EGAMI team image
vikino
EGAMI team image
Egami - 1.0 - et9000
Overview:
- Image based on Oe 1.6
- Kernel 2.6.18-7.4
- Drivers 16.05.2011
- Most of USB Wifi Dongles should works
- Most of USB Tuners - DVB-C / DVB-T / DVB-S2 should works - UP to 2 dongles !
Installed Plugins:
- HDMI-CEC Support
- BLIND SCAN Support
- Web Interface
- MyTube Player
- FAN Setup
- OSD 3D Setup
- OSD Position setup
- Cross EPG SVN 300
Buttons Mapping:
OK button = LITE SKIN ( need to be turned on on GREEN PANEL -> EXTRAS -> OSD SETTINGS )
OK button x 2 = Extra Info Skin
Blue button = EGAMI Blue Panel
Blue button and then Yellow button = INFO Panel
Blue button and then Blue button = EGAMI Settings
Blue button long press = Extensions
Yellow button = Time Shift
Green button = EGAMI Green Panel
Green button long press = Subservices
Green button and then Red button = ADDONS
Green button x 2 = EGAMI Settings
Green button and then Yellow button = FILE MANAGER
Green button and Blue button = SCRIPTS
Button Red = EPG List
Button PIP = Turn ON / OFF PIP
Button PIP long press = PiP Menu - Move/Switch Windows
Infobar:
- CAM Name
- ECM INFO
- NETCARD INFO
- CA INFO
- TUNER INFO
- CHANNEL INFO
- NEXT EVENT INFO ( in channel list !! )
- AnalogicClock renderrer
- Lite and Full infobar skin
much, much and more...
Egami Panel include:
- Green button and then Red button takes You to EGAMI ADDONS MANAGER
--> Download Egami Addons - Download extensions from Egami Server
--> Manual Egami Addons Install - Install packages from /tmp
--> Remove Egami Addons - Remove installed packages
--> Download GUI Addons - Download CVS Extensions
--> User Addons - Here You can install extensions from Your own server ( put in /etc/user_addon.txt url to catalog: example: http://..... )
- 2x Green button takes You to EGAMI Extras
--> Kernel Modules Manager - start/stop kernel modules
--> Devices Manager - here You can easily mount/map/format/settings Your extra memory storages like HDD, USB. REMEMBER TO MOUNT HDD BEFORE RECORDING !!!
--> Services Panel - here You can Start/Stop/Check Status/Setting up:
+ NFS Server
+ HTTPD
+ Inadyn
+ Cron
+ DjMount ( UpNp Client )
+ uShare ( UpNp Server )
+ Syslog
+ Samba
+ OpenVPN
+ FTP
+ Telnet
+ Pcscd
--> Mount manager - here You can mount Your networks share - CIFS/NFS
--> Decoding Setup - You can disable some messages like eg. "Show Tune failed info?"
--> Swap File settings - make Your swap file
--> OSD Settings - Here You are able to Turn ON / OFF options like: Lite Skin, Orbital position, cam name, provider, crypt info in Infobar, Pernamental Clock, Picons and much much more...
--> Stream Information - Get PAT/CAT/NIT/EIT/ECM Info
--> USB Wifi & Tuner Dongles Setup - in this panel You can easily see what kind of Wifi or Tuner ( DVB-c/t/s2 ) you have connected to box and load drivers. The most complete info ever: Manfacturer, Vendor ID, ProID
- Green button and then Yellow button run EGAMI FILE MANAGER
--> You can Move/Copy/Remove/Rename Your files inside Your Box !
--> You can Create New Directory/New Text File/New Symlink !
--> You can change Permission of the files !
--> You can play all movies and music directly from Egami File Manager !
--> You can watch Your pictures from holiday directly from Your USB dongles by Egami File Manager !
--> You can start SHELL scripts
--> You can start PYTHON scripts
--> You can view most type of files by pressing OK
--> 1st EVER - You can download Subtitles to Your movies stored inside your HDD - it finds subtitles exacly to version of the movie You have ! - available languages - ENGLISH, POLISH - more will come SOON...
- Green button and then Blue button run EGAMI Scripts Panel
--> You can run all scripts from /usr/scripts/
--> You can easily add new scripts to /usr/scripts/NAME_smartscript.sh and it will be visible in Scripts Panel
Credits
Thanks to the group of Beta Testers.
Thanks to Rytec for providing us with the server with all epg.dat files.
Thanks to SiF Team for the nicest EPG plugin ever - CrossEPG
Thanks to Skaman from SiF Team for extuner and usbloader
DISCLAIMER
THE EGAMI IMAGE IS BASED ON THE OFFICIAL FIRMWARE PULBISHED BY XTrend AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
THE EGAMI IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
LASTLY, THE EGAMI IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
THE EGAMI IMAGE IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY AND THAT IT WILL ONLY BE USED FOR LAWFUL PURPOSES.
ANY CHANGES OR ADDITIONS TO EGAMI IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REWOKE OF THIS LICENSE.
DOWNLOAD
thx Egami Team
Overview:
- Kernel 2.6.18-7.4
Installed Plugins:
- HDMI-CEC Support
- Web Interface
- MyTube Player
- FAN Setup
- OSD 3D Setup
- Cross EPG SVN 300
Buttons Mapping:
Infobar:
- CAM Name
- ECM INFO
- NETCARD INFO
- CA INFO
- TUNER INFO
- CHANNEL INFO
+ NFS Server
+ HTTPD
+ Inadyn
+ Cron
+ Syslog
+ Samba
+ OpenVPN
+ FTP
+ Telnet
+ Pcscd
Credits
DISCLAIMER
DOWNLOAD
thx Egami Team
vikino
Re: EGAMI team image et9000
EGAMI 1.1 ET-9000
Overview:
- Image based on OE 1.6
- Kernel 2.6.18-7.4
- Drivers 27.06.2011
What's new ???
- Image include latest Front Processor
- image include latest Bootloader
- Latest Drivers
-increase framebuffer acceleration memory size
-always downmix audio on analog outputs
-support /proc/stb/fp/was_timer_wakeup (needs frontpanel update)
-vcr scart detection fix
-vfd improvements
-vfd: support greek and cyrillic charsets
-vfd: support additional symbols (see /proc/stb/lcd/*)
-pcm playback improvements
-sci improvements
-DVD Menu works OK - from ISO files also
- Latest GUI
- Latest GUI-Plugins
- Added AC3+ / Dolby Digital + Support
- Added zapUp /zapDown -> LEFT / RIGHT arrow
- Added default cable.xml - thx pr2
- Added in FileManager option to play file by file -> most types of mulimedia files ( e.x 001.mts, 002.mts, 003.mts - You don't need to play one by one, it will be play from 1-3 )
- Added in File Manager < Root Directory > to make fast jump to / direcotry in Flash
- Added in Mount Manager option to mount by UDP and TCP
- Added animated pixmaps when We press RED to start CAM
- Added in Decoding Setup -> Option to disable CI messages
- Added Subtitles Menu on Subtitiles Button
- Added Sleep Timer Menu on Timer Button
- Added *.MTS extensions in MediaPlayer
- Added Videoenhacement Plugin
- Added EGAMI BackUp Manager -> You can backup/ restore EGAMI - You can install new egami, run this plugin and it will install things like emu, configs, plugins, etc...
This tool allows You to flash by latest EGAMI Image but Keep Your favorite things inside !!!
- Updated skin by Mimi
- Updated French language by Mimi
- Updated French language CrossEPG by Mimi
- Fixed removing files from FLASH by EGAMI File Manager
- Fixed Software Manager -> Install Local IPK
- Fixed Marker
- Fixed Button SAVE in FileManager Settings
- Fixed Uninstaller SoftCams fixes ( killing before removing, if running softcam is removed, fall back to Common interface mode, if user remove other softcam, running softcam is still running )
- Fixed SoftCams change- it is 2 times faster now
Installed Plugins:
- HDMI-CEC Support
- Videoenhacement Plugin
- Web Interface
- MyTube Player
- FAN Setup
- OSD 3D Setup
- Cross EPG SVN 300
Buttons Mapping:
Infobar:
- CAM Name
- ECM INFO
- NETCARD INFO
- CA INFO
- TUNER INFO
- CHANNEL INFO
--> User Addons - Here You can install extensions from Your own server ( put in /etc/user_addon.txt url to catalog: example: http://your-feed-url.com/catalog_enigma2.xml )
+ NFS Server
+ HTTPD
+ Inadyn
+ Cron
+ Syslog
+ Samba
+ OpenVPN
+ FTP
+ Telnet
+ Pcscd
Credits
DISCLAIMER
Download
Egami v1.1 Final
Overview:
- Kernel 2.6.18-7.4
What's new ???
- Latest Drivers
-vfd improvements
-sci improvements
- Latest GUI
- Fixed Marker
Installed Plugins:
- HDMI-CEC Support
- Web Interface
- MyTube Player
- FAN Setup
- OSD 3D Setup
- Cross EPG SVN 300
Buttons Mapping:
Infobar:
- CAM Name
- ECM INFO
- NETCARD INFO
- CA INFO
- TUNER INFO
- CHANNEL INFO
+ NFS Server
+ HTTPD
+ Inadyn
+ Cron
+ Syslog
+ Samba
+ OpenVPN
+ FTP
+ Telnet
+ Pcscd
Credits
DISCLAIMER
Download
vikino
EGAMI 1.2 ET-9000
Overview:
- Kernel 2.6.18-7.4
What's new ??? in v 1.2
- EGAMI Backup Panel - now you can have severals backup of the EGAMI Image on severals connected devices to your STB - all backups are dated - so when you will make backup it will have new format:
20110712_EGAMI_Backup.egi
- Egami Backup Panel -> When user makes backup - it is named like: DATE_Egami_BACKUP.egi
- Egami Backup Panel -> Support for more than one backup on connected devices - user can choose which Backup he wants to restore
- Egami Backup Panel -> Fixed Restore/Backup MultiQuickButton and CrossEPG ( About CoolEPG Restore - not done, because it install converters, it is not suitable to make for each plugin special backup logic )
- Also you can choose which backup you want to restore by moving UP/DOWN and after choose pressing BLUE button
- Added text to inform user to press OK to reboot after Restore
- Added default picon turned on as Reference read from /media/hdd/picon
- Fixed user Add-on
- Some Blue Panel skin improvements ( now it is listbox, not any more config )
- Some Blue Panel emu list changes
- Samba conf workgroup changed to "workgroup" as a default
Download
Overview:
- Kernel 2.6.18-7.4
- Fixed user Add-on
Download
vikino
EGAMI 1.3 ET-9000
Overview:
- Kernel 2.6.18-7.4
What's new ??? in v 1.3
- Improved OSD info in Infobar for OSCam
- Improved HDMI-CEC driver ( thx to openstb git owner ) - now it is fully working HDMI CEC
- Improved EGAMI File Manager - now it corretly PLAY .VOB files, some of them need to be PAUSED and then RESUMED to get playing...
- Fixed WebInterface ( movie list )
- Fixed some "greenscreens" in File Manager
- Fixed MyTube
- Added EgamiBoot 1.0 - multiboot plugin
- Added Image version info in Menu->Informations->About
- Added Image version info on Bootlogos Installed Plugins:
- HDMI-CEC Support
- Web Interface
- MyTube Player
- FAN Setup
- OSD 3D Setup
- Cross EPG SVN 300
Buttons Mapping:
Infobar:
- CAM Name
- ECM INFO
- NETCARD INFO
- CA INFO
- TUNER INFO
- CHANNEL INFO
--> User Addons - Here You can install extensions from Your own server ( put in /etc/user_addon.txt url to catalog: example: http://your-feed-url.com/catalog_*******.xml )
+ NFS Server
+ HTTPD
+ Inadyn
+ Cron
+ Syslog
+ Samba
+ OpenVPN
+ FTP
+ Telnet
+ Pcscd
Download
Overview:
- Kernel 2.6.18-7.4
- Fixed MyTube
- HDMI-CEC Support
- Web Interface
- MyTube Player
- FAN Setup
- OSD 3D Setup
- Cross EPG SVN 300
Buttons Mapping:
Infobar:
- CAM Name
- ECM INFO
- NETCARD INFO
- CA INFO
- TUNER INFO
- CHANNEL INFO
+ NFS Server
+ HTTPD
+ Inadyn
+ Cron
+ Syslog
+ Samba
+ OpenVPN
+ FTP
+ Telnet
+ Pcscd
vikino
Egami 2.0 Venton HD1 Image
egami-2.0-venton-hd1-image
nagelneues Image für die Cybox HD1:
3rd Party 2.0 CYBOX
OverviewImage
based on OE 1.6
- Kernel 2.6.31-3.2
- Drivers ?
What's new ??? in v 2.0
-Move to OpenPLi source tree ( Thank You PLi TEAM )
- Move to Kernel 2.6.31-3.2
- New device manager- Fast Scan
- Cable Scan
- MultiBoot 2.0 ( support USB, HDD, eSATA HDD)
- Support UBIFS images ( ET9x00, ET6x00, VUDUO, VUUNO )
- Support for NFI images ( DM800se, DM7020HD - up to enigma v3.1 free one!)
- Updated default skin
Installed Plugins:
- HDMI-CEC Support
- Web Interface
- MyTube Player
- FAN Setup
- OSD 3D Setup
- Cross EPG
- Weather Plugin
-ZDF Mediathek
- WebMedia
Image fungujuci na et9000, test OK. Offico podpora Egami teamu pre et9000 skoncila...
Sťahuj tu klikni
3rd Party 2.0 CYBOX
OverviewImage
based on OE 1.6
- Kernel 2.6.31-3.2
- Drivers ?
- Cable Scan
Installed Plugins:
- HDMI-CEC Support
- Web Interface
- MyTube Player
- FAN Setup
- OSD 3D Setup
- Cross EPG
- Weather Plugin
-ZDF Mediathek
- WebMedia
vikino
EGAMI v3.0 opensource by loulou2000 (neoficialne!)
drivers: bcm7413-2
image: experimental
kernel version: 3.6.0
GUI: 2012-12-24
Last upgrade: 3.0
Tu stiahni egami 3.0 opensource
drivers: bcm7413-2
image: experimental
GUI: 2012-12-24
Last upgrade: 3.0
vikino
vikino
image magic-merlin base egami
-20130513
-news image magic-merlin base egami 3.0 ,kernel 3.8.7,multiboot
thx loulou2000
Tu stiahni magic-3.0-et9x00 z 13.5.2013
-20130513
thx loulou2000
vikino
-warning update version all et9x00 20130520
thx loulou2000
Tu stiahni magic-3.0-et9x00 z 20.5.2013
thx loulou2000
vikino
-update 20130524
thx loulou2000
Tu stiahni magic-3.0-et9x00 z 24.5.2013
-update 20130524
thx loulou2000
vikino
image magic-merlin base egami 08.08.2013
[code]warning in picture no longer install the dream image, because the binary nfidump to need a permission from the author, I just deleted nfidump my source if you want to install an image of dream it will recover nfidump2 binary and rename nfidump magicboot and transfer in / bin with chmod 755, the rest of his alter[/code]
[code]http://e-nautia.com/loulou2000/disk?f=1269105
Here the list of ipk for et9x00 and et6x00.
you SEVERAL solution is to use the ipk you unzip the package and install the ipk you want manually or unzip to the root of the hard drive and you use software that is created virtually an http server and provides access to the list ipk directly on the usual list
tutorial
selected menu, choose the directory where et9x00 et6x00 or et5x00 or et4x00 and here and your server is ready[/code]
[code]tar xzf /tmp/serveur-local-ipk.tar.gz[/code]
[code]then installed the server-local-ipk.tar.gz package in your etxx00 and changed the IP and inserted the local ip of your pc in the file located in / etc / opkg his concerns only file that is ip 192.168.1.224 the rest untouched[/code]
thx loulou2000
Tu stiahni magic-3.0-et9x00-20130808
tutorial
thx loulou2000
