Firmware Ariva200
Zde naleznete firmware.
blackie2
Firmware Ariva200
Příspěvek od blackie2 »
Nový firmware 15.1.2010
maincode 1.04B2
Code:
* Subscription status for Conax and Irdeto cards
+ First improvement of handling frequency 10719
Legend:
* New feature
+ Improvement
! Software change requires modification of your configuration
x Bugfix
- Information only
* A200_1.04B2_patch
Quote:
- The amendment as firmware manufacturer cut 10,719 more times but a lot less ...
- Amendment AU DigiTV (you enter the 11,785 to 0.8 W Thor wait about 1 min on any of the encrypted channels possibly change the channel),
- Improved handling nagra3 in newcamd.
A200_20100115_1.04B2_patch.zip
A200_20100115_1.04B2.zip
blackie2
Re: Nový Firmware Ariva200
Firmware Ariva 200HD 25.1.2010
What's new? Ferguson Sp. z o.o.
Legend:
* New feature
+ Improvement
x Bugfix
- Information only
Revision history: ------------------------------------------------------
maincode 1.04B3
x AC3 support fix
A200_20100121_1.04B3_patch.zip
A200_20100115_1.04B3.656.zip
whisky
Příspěvek od whisky »
fA200_1.04B4.zip
maincode 1.04B4
x Reboot trouble in media player
+ Second improvement of handling frequency 10719
http://www.ferguson-digital.eu/en/downl ... lect&id=95
Prechazel jsem z02, mel sem zalohu sett, nahral a v pohode funkcni.
SAT prijem bez problemu. Nahravani zatim netestovano.
U mp3 zobrazi jen 100 položek, vic ne kdyz jich mate na disku vic, adresare, soubory.
blackie2
FW-Ariva 200 1.04B4, 1.04B4_patch
maincode 1.04B4
A200_20100127_1.04B4.zip
A200_20100127_1.04B4_patch.zip
blackie2
Citace z pl stránek:
Soft na bazie producenta, żadnych zmian w emu+sharing.
kolejne poprawki z zacinkami na transporderze 10719.
A200_20100208_1.04B5.zip
A200_2010.02.08_1.04B5_patch.zip
furko Slovakia
Dal poděkování: 5 poděkování
Příspěvek od furko »
A200_20100323_1.04B8
maincode 1.04B8
x descrambling conax MTV Unlimited card in CA
x radio station names
+ volume speed
+ several audio track recording !!!
x accuracy of the manual clock settings
x regional channel switching for ORF provider
+ EPG autoupdate in weekly mode
* new DVR option: default record duration time
* new DVR option: receiver behave after timer record
* volume control over picture in graphic
* edit: bit rate and service ID display
* moving several channels simultaneously
- new options OSD translations will be done in next version
maincode 1.04B8_patch
wersja z emu i sharingiem
- dodano serwer NewCamd
- emu C+ NL z Irdeto2
furko Slovakia
A200_20100326_1.05B0
maincode 1.05B0
* Pridaná podpora pre DDNS
* Vypnutý USB disk s hodinami ON v pohotovostnom
x reboot problémy stlačením EDIT odstránené
x pevné merače pracovať s hodinami v pohotovostnom režime OFF
x obnovovacou bit rate
x schopnosť aktualizovať s FTP.
+ Pridaná podpora pre Viaccess 4,0 karty SSR / SRG
+ OSD preklady
bery2
Re: Firmware Ariva200
Příspěvek od bery2 »
maincode 1.05B1
odstraněn problém restartu po výpadku proudu.
furko Slovakia
A200_20100507_1.05B5
maincode 1.05B5
* added Lithuanian language OSD
+ Czech OSD translation changes
* SKY.de card support in CA
x channel descrambling by CI (eg Nickelodeon)
x reactivation of Seca cards
+ Polish teletext fonts on Canal +
x channels Audio/Video synchronization after long time
+ eliminate cracks in the digital audio outputs
x front panel POWER/Restart when switched on the clock in standby
x restoring the names of the favorites groups
- various bug fixes & patches for the main core
bery2
EMU FW
Elektronek
Příspěvek od Elektronek »
Ariva 200 2010.09.10 2.01B5
TESTOVACI VERZE, instalujete na vlastni riziko!
Velice doporucovano jest provest po nahrani TOVARNI NASTAVENI a znovu NALADIT kanaly.
Jinak lze ocekavat problem se zvukem, sekani a pod...
Zamerne prikladam orig. popis (prelozit pomoci prekladace, z ktereho vylezou blbosti muze kazdy sam)
U video formatu zalezi na pouzitem kodeku atd.. chce si to s tim pohrat/vyzkouset.
Pro jistotu mejte po ruce RS232 kablik :mrgreen:
changelog:
* New feature
+ Improvement
x Bugfix
- Information only
Revision history: ------------------------------------------------------ //
maincode 2.01B5
- Initial release of v2
Software version V2 brings up new funcionality:
1. Shoutcast based internet radio service.
Internet radio playback depends on network connection speed
and stability.
Note that some of servers can be full when trying to access
them, in this case radio will not be played. The maximum number of
simultaneous listeners allowed depend on server settings.
2. Recognized multimedia file extensions are listed below.
Not all files with those extensions are playable - some files may
include not supported codecs and/or settings (for example divx).
- Audio files: mp1, mp2, mp3, mp3 Pro, ogg, flac, wav (PCM only)
- Video files containers: avi, mkv, mpeg, mpg, ts, mp4, dvr (the default recordings format)
|-> video codec supportet in containers: H.264 (up to 8 RF)
|-> audio codec supported in containers: mp3, aac, ac3
- Images files in formats: bmp, jpeg, jpg
AZBox HD Premium|RTi Core v1.5.3 Enigma 2
Zpět na „Download firmware - Ferguson Ariva HD“
