oscam mi prestal dekódovať
peterg-77
Dnes mi prestal oscam dekódovať bez toho, že by som čokoľvek manil v nastavení môjho et9000. Idú mi len nekódované kanály. Log oscamu hovorí toto (pre STV1):
2013/04/09 18:40:50 77901E38 c dvbapi: [ADD PID 0] CAID: 0D03 ECM_PID: 045B PROVID: 000000
2013/04/09 18:40:50 77901E38 c dvbapi: [ADD PID 1] CAID: 0D70 ECM_PID: 0465 PROVID: 000000
2013/04/09 18:40:50 77901E38 c dvbapi: [ADD PID 2] CAID: 0D0F ECM_PID: 046F PROVID: 000000
2013/04/09 18:40:50 77901E38 c dvbapi: [ADD PID 3] CAID: 0D96 ECM_PID: 0479 PROVID: 000000
2013/04/09 18:40:50 77901E38 c dvbapi: [ADD PID 4] CAID: 0624 ECM_PID: 0483 PROVID: 000000
2013/04/09 18:40:50 77901E38 c dvbapi: [ADD PID 5] CAID: 0666 ECM_PID: 048D PROVID: 000000
2013/04/09 18:40:50 77901E38 c dvbapi: Found 6 ECMpids and 4 STREAMpids in PMT
2013/04/09 18:40:50 77901E38 c dvbapi: New program number: 13F1 (0D03:13F1 unknown) [pmt_list_management 3]
2013/04/09 18:40:50 77901E38 c clarke tech (0D96&000004/0000/13F1/80:7A0568C7734C8C2F4E8786C59556664D): not found (163 ms) by horna
2013/04/09 18:40:50 77901E38 c clarke tech (0D0F&000004/0000/13F1/7C:00000000000000000000000000000000): rejected caid (0 ms) (0/0/0/0) (invalid caid 0x0D0F)
2013/04/09 18:40:50 77901E38 c clarke tech (0D96&000004/0000/13F1/80:7A0568C7734C8C2F4E8786C59556664D): not found (0 ms) by horna
2013/04/09 18:40:51 77901E38 c clarke tech (0D96&000004/0000/13F1/80:7A0568C7734C8C2F4E8786C59556664D): not found (1 ms) by horna
2013/04/09 18:40:51 77901E38 c dvbapi: ERROR: Can't decode channel
2013/04/09 18:40:51 77901E38 c clarke tech (0D0F&000004/0000/13F1/7C:00000000000000000000000000000000): rejected caid (0 ms) (0/0/0/0) (invalid caid 0x0D0F)
Doteraz mi išla staršia verzia oscamu (1.20 unstable verzia 5niečo), teraz som skúsil aj 8333, stále rovnako. Nie sú mi úplne jasné zápisy na karte, ale je ich tam 23 a všetky majú start date 8.4.2013 a sú platné do 8.5.2013, takže by asi mali byť ok. Poraďte, prosím.
peterg-77
Re: oscam mi prestal dekódovať
Tak som to aj nakoniec vyriešil - v oscam.dvbapi som mal P:0D96, P:0D97 1 a potom I:... Vyhodil som P:0D97 1 a jednotku som dal k 0D96. Nechápem, prečo to doteraz takto chodilo. Ak mi niekto dá vysvetlenie, budem rád.
vikino
Tiez mi oscam prestal dekodovat programy zo sky-linku. Nepouzivam v nom oscam.dvbapi. Mam ho nastaveny po svojom a myslim, ze spravne. Na karte boli zapisy az do 8.5.2013. Oni pani v sky-linku sa zase hrali s niecim, s cim si oscam nevie bezne rady...
Prepol som z oscamu na chvilku na cccam 2.3.0 bez cccam.cfg a karta sa za chvilku chytila. Vratil som na oscam a karta bezi stale.
- streethawk
Ahoj "vikino" a prečo nepoužívaš Cccam 2.3.0 stále? Funguje v pohode...ja na ňom frčím stále...
ZDAR...
ZDAR...
Xtrend ET-10000 (3 x DVB-S2 tuner + DVB-T2/C), OpenPLI, parabola Gibertini 105cm, LNB Inverto Unicable, motor DG240, Seagate 3TB, TV Panasonic 55st60E, BD Player Panasonic BD500
vikino
cccam je velmi jednoduchy, radsej mam oscam
torin
Tiež v tom čase mi šlo len TA3 a CT24. Pomohol až restrart enigmy. Ako to sledujem tak takéto problémy sa dejú čoraz častejšie.
Xtrend ET 9500_Hdd: WD 10EADS-00L, 1TB "3,5"_TV-Panasonic TX-P50G30E
ondrej9
Vysvetlenie je tu: http://www.................cz/zpravicky/19133/skylink-vcera-provedl-dve-zmeny-v-kodovani/
OSCAM sa správa tak, že ak po zmene kľúčov zapneš pjijímač a nemá ich správne tak nedekóduje, ale ani sa nesnaží ich načítať. Riešenie je napísať do oscam.dvbapi P:0D96 1 , vtedy čaká na príchod nových kľúčov, ktoré hneď aj zapisuje na kartu.
Pri zmene kľúčov boli posielané každé 3 min, postupne sa tento interval predlžoval. Najistejšie je poslať si reautorizáciu karty cez ich web.
Naposledy upravil(a) dempsey dne 10 dub 2013, 20:02, celkem upraveno 1 x.
Důvod: Prečítaj si pravidlá fóra a neporušuj ich
Xtrend ET 10000 Pli, HDD Western Digital 2TB, Toroidal 90, LG 50PV350
- dempsey
Tá správa je hlúposť a obyčajná výhovorka.
Jednalo sa o zmenu op klúča ktorým sa shitlink pokúša eliminovať zneužívanie chyby na kartách, ktorá zase umožňuje príjem promo ponuky aj tým klientom, ktorí si ju nepredplatili a to zakázaním prístupu oprávnení na kartu.
Zmenou op klúča chcú donútiť klientov povoliť oprávnenia, čím sa zmažú povodné, ktorých oprávnenie - tou chybou na kartách ICE - fungovali na pôvodný op klúč.
Problém je v tom, že pri tejto zmene majú problém s zapísaním nových dát na kartu aj pseudocertifikované prijímače, ktoré sú v stanby režime a vlastne sa správajú ako keby bol na nich použitý tzv. bloker. To dokazuje ako biedne je celý systém nastavený a aj fakt, že certifikovaný prijímač vôbec neni zárukou bezproblémového príjmu shitlinku o ktorom sa práve na Tebou uvedenom komerčnom webe snaží presvedčovať shitlink svojimi platenými promo článkami. Fuj....
Bol by som veľmi rád aby si dodržoval pravidlá fóra a to hlavne tie ktoré hovoria o odkazoch na komerčné fóra, preto že Tebou spomínané je najkomerčnejšie, najneobjektívnešie a zároveň najviac cenzúrované fórum v bývalom československu a to hlavne kôli svojmu najväčšiemu inzerentovi, ktorým je samotný shitlink.
ondrej9
V poriadku. Len veľakrát sa nikde nedozviem pravú odpoveď. Ľudia, ako Ty, veci znalí, sú skúpi na slovo o problematike. Preto ďakujem za vysvetlenie.
