Black Hole Clarke Tech ET-9000 v. 1.4.3 OE-BH 1.6
Specifications:
- Drivers et9000 12. 1. 2011
-support 1080p24/25/30 and 3d resolutions
-use deinterlacer
-vfd improvements (show various symbols, use slower scroll speed)
-accelerated alpha blending
- skin: Army Gradient
- extra plugins osd
dvb-t full BlackHole support
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.
The image MUST be installed in the flash.
Black Hole can not support images not installed in the flash.
This latest version of the Black Hole series has been entirely rewritten and improved in the code for maximum stability and performance.
Please note that of all images Black Hole now has the best epg system:
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Community members can then download it from our servers.
This feature provides other benefits such as:
Increase download speed of EPG
Download EPG from any channel
Schedule the download of EPG decoder even during standby
Users can customize the providers using Add / Remove function
Main functions of the buttons on the remote
OK button = Skin with simple information
OK button x 2 = Extra Info Skin
Blue button = Black Hole Blue Panel
Blue button and then Red button = Black Hole Epg Panel
Blue button and then Yellow button = System Monitor Panel
Blue button long press = Extensions
Yellow button = Time Shift
Green button = Black Hole Green Panel
Green button long press = Subservices
Green button and then Red button = Fast Plugin Setup
Green button x 2 = Fast Plugin
Button Red = Start Record
Addons
Green button and then Yellow button takes you to:-
Dedicated server for BlackHole addons
Download and install additional packages from the Black Hole server
Infobar / OSD
Analog Clock Enigma2
Channel orbital location
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, BER
Infobar picons
Characteristics of BlackHole Panels
Blue Panel
Extra Settings
Black Hole Cron Manager (Manage schedules)
OSD Settings (OSD configuration)
Manager Kernel Modules (Kernel module operator)
Inadyn Settings (Configure Inadyn)
Swap File Settings (Configure File Swap)
Hard Disk Settings (Configure Hard Drive)
Black Hole Mount ****** (Mount points)
OpenVPN Panel ( OpenVPN Panel)
Samba / CIFS Panel ( Samba Panel)
NFS Server Panel ( NFS server Panel)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
Info Panel
1 - E2 Setting (Enigma2 configurations)
2 - Service Information (information system)
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Global settings (global settings EPG)
Setting Provider (ISP settings)
Green Panel
Fast Plugin Setup (Configure quick access to your favourite plugin)
Fast Plugin (Access your favourite plugin)
Addons (added)
Addons Download Manager (Manager for package downloading)
Installation manual packages (Manual installation of Black Hole packages)
Manual Install IPK packages (Manual installation of IPK packages)
Addons Uninstall Panel (Uninstalled packages)
Black Hole Statistics (See connections, top downloads and more)
Credits
Thanks to the group of Beta Testers.
Thanks to Rytec for providing us with the server with all epg.dat files.
Thanks to MaxZ4 for Integrated EPG loader.
Thanks to Lukkino (VDR-Italy) for the source code of OpenTV.
Thanks to Reinh@rd for the file satellites.xml.
DISCLAIMER
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE
PUBLISHED BY CT AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR IILEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
THE BLACK HOLE IMAGE IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY AND THAT IT WILL ONLY BE USED FOR LAWFUL PURPOSES.
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REWOKE OF THIS LICENSE.
Download: BlackHole-1.4.3-et9000-20110113154337_usb.zip
Black Hole Image
vikino
vikino
Re: Black Hole Image
Black Hole 1.6.4a Full Hdmi-Cec - XTREND ET9000
Tento image nie je zrejme oficialnym image-om od teamu BH pre et9000, ale funguje.
m. info:
- drivers su z 27.6.2011
- kernel 2.6.18-7.4
YOU MUST TO HAVE LATEST BOOTLOADER !!!
What is new in 1.6.4a?
- Fixed GreenScreen on CrossEPG
- Initial relase for ET9000 - VFD ALSO WORKS OK !!!
What is new ?
The new Black Hole Hdmi-Cec driver allow you to command two devices (Tv and Vu+ box) with only ONE Remote control (Tv remote control)
Not all television are compatibile with this funcion, as for example Panasonic seems to be not yet compatible with Bh Hdmi-Cec.
But Bh Hdmi-Cec is tested and report working on all latest Samsung(Anynet+), Philips and and other Tv models like Sony Bravia KDL40EX402 series.
But we cannot test all tv recent models, so please help us reporting your tests too with your television model.
Instructions to connect the box to your Hdmi-Cec compatible Tv:
1) Enter in your Tv Menu Options and enable all the Hdmi-Cec options.
2) Enter in your Vu+ box Black Hole Hdmi-Cec Panel Setup (blue->blue->Black Hole Hdmi Cec: Configure in this screen the right Hdmi connection port and enable Bh Hdmi-Cec.
3) Click Save (red) button and your box will try to connect with your Tv.
All Done. If your Tv is compatible you can now control Tv and Box with Tv rc.
Warning: You have to select the specific port option if your box is connected to an ampli.
Download
http://www.multiupload.com/791MRSFA97
m. info:
- kernel 2.6.18-7.4
What is new ?
Credits
DISCLAIMER
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REWOKE OF THIS LICENSENemáte oprávnění prohlížet přiložené soubory.
vikino
Black Hole 1.6.5 Full Hdmi-Cec - XTREND ET9000
Podobne ako predchadzajuca verzia 1.6.4a, tak ani tento image nie je officialnym produktom teamu BlackHole...
What is new in 1.6.5?
New Skin Beyounce 14 by Matrix 10
- MEDIATOMB updated to ver. 0.12.1
- NTFS-3G updated to ver. 2011.4.12.
- OpenVPN updated to ver. 2.2.1
- VsFTPd updated to ver. 2.3.4
- Dropbear updated to ver. 0.53.1
What is new ?
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Black Hole HDMI Cec
Manager Kernel Modules (Kernel module web browsertor)
Black Hole Mount Wizard (Mount points)
Usb Tuner Panel
UPnP Client Djmount
UPnP Server Mediatomb
Info Panel
1 - Gui Setting (Gui configurations)
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
Thanks to Sandro Cavazzoni for Cross EPG
Thanks to bigroma (vuplus-community board) for rt3070 patches.
DISCLAIMER
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
Download
What is new ?
Warning: You have to select the specific port option if your box is connected to an ampli.The image MUST be installed in the flash.
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Black Hole HDMI Cec
Usb Tuner Panel
UPnP Client Djmount
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
DISCLAIMER
Download
vikino
Re: Rôzne images
Openblackpole et9x00 private kernel 3.3.0
blackpole-version-private-et9x00.zip
thx loulou2000loulou2000 píše:hello, for those traveling on wheels they test the openblackpole, I have for some time, I can tell you is what is very stable, évidamment I have changed the sources of enigma2 and added sources openplie compiled for the image, there just bootlogo I left the original
