mbox 0.4
Stáhni Emu Plugin.
AzMaster
mbox 0.4
Příspěvek od AzMaster »
mbox 0.4 BETA build 0023 3 REUPLOAD by mower
0.4 BETA build 0023
-Fix problem with returning wrong boxid in (cached) DCW message.
-Few changes in cache code.
-Few changes in code for cards reshare.
-Added support for SSSP protocol, S line in mbox.cfg, tested only on Windows OS, on Linux OS still doesnt work!!.
-Added support for triple dragon receiver(set D on 5 in mbox.cfg).
-Few changes in code for Qbox HD receiver(set D on 6 and A on 1 in mbox.cfg).
-Information in stat.info file is just for mbox peers!!.
-Added mapping , from 1815 to 1801 in H line (mbox.cfg).
-Few changes in sssp code, affect just mbox.exe file.
-Fix problem mapping 1815 to 1801, add mapping from 1822 to 1801.
-Few changes
ZDROJ http://azboxworld.com/index.php?page=Th ... eadID=5311
fyzik
Mbox 0.4 BETA build 0023 rev.4
Příspěvek od fyzik »
Thanks to mower/The_Ripper
* Fix problem with returning wrong boxid in (cached) DCW message.
* Few changes in cache code.
* Few changes in code for cards reshare.
* Added support for SSSP protocol, S line in mbox.cfg, tested only on Windows OS, on Linux OS still doesnt work!!.
* Added support for triple dragon receiver(set D on 5 in mbox.cfg).
* Few changes in code for Qbox HD receiver(set D on 6 and A on 1 in mbox.cfg).
* Information in stat.info file is just for mbox peers!!.
* Added mapping , from 1815 to 1801 in H line (mbox.cfg).
* Few changes in sssp code, affect just mbox.exe file.
* Fix problem mapping 1815 to 1801, add mapping from 1822 to 1801.
* Few changes.
* From now gboxx and mbox protocol is seperated. They are compiled in seperated files(mbox with only gboxx is in "mboxg" folder). For mbox protocol G line stay for peer.
* Added SSSP code for Linux OS, it wasnt tested!!.
ZDROJ: http://www.azboxworld.com/index.php?pag ... eadID=5401
Re: mbox 0.4
MBox 0.4 BETA build 0023 - MULTI-ECM Edition (Azbox HD)
len samotna binarka !!!!
If you use wrong prio file - some channels will not work.
simply - remove prio file
MboxCardinfo V1.0 Beta
mboxinfo plugin
- rozbalte na USB kluc, alebo na HDD v PC a do azboxu (adresar /tmp/ ) prekopirujte subory plugins.lst a mboxinfo.plugin
Instalovat cez Home 3 - cervene tlacitko ....
It should tell you [once you're in mboxinfo menu]:
-which peers you have and their details [green button]
-which cards you have and from whom [blue button]
-enable you to restart Mbox [yellow button]
Zpět na „Emu pluginy“
