netdisk - script / diskusia
- dempsey
Tu môžete diskutovať o scripte pre sieťový disk
xsauron
Re: netdisk - script / diskusia
#!/bin/sh
# network disk mounting service for AZBOX Elite/Premium
# instead of internal or external hdd
export PATH=/bin:/sbin:/usr/bin:/usr/sbin
# IP of the network storage point (Samba or NFS-Server)
NETDEVICE=192.168.1.1
# Shared directory on the Samba or NFS Server
NETDIR=/part2/video_nahravky
# Directory mapping from netdisk to azbox
MOVIES=filme
PICTURE=bilder
MUSIC=musik
RECORDING=recording
RECORDFILE=recordfile
PVRFILE=pvrfile
DOWNLOAD=download
start() {
echo "starting netdisk"
if [ -e /tmp/HAVE_HDD ]; then
echo "intern hdd already mounted"
exit 0
fi
/sbin/ping -c 1 $NETDEVICE | grep round-trip
if [ $? = 1 ]; then
echo "netdisk not online"
exit 0
fi
if [ ! -e /DATA/netdisk ]; then
echo "make dir /DATA/netdisk"
mkdir -p /DATA/netdisk
fi
# activate for samba shares
/bin/mount -t cifs -o username=guest,rw,noatime,rsize=16384,wsize=16384 //$NETDEVICE/$NETDIR /DATA/netdisk
# activate for nfs shares
#/bin/mount -t nfs -o username=???,rw,noatime,rsize=16384,wsize=16384 $NETDEVICE://$NETDIR /DATA/netdisk
if [ $? = 1 ]; then
echo "failed to mount netdisk"
exit 0
fi
touch /tmp/HAVE_HDD
#chmod 777 /DATA/netdisk
if [ ! -e /DATA/netdisk/$MOVIES ]; then
echo "make dir /DATA/netdisk/$MOVIES"
/bin/mkdir -p /DATA/netdisk/$MOVIES
fi
rmdir /DATA/movie
/bin/ln -s /DATA/netdisk/$MOVIES /DATA/movie
if [ ! -e /DATA/netdisk/$PICTURE ]; then
echo "make dir /DATA/netdisk/$PICTURE"
/bin/mkdir -p /DATA/netdisk/$PICTURE
fi
rmdir /DATA/picture
/bin/ln -s /DATA/netdisk/$PICTURE /DATA/picture
if [ ! -e /DATA/netdisk/$MUSIC ]; then
echo "make dir /DATA/netdisk/$MUSIC"
/bin/mkdir -p /DATA/netdisk/$MUSIC
fi
rmdir /DATA/music
/bin/ln -s /DATA/netdisk/$MUSIC /DATA/music
if [ ! -e /DATA/netdisk/$RECORDING ]; then
echo "make dir /DATA/netdisk/$RECORDING"
/bin/mkdir -p /DATA/netdisk/$RECORDING
fi
rmdir /DATA/recording
/bin/ln -s /DATA/netdisk/$RECORDING /DATA/recording
if [ ! -e /DATA/netdisk/$RECORDFILE ]; then
echo "make dir /DATA/netdisk/$RECORDFILE"
/bin/mkdir -p /DATA/netdisk/$RECORDFILE
fi
rmdir /DATA/recordfile
/bin/ln -s /DATA/netdisk/$RECORDFILE /DATA/recordfile
if [ ! -e /DATA/netdisk/$PVRFILE ]; then
echo "make dir /DATA/netdisk/$PVRFILE"
/bin/mkdir -p /DATA/netdisk/$PVRFILE
fi
rmdir /DATA/pvrfile
/bin/ln -s /DATA/netdisk/$PVRFILE /DATA/pvrfile
if [ ! -e /DATA/netdisk/$DOWNLOAD ]; then
echo "make dir /DATA/netdisk/$DOWNLOAD"
/bin/mkdir -p /DATA/netdisk/$DOWNLOAD
fi
rmdir /DATA/download
/bin/ln -s /DATA/netdisk/$DOWNLOAD /DATA/download
stop() {
/bin/umount /DATA/netdisk
rm /tmp/HAVE_HDD
restart() {
stop
start
case "$1" in
start)
start
stop)
stop
restart|reload)
restart
echo $"Usage: $0 {start|stop|restart}"
exit 1
esac
exit $? Nevim hlavne co mam napsat do polozek:
kdyz se podivam v azedboxu na to umisteni pres sit je tam napsano network/WORKGROUP/WL500W/part2/video_nahravky
Diky za pripadnou radu
xsauron
Jinak skript jsem nahral do slozky /DISK2/etc/start.d/ a nastavil prava. Takhle by se mel sputit Pri startu ne?
xsauron
Zdravim tak jsem se v tom trochu "povalel". Nahral jsem si nakonec script pres ftp v programu Maz. Abych vubec ozkousel jestli to funguje a dal prikaz ke spusteni pres telnet. A nefungovalo.
1) Nemohl najit /bin/ping atd.
Reseni: vim proc, ale smazal jsem vsechny vyskyty /bin ve scriptu pred prikazy a makato.
2) Protoze mam disk spojeni s wifi routerem na ip 192,168.1.1, ale je rozdelen na 3 partiony musel jsem napsat do NETDIR treba partion2
Disk pak namoutnul vse do /DATA/netdisk, ale ten jsem pres menu na mem AZBOXU stejne nevidel ;-( a nepovolil mi Azbox nahravani
Zapojil jsem tedy usb flasku do AZBOXU a zaroven sitovy disk namoutnul jako by na ni (viz kod) a ono to slape.
Ted uz muzu nahravat na sitovy dis,a le problem je, ze tam musim mit flasku.
Zde je kod:
Dotaz:
Vim jak zaridim namoutnuti sitoveho disku, ale nevite jak zaridim,aby slozka kam to namountu byla videt v azboxu a azbox do ni umoznil nahravat???
Zde je kod:
#!/bin/sh
NETDIR=part2
MOVIES=filme
PICTURE=bilder
MUSIC=musik
RECORDING=recording
PVRFILE=pvrfile
DOWNLOAD=download
start() {
exit 0
fi
if [ $? = 1 ]; then
exit 0
fi
mount -t cifs -o username=quest,rw,noatime,rsize=16384,wsize=16384 //$NETDEVICE/$NETDIR /DATA/usb1
if [ $? = 1 ]; then
exit 0
fi
touch /tmp/HAVE_HDD
stop() {
rm /tmp/HAVE_HDD
restart() {
stop
start
case "$1" in
start)
start
stop)
stop
restart|reload)
restart
exit 1
esac
exit $?
Dotaz:
p3ksatdigi
Vyskusal som vsetky scripty, ktore som tu nasiel, ale ani jeden mi nenamountol sietovy disk (firmware 4890).
Jedna otazocka, Settings/Network Service/Suborovy server .... ma byt vypnuty, alebo zapnuty. Ak ma byt zapnuty, ako ma byt nastaveny?
Ma to niekto rozbehane?
Ak ano, tak ako?
Dakujem
Ak ano, tak ako?
Dakujem
p3ksatdigi
Nakoniec sa mi to podarilo mountnut pomocou tohto prikazu
$mount.cifs //192.168.1.2/MUSIC /DATA/music -o password=bob,username=whatever
uz len upravit script aby mi to robilo zakazdym ked pristroj startuje.
p3ksatdigi
takze nakoniec som to poriesil tak, ze som dany prikaz vlozil uz do existujuceho scriptu v DISK2/etc/start.d/S10UserDefinedShell
#!/bin/sh
# Samples for user defined shell
start() {
echo "===> Starting user defined script"
mount -t cifs -o username=xxx,password=xxx //192.168.1.1/MyDisk /DATA/picture
echo "User script test" > /tmp/UserDefinedShellIsRunning
stop() {
echo "===> Stopping user defined script"
rm -f /tmp/UserDefinedShellIsRunning
restart() {
stop
start
case "$1" in
start)
start
stop)
stop
restart|reload)
restart
exit 1
esac
exit $?
#!/bin/sh
start() {
stop() {
restart() {
stop
start
case "$1" in
start)
start
stop)
stop
restart|reload)
restart
exit 1
esac
exit $?
