CCcam - beta
CCcam - beta
Diskusia k CCcam - beta verzii.
fevlad
Dal poděkování: 5 poděkování
Re: CCcam - beta
Příspěvek od fevlad »
grantec píše:Diskusia k CCcam - beta verzii.
Neskúšal nikto tento Cccam na share ako klient. Chcem kúpit AZ BOX len potrebujem vedieť či to funguje cez Cccam.
Dík
Benny
Re: CCcam - beta
Příspěvek od Benny »
fevlad píše:
Dík
Nezkousel ale jestli nahodou nejde tak behem par tydnu urcite pujde
fevlad
Re: CCcam - beta
Benny píše:
fevlad píše:
Dík
Prosím ta , a ty to nevieš vyskúšat máš aj 200 aj AZ , server 200-klient AZ
díkes
jipo
Re: CCcam - beta
Příspěvek od jipo »
Tak me to teda nefunguje. Na CCcam serveru se tavri jako pripojeny, ale klient v azboxu nedekoduje.
Tohle to pise klient:
MMP[CCcamCAS]$ ./cccam_module -d
[19:41:11] [cccam_client] Starting cccam_client pre release v. 0.1 for Azbox Elite/Premium receivers.
[19:41:11] [cccam_client] Coded by The_Ripper ;)
Thx to all who helped me ;)
[19:41:11] [cccam_client] Special Thanks goes to uvadi.
[OPENXCAS_API:Thu May 28 19:41:11.672] openxcas_open:285 ## CCcamCAS
[OPENXCAS_API:Thu May 28 19:41:11.677] load_xcas_control:98 ## loaded controller ID = 0x19760507
osdep_msq_server_open : key_request 0x6C4B094 key_response 0x6C4B095
osdep_msq_server_open : request msq is already created
osdep_msq_server_open : response msq is already created
osdep_msq_client_connect : key_request 0x6C4B094 key_response 0x6C4B095
[19:41:11] [cccam_client] Creating cccam worker thread ...OK
[19:41:11] [cccam_client] Creating openxcas API message thread ...OK
[19:41:11] [cccam_client] Trying to connect to server (192.168.88.13:12000)
[19:41:11] [cccam_client] Connected to (192.168.88.13:12000) ...
[19:41:13] [cccam_client] Creating cccam worker thread for (192.168.88.13:12000) ...OK
[19:41:27]
[19:41:27] ReReading pmt.tmp
[19:41:33]
[19:41:33] ReReading pmt.tmp
[19:41:33] ==================================================================
[19:41:33] ECM: CA ID: 0x0D70 Cryptoworks -> CA PID: 0x008F
[19:41:33] ECM: CA ID: 0x0D03 Cryptoworks -> CA PID: 0x00AD
[19:41:33] ECM: CA ID: 0x0D0F Cryptoworks -> CA PID: 0x0639
[19:41:46]
[19:41:46] ReReading pmt.tmp
[19:41:46] ==================================================================
[19:41:46] *ECM: CA ID: 0x0D02 Cryptoworks -> CA PID: 0x1580
[19:41:46] ECM: CA ID: 0x1815 Nagravision -> CA PID: 0x16AC
[19:41:46] [cccam_client] No card for CaID:0x0D02 SID:0x4F6A ECM:0x1580
[19:41:53] [cccam_client] No card for CaID:0x0D02 SID:0x4F6A ECM:0x1580
Incubus funfuje relativne v pohode.
AZBOX Elite, IPbox 200, DM 500
riddle
Re: CCcam - beta
Příspěvek od riddle »
uz je releases 2
jipo
Re: CCcam - beta
Příspěvek od jipo »
Vecer ho vyzkousim.
Benny
Re: CCcam - beta
jipo píše:Vecer ho vyzkousim.
koukam ze jsou docela pilni.
riddle
Re: CCcam - beta
a do nekolika dni bude udajne finall verze :)
Benny
Re: CCcam - beta
riddle píše:a do nekolika dni bude udajne finall verze :)
na cccam se docela tesim, prisel mi jako lepsi nez kombinace newcs + mgcamd
fevlad
Re: CCcam - beta
Benny píše:
Ahoj , ved práve aj ja mám IP BOX 250 v nej Cccam 2.0.1 a preto potrebujem vediet či funguje share, pretože chcel by som kúpiť AZ BOX HD premium,testni ,ked budeš moct, a daj potom vedieť, ako to funguje.
Dík
jipo
Re: CCcam - beta
Příspěvek od jipo »
Tak ta druha verze fugovala jenom chvili, 3x jsem prepnul -ok pak jsem zkusil restart a uz jsem to nerozbehnul. Zacalo se to chovat jako ta prvni. Ale vypada to nadejne.
gama
Re: CCcam - beta
Příspěvek od gama »
jipo píše:Tak ta druha verze fugovala jenom chvili, 3x jsem prepnul -ok pak jsem zkusil restart a uz jsem to nerozbehnul. Zacalo se to chovat jako ta prvni. Ale vypada to nadejne.
Mne sa ju žial nepodarilo rozbehať vôbec.
AZbox Elite,GIGABLUE Quad+,VU+Uno
klidas
Re: CCcam - beta
Příspěvek od klidas »
Chova se to u me tak, ze nabehne, pripoji se na server, nacte karty, pak je zase odebere a odpoji se nebo killne. :21:
Server je 2.0.11 jestli to hraje roli...
MAXIMUM E-85 Multifocus, 1W-28,2E, AZBOX HD Elite (fw 0.9.5303, OpenRSI 3.0), HDBOX 9100 (fw 1.10.13), Samsung UE40B6000.
neo177
Re: CCcam - beta
Příspěvek od neo177 »
cccam pre relase 2 sa chova celkom divoko :) par krat sa mu podarilo nieco dekodovat ale inak hlasi len NOK alebo ze vobec kartu nenasiel (co je celkom vtipne ked ich ma na vyber z 150 kariet :)) pockame na nejaku betu. ale dobre znamenie je, ze aspon sa to zacalo hybat a neboli sme v neistote ci nieco bude :)
online: DM800 HD + cccam
offline: AZBox Elite HD + cccam
Zpět na „AzBox HD diskuze“
