Homesharing
dreamb
Homesharing
Pokiaľ to nie je porušenie pravidiel tohto fóra, chcel by som sa opýtať na homesharing. Chcel by som k 9200-ke pripojiť cez LAN dreambox 7000-ku. Poprosil by som o radu ako to nastaviť, ďakujem.
Naposledy upravil(a) dempsey dne 11 dub 2013, 21:23, celkem upraveno 1 x.
Důvod: Upravil som trochu názov a text
Dreambox DM900 RC20 UHD (tuner A-usals,tuner B-pevna 23,5E), parabola 2x 110,SG2100,plazma Panasonic-42",SkyLink+CSLink.
Re: Homesharing
Dreamsky 7000/7500 funguje len v newcamd protokole.
Tzn. v CT vytvoríš newcamd server viewtopic.php?f=289&t=7146
a v Dreamsky klienta v newcamd protokole viewtopic.php?f=88&t=2825
8. Dreamsky Ethernet Sharing
a) After factory default, Enable Patch. and make sure the RS45 small board embeded.
b) Searching channels.
c) Press INFO+2: and Select Ethernet CSC
d) Go to Main Menu-->Timer Setup-->IP Setting
In this menu, you can set the IP Address etc..., if the IP-Address is 0.0.0.0. It will get the IP automatically.
e) Go to Main Menu-->Timer Setup-->Server Setting.
In this menu, you can input the server by manul. After input the server, it will automally login the server and display
the server information at the bottom.
dreamb
Re: Homesharing
Dempsey, ďakujem za úpravu aj radu, vyskúšam.
Re: Homesharing
Mal si na mysli dreambox alebo dreamsky? Ak dreambox, ja by som pouzil oscam v oboch s newcamd protokolom.
Re: Homesharing
Aha. Asi Dreambox :-)
Tak v Dreame Ti stačí mgcamd
romanmesko
Re: Homesharing
Ja by som tiež mal záujem o spárovanie týchto dvoch prístrojov E-xtrend a Dreambox 7000s.Dajte nejaký navod ,ako na to.Dík
VU+UNO 4k SE,OpenATV 6.3 aktívny,250GB Hdd,Portugal 85cm AL click clack,LNB Smart Twin Titanium 0.1db, Motor SG 2100,HDD WD My passport 500GB,LED Samsung UE46D5520,AV Receiver ONKYO HT-R548
Re: Homesharing
Co mas v DM7000ke za emulator?
Ak mgcamd, tak do newcamd.list dopis riadok:
CWS = ip_xtrendu port meno heslo 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan local
Ak cccam, tak do cccam.cfg dopis riadok:
N: ip_xtrendu port meno heslo 01 02 03 04 05 06 07 08 09 10 11 12 13 14
V Xtrende v oscam.user treba doplnit usera:
[account]
user = DM7000
pwd = DM7000
monlevel = 0
uniq = 1
group = 1
au = 0
caid =
ident =
a v oscam.cfg nastavit ak nie je newcamd protokol pre dany port a caid karty napr takto:
[newcamd]
port =15000@0D96:000004
allowed =
keepalive = 1
mgclient = 1
[account]
user = DM7000
pwd = DM7000
monlevel = 0
uniq = 1
group = 1
au = 0
caid =
ident =
[newcamd]
allowed =
keepalive = 1
mgclient = 1
dreamb
Re: Homesharing
Vikino ďakujem, vyskúšam to až v sobotu a dám vedieť.
akordeon
Pozdravujem všetkych, chcel by som poradiť mam clarktech 9000 a chcel by som k nemu kupiť neaky najlacnejši hd prijmač ktory by dokazal zdielať jednu skylink kartu( po kable). Poradi niekto čo by bolo vhodne do pary? A čo by trebalo nahrať v obidvoch aby to fungovalo nezavisle čo pozera jeden a čo druhy. Dik za každu radu.
Re: Homesharing
Hocaky prijimac s E2, dreambox aj klon - napr. newcamd protokol ako som popisal vyssie, alebo cccam, Ariva hocaka s newcamd protokolom atd... je toho velmi vela. Treba citat a rozhodnut sa pre niektory, potom nastavime....
akordeon
Re: Homesharing
oki, sorry, toto vlakno som skôr nenašiel, dam vedieť čo som kupil, a potom ako pišeš, vopred ĎĎĎ
akordeon
Re: Homesharing
Vikino a sat. prijimač typu ab cryptobox 550HD, alebo ab cryptobox 450HD by mohol byť, budu dobre spolupracovať s xtrend et 9000, nebudu mrznuť programi?...
akordeon
Re: Homesharing
vikino zdravim ťa ,tak som si kupil napokon ab cryptobox 550hd, tak čo potrebujem aby som ich spojil dokopy a išli na jednej karte skylink, druhy sat. je xtrend et 9000
