Oscam pre Azbox HD
Stáhni Emu Plugin.
dempsey
Oscam pre Azbox HD
Příspěvek od dempsey »
Prvý oscam pre Az HD s dvbapi od Kanber Kav
Download OpenXCAS.tar.tgz file.
extract /EMU plugins.
module.seq file change or add AZdevCAS add line.
Restart azboxhd.
Len pre externú čítačku
Príklady nastavenia oscamu : http://streamboard.gmc.to/svn/oscam/tru ... c/example/
Pridaj cccam server do oscam.server
[reader]
label                         = Label
enable                        = 1
protocol                      = cccam
device                        = dynsadres,port
account                       = user,password
services                      =
inactivitytimeout             = 1
fallback                      = 1
caid                          =
ident                         =
group                         = 1,2,3
ecmcache                      = 1
blockemm-unknown              = 1
blockemm-u                    = 1
blockemm-s                    = 1
blockemm-g                    = 1
lb_weight                     = 100
cccversion                    = 2.0.11
cccmaxhops                    = 2
cccdisableretryecm            = 1
cccdisableautoblock           = 1
cccwantemu                    = 1
cccforceresendecm             = 0
webif
http://ip_azboxu:83
user:kkav
pass:kkav
oscam.conf
# oscam.conf generated automatically by Streamboard OSCAM 0.99.4svn build #2850
# Read more: http://streamboard.gmc.to/oscam/browser/trunk/Distribution/doc/txt/oscam.conf.txt
[global]
logfile                       = stdout
disablelog                    = 0
disableuserfile               = 0
usrfileflag                   = 0
clienttimeout                 = 90000
fallbacktimeout               = 2500
clientmaxidle                 = 120
cachedelay                    = 1
bindwait                      = 120
netprio                       = 0
clientdyndns                  = 1
resolvedelay                  = 30
unlockparental                = 1
nice                          = -1
serialreadertimeout           = 1500
maxlogsize                    = 10
waitforcards                  = 1
preferlocalcards              = 1
saveinithistory               = 1
readerrestartseconds          = 5
readerautoloadbalance         = 1
readerautoloadbalance_save    = 0
[cccam]
port                          = 17600 #cccam server port
reshare                       = 2
version                       = 2.1.4
[dvbapi]
enabled                       = 1
au                            = 1
boxtype                       = none
user                          = dvbapiuser
pmt_mode                      = 1
[webif]
httpport                      = 83
httpuser                      = kkav #webif user
httppwd                       = kkav #webif pass
httprefresh                   = 0
httpallowed                   = 192.168.2.1-192.168.2.15 #azboxip area
httphideidleclients           = 0
httpreadonly                  = 0
dempsey
Re: Oscam pre Azbox HD
2882 timeout fix.
-dvbapi ok
-timeout fix
no internal card reader.
Oscam 0.99.4 svn 2940
-support internal reader (nutne pouzit spravny typ "mode" ! )
default uzivatel - azbox
webif : port 83 , azbox/azbox
update service info all CZ/SK provider
Instalacia: Rozbalit na PC a prekopirovat do preddefinovaneho adresara . Na vsetky subory pouzite atribut 755 .
Diskutujte prosim v sekcii pre diskusiu - nie tu !!!
005jon Slovakia
Dostal poděkování: 206 poděkování
Příspěvek od 005jon »
OSCAM 0.99.4svn build #3037
-cccam server ok
-dvbapi ok
-webif OK
http://IP_Azbox:8888
meno = 005jon
heslo = 005jon
internal reader – mne nefungovala 0D0F možná budete mat viac šťastia ako ja
[reader]
label                         = azbox-internal
enable                        = 1
protocol                      = internal
device                        = 0
mode = 3
services                      = cslink
caid                          = 0D0F
detect                        = cd
mhz                           = 500
cardmhz                       = 357
ident                         = 0D0F:000000
group                         = 1
emmcache                      = 1,1,3
ecmcache                      = 0
blockemm-s                    = 1
blockemm-g                    = 1
lb_weight                     = 100
mode = 115
Inštalácia z USB
Rozbaľ *rar nachádzajú sa tam dva súbory ( oscamCAS.tgz + Camd.lst )
Ulož na USB a inštaluj
cslu
Příspěvek od cslu »
oscam.0.99.4.svn2925 crw ok
vikino Ukraine
Dal poděkování: 9 poděkování
Příspěvek od vikino »
OscamCAS 1.1
-nakopirovat do OpenXCAS a zmenit vsetky atributy na 755
emilb Czech Republic
Příspěvek od emilb »
oscam 2925 pro kontrolu a prochazeni zapisu na ICE (nacte kartu jen kdyz je spousten v rezimu debug 255 - v openxcas.conf radek daemon = oscam -d 255)
web je na portu 8888, bez hesla...
v baliku je i mgcamd 1.35a prednastaven na posilani zapisu
pro bezny provoz to neni - dlouhe prepinani programu a obcas zakodovano...
zkouseno na fw 5306 na USB na elite
X-Trend ET9000
dempsey
Oscam AZBox 1.20-Rev.6339 Compiled by Arbabe
-Changeset [6339] by Admin
Fix stapi compile without cardreader.
-Changeset [6338] by oopepe
SC8in1: * fix for overclocked card slots
For opensat firmware:
-In folder OpenXCAS is present file module.seq, need edit it
if you use others emu, remember to use symbol
# before the names of non-active emu
-In folder OpenXCAS/oscamCAS are present openxcas.conf
and others are only exemple files
-In folder OScam 1.20 is present new oscam file
to put in /PLUGINS/OpenXCAS/oscamCAS with chmod 755
-Details in Info file
Zpět na „Emu pluginy“
