fw 0.9.4829
vikino
Re: fw 0.9.4829
nieco podobne som zazil aj ja. ak sa dobre pamatam, zliezol som vtedy s fw na nejaky nizsi a problem s casovym nahravanim zmizol. ale mne v tomto fw casove nahravania funguje. nemozem to teraz preverit lebo sa prave timeshiftuje...
frcko73
- Mazák
Re: fw 0.9.4829
Formát : Matroska
Velikost souboru : 7,85 GiB
Duration/String : 2h 41mn
Celkový BitRate : 6 953 Kbps
Encoded date : UTC 2010-04-23 19:53:59
Použitý software : mkvmerge v2.4.1 ('Use Me') built on Dec 5 2008 18:30:05
Enkódoval : libebml v0.7.7 + libmatroska v0.8.1
Video
Formát : AVC
Formát/ : Advanced Video Codec
Format_Profile : High@L4.1
Format_Settings_CABAC/String : Ano
Format_Settings_RefFrames/String : 5 frame
MuxingMode : Container profile=Unknown@4.1
CodecID : V_MPEG4/ISO/AVC
Bit rate : 6 367 Kbps
BitRate_Nominal/String : 6 500 Kbps
Šířka : 1 280pixely
Výška : 720pixely
Poměr stran : 16:9
Frame rate : 23,976 fps
Rozlišení : 8 bits
Colorimetry : 4:2:0
ScanType/String : Progressive
Bits/(Pixel*Frame) : 0.288
StreamSize/String : 7,18 GiB (91%)
Titul : Avatar.2009.720p.BluRay.x264-TDM
Enkódoval : x264 core 93 r1542 5b86182
Nastavení enkoderu : cabac=1 / ref=5 / deblock=1
-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=6500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Jazyk : English
Audio
Formát : AC-3
Formát/ : Audio Coding 3
CodecID : A_AC3
Bit rate : 448 Kbps
Kanál(y) : 6 kanály
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48,0 KHz
StreamSize/String : 518 MiB (6%)
Text
Formát : UTF-8
CodecID : S_TEXT/UTF8
/ : UTF-8 Plain Text
Z interneho HDD,bez jedneho jedineho zaseku,ci kocky v obraze.....No proste parada.
Video
Formát : AVC
Šířka : 1 280pixely
Výška : 720pixely
Poměr stran : 16:9
Rozlišení : 8 bits
Colorimetry : 4:2:0
Jazyk : English
Audio
Formát : AC-3
CodecID : A_AC3
Bit rate : 448 Kbps
Kanál(y) : 6 kanály
Text
Formát : UTF-8
monkus
Re: fw 0.9.4829
by ma zaujimalo, ako je to mozne? mne cuka dts, ked pretocim mkv, tak potom mi seka, obcas sa zrychli obraz/zvuk, uplna haluz.
opakujem, 4466 mi fici bez akychkolvek problemov, takze nie je to tym, ze by som mal zly disk, zly azbox, zly ... whatever.
frcko73
- Mazák
Re: fw 0.9.4829
este skusim stiahnut FULLHD,co to povie....
r_e_n_e
Re: fw 0.9.4829
no neviem ci ma niekto takuto skusenost ako ja.
mal som tam fw azbox-0.9.4754-patch.bin
siel som do menu a zvolil som update z USB kluca
nabehol update, restartol sa box zacal sa uploadovat firmware azbox-0.9.4829-patch.bin.
presiel checking...
box sa zrestartoval...spustil sa LOADING...
potom SETTING...
a to je vsetko...
Na obrazovke stale blika AZBOX....
jedine co viem je dostat sa do SLEEP, REBOOT, SHUTDOWN, CANCEL menu...
Pomozte....
presiel checking...
potom SETTING...
a to je vsetko...
Pomozte....
HD-BOX FS-7119 HD PVR
HS 2.11.96 HbbTV.; L 7.14; API 8 jan 2013; FDU 1.4
Beam
Re: fw 0.9.4829
FW nefunguje v SK lokalizaci, jak uz je tu psano x-krat..
rekl bych ze to bude tvuj problem..
r_e_n_e
Re: fw 0.9.4829
no...to je sice pekne, ale co teraz?
skusil som to dat na azbox-0.9.4785-patch.bin, ale stale to ostane na SETTINGS...
Tak som vyformatoval Application area a skusam este raz dat azbox-0.9.4785-patch.bin.
Dufam, ze potom to uz pojde.
Je nejaka moznost nastavit default settings?
Alebo mate nejake riesenie.
Vdaka za odpoved.
Vdaka za odpoved.
r_e_n_e
Re: fw 0.9.4829
takze po vyformatovani AE sa mi podarilo satak rozbehat.
Len co som nastavil Slovak, tak satelit urobil to iste.
Takze vraciam na verziu azbox-0.9.4754-patch.bin a pockam si na seriozny fw, ktory bude pracovat aj zo slovenskou lokalizaciou.
No toto nejako AZBOXu nevyslo....
frcko73
- Mazák
Re: fw 0.9.4829
ved nechaj cesku lokalizaciu.....
- VraKo
Re: fw 0.9.4829
Nezaznamenal prosím někdo s Vás problémy s rebootem azboxu ? Stává se mi, že pokud musím stb rebootovat ( např. při zatuhnutí ), tak nenaběhne korektně. Naběhne do stavu, že na displeji je zobrazeno TV a na obrazovce je tma. Přitom je možné vstoupit do menu, tam je zobrazena hláška "ČEKEJTE PROSÍM" s načítacím kroužkem, který pořád načítá a načítá, ale nic se nenačte. Pokud to nechám v tomto stavu dál, tak po cca. 2 minutách se případně zobrazí ERROR -1 a nebo se box znovu sám rebootuje. Další reboot boxu nepomůže, dostane se to zase do stejného stavu. Pomůže je to, že stb tak na dvě minuty odpojím úplně od napájení a teprve potom naběhne korektně. Pozoruji to nejen na tomto posledním fw., ale i na několika předchozích, které jsem zkoušel. Má někdo podobnou zkušenost?
- visper
Re: fw 0.9.4829
Já bych zkusil takovýto postup: Továrním restartem bych smazal setting a udělal bych si jednoduchý třeba jen 3 stanice. Kdyby se to spravilo, tak bych tam natáhl zpět ten původní. Když to znova začne, tak je to tím settingem. Pokud toto nemá vliv, tak bych zkusil odpojit hardisk.
- VraKo
Re: fw 0.9.4829
Tím settingem to určitě nebude, protože již několik fw. nazpět si vždy naskenuji svůj nový čistý setting. Ten harddisk by teoreticky mohl dělat potíže ( vyzkouším ), ale stejně mi to přijde divné, protože na starších fw. jsem takový problém nepozoroval. Navíc nahrávání, přehrávání nebo kopírování po síti na interní hardisk mi funguje vždy bezchybně. Nicméně pokud zjistím, že to způsobuje připojený hardisk, co potom s tím. Není přece možné pořád při rebootu otvírat azbox a odpojovat hardisk. No uvidím.visper píše:Já bych zkusil takovýto postup: Továrním restartem bych smazal setting a udělal bych si jednoduchý třeba jen 3 stanice. Kdyby se to spravilo, tak bych tam natáhl zpět ten původní. Když to znova začne, tak je to tím settingem. Pokud toto nemá vliv, tak bych zkusil odpojit hardisk.
krokodill
Re: fw 0.9.4829
Je to naozaj zakopanej pes. Podobnou věc jsem zjistil i já, že po Rebootu to stále načítalo a načítalo v podobném stavu. Neměl jsem připojený hardisk, jen zastrčenou flašku a ta furtumpičum blikala, jako by to něco chtělo z ní. Přitom byla nově zformátovaná a prázdná. Tak jsem ji hrdě tvrdě vytrhnul a hned se box spustil
Takže něco podobného možná dělá i Tvůj hd. Ale co přesně to způsobuje - čééért ví
honza318
Re: fw 0.9.4829
Taky se mi to už několikrát stalo. Tím diskem to nebude, protože mám Elite a dělalo mi to i když byl HDD odpojenej. Moc tomu nevěnuju pozornost, protože používáme testovací verze a tak se tomu moc nedivím. Jen bych už čekal nějakej další oficiál.
- JirkaB2
Re: fw 0.9.4829
taky čekám až bude nějaký ofic, měli by ho vydat, protože 3877 už je dost starej a nemá fixnutý youtue, též čekám na increased soon foto prohlížeče (od 4.2.2008) snad tento měsíc už. Tento FW 4829 chci přeskočithonza318 píše:Taky se mi to už několikrát stalo. Tím diskem to nebude, protože mám Elite a dělalo mi to i když byl HDD odpojenej. Moc tomu nevěnuju pozornost, protože používáme testovací verze a tak se tomu moc nedivím. Jen bych už čekal nějakej další oficiál.
