellite position in Tp info
- added channel selection type: PIG + PIP 3, G17 events 4
- DOWNLOAD MENU: updated satellites table
et, lt, fr
- prehliadac adresarov: pridane auto orezavanie cesty v titulku
- PONUKA STAHOVANIA: uprava vzhladu vysledku po stahovani suborov
- oprava auto nastavenia velkosti riadku pre vyber kanalov
- oprava ECM PID zobrazenia (deb verzia)
- POCASIE: zrusena volba "Najdi mesto" (v rozsireniach, v menu), pridana volba
"Najdi mesto" aktivuje sa stlacenim OK
- pridane def pre screeny: change root password, filebrowser generic, mediacenter
- EXTRA INFOBAR: typ druheho piconu rozsireny o moznosti: "len pocasie", "satelit
a pocasie", "provider a pocasie", "satelit, provider a pocasie", zobrazuje
aktualnu teplotu a ikonu podla nastaveni v kapitole POCASIE (mesto, provider)
- PONUKA STAHOVANIA: pridane piconWeather biele, piconWeather cierne
- oprava "Najdi mesto" vyhladavanie pre Yahoo
- oprava typu infobaru: jednoduchy
- TP INFO: rozsirena podpora detekcie kodeku HEVC
- NASTAVENIA FHDG: pridana kapitola ANIMACIE
- ANIMACIE: pridane volby: povolit animacie, infobar - picon, druhy picon, ECM
line, TP info a typ, menu - ikony (nie typ ikon), vyber kanalov - picon, prov,
sat (nie picon pre zoznam kanalov - services list)
(dostupne-autodetekcia len na HW a image, ktore podporuje animaciu single objektov)
stlacenim OK v setupe je mozne znova zobrazit preview zvolenej animacie
- pridany extra screen 57,59
- pridana detekcia Multistream (MS) v TP info - zobrazi sa len ak je v kapitole
EXTRA INFOBAR povolena volba: zobraz poziciu satelity v TP info
- pridany typ vyberu kanalov: PIG + PIP 3, G17 viacero prog. 4
- PONUKA STAHOVANIA: aktualizovana tabulka satelitov
Thx@shamann
et, lt, fr
Thx@shamann
vusolo2
Full HD Glass 17 ver. 2.13
- updated enhanced weather translations: sk, cz, et, lt
- fix/corections some extra screens
- added enhanced method of picon searching
- fix CAID:PID info
- WEATHER: YAHOO - added option Show yesterday
- WEATHER/ENHANCED WEATHER: fix colors table
- fix audio trak type AAC detection
- added detection tuners: A1 - A8, B1 - B8 (after restore icons type will be set
to default type 1, so after update and autorestore you must download icons and
previews and then set/select your prefered icons type)
- DOWNLOAD MENU: updated icon sets and previews
- EXTRA INFOBAR: added option Tuner info with options - real data from tuner,
transponder info
et, lt, fr
- aktualizovane preklady pre rozsirene pocasie: sk, cz, et, lt
- opravy/korekcie viacerych extra screenov
- pridana rozsirena metoda vyhladania picon
- oprava CAID:PID info
- POCASIE: YAHOO - pridana moznost zobraz vcerajsok
- POCASIE/ROZSIRENE POCASIE: oprava tabulky farieb
- oprava detekcie AAC audio stopy
- pridana detekcia tunerov: A1 - A8, B1 - B8 (po obnove bude zmeneny typ ikon
na 1, nasledne je potrebne stiahnut znova sady ikon a ukazky a potom zvolit
svoj oblubeny typ)
- PONUKA STAHOVANIA: aktualizovane sady ikon a ukazky
- EXTRA INFOBAR: pridana volba Informacie z tunera s moznostami - skutocne data
z tunera, informacie z transpondera
Thx@shamann
Download https://www.sendspace.com/file/3k6lgz
- fix CAID:PID info
transponder info
et, lt, fr
svoj oblubeny typ)
Thx@shamann
