IKONY NA DISLPEJI
kirk
IKONY NA DISLPEJI
PO PRIPOJENI HDD MI NA DISPLEJI STALE SVITI IKONA REC A TIME SHIFT LE ZADNE ODLOZENE NAHRAVANI NENI NASTAVENE A NAHRAVANI TAKY NENAHRAVA,POKUD ZAPNU NAHRAVANI ORIDA SE JESTE JINA IKONA A DETEKUJE ZE SAT NEHRAVA PRIJDE MI ZE TO SVITI JAKO E JE TO MOZNE,MAM V HD BOXU FS 9300 E2 V TE MI TO TAK SVITI,ALE MAM TAM I STARY SOFT A VENEM MI TO NESVITI ALE TAKY MI TO NEBERE HDD POKUD NEKDO MA ZKUSENOST BUDU RAD
- forsajd
Re: IKONY NA DISLPEJI
Neviem aku E2 tam mas najlepsie spravys ked das najnovsiu E2 jku od PKT OCTAGON E2 HYPERION IMAGE http://www.sendspace.com/file/ysed32 zobere ti to pol hodinky z casu a potom ti poradim aj z HDDkirk píše:PO PRIPOJENI HDD MI NA DISPLEJI STALE SVITI IKONA REC A TIME SHIFT LE ZADNE ODLOZENE NAHRAVANI NENI NASTAVENE A NAHRAVANI TAKY NENAHRAVA,POKUD ZAPNU NAHRAVANI ORIDA SE JESTE JINA IKONA A DETEKUJE ZE SAT NEHRAVA PRIJDE MI ZE TO SVITI JAKO E JE TO MOZNE,MAM V HD BOXU FS 9300 E2 V TE MI TO TAK SVITI,ALE MAM TAM I STARY SOFT A VENEM MI TO NESVITI ALE TAKY MI TO NEBERE HDD POKUD NEKDO MA ZKUSENOST BUDU RAD
HD-BOX FS-9200 PKT E2 HYPERION , VU DUO
kirk
forsajd píše:Neviem aku E2 tam mas najlepsie spravys ked das najnovsiu E2 jku od PKT OCTAGON E2 HYPERION IMAGE http://www.sendspace.com/file/ysed32 zobere ti to pol hodinky z casu a potom ti poradim aj z HDDkirk píše:PO PRIPOJENI HDD MI NA DISPLEJI STALE SVITI IKONA REC A TIME SHIFT LE ZADNE ODLOZENE NAHRAVANI NENI NASTAVENE A NAHRAVANI TAKY NENAHRAVA,POKUD ZAPNU NAHRAVANI ORIDA SE JESTE JINA IKONA A DETEKUJE ZE SAT NEHRAVA PRIJDE MI ZE TO SVITI JAKO E JE TO MOZNE,MAM V HD BOXU FS 9300 E2 V TE MI TO TAK SVITI,ALE MAM TAM I STARY SOFT A VENEM MI TO NESVITI ALE TAKY MI TO NEBERE HDD POKUD NEKDO MA ZKUSENOST BUDU RAD
ja jsem to nedelal no tu novou e2 jsem si stahnul a jak a co s tim dal kam ji mam nahrat mam e2 instalovanou ve flesce
kirk
mam e2 od pkt haarp image zkousely jsme jich nekolik tahle je nejstabilneji,jen po vlozeni hdd mam ty dve zminene ikony,jinak k tomu hdd ja ho vidim muzu na nej nahravat a ukladat filmy jen nevidi slozky jako pohadky komediae a tak ale to mi nevadi takze na siti ho vidim hjako hdd a vsechno video a foto musim ukladat do moves,me tedy jde jen o ty ikonky no pokud zmacnu nahravani na ovladaci vejede mi nabidka a v ni vidim a kazdy den se to meni nastavene nahravani na aktualni datum ale nenahrava to ale nemuzu to ani zmenit,je nejaky plugin jako manager casoveho nahravani?jinak mi e2 chodi jak hodinky ono to casove nahravani snad ani nebudu pouzivat ale ta ikona rec ma svitit pri nahravani ale me pri nahravani se rozsviti jeste jina ikonka takze i tohle je ok rad bych jen zrusil to posunute nahravani ini se to automaticky nastavuje na kazdy den samo ale nenahrava to je to jako by svitilo ze jemmozne si to nastavit chtel bych to nejak zrusit,kdyz mi napises jak zjistim jakou mam e2 presne tak kouknu jsme zacatecnikem jinak mam vse ok,treba je nejaky plugyn na casove nahravani nevis?nebo nejaka rada jak zrusit?tahle e2 byla jedina ktera se s hd boxem fs9300 rozjela,
kirk píše:forsajd píše:Neviem aku E2 tam mas najlepsie spravys ked das najnovsiu E2 jku od PKT OCTAGON E2 HYPERION IMAGE http://www.sendspace.com/file/ysed32 zobere ti to pol hodinky z casu a potom ti poradim aj z HDDkirk píše:PO PRIPOJENI HDD MI NA DISPLEJI STALE SVITI IKONA REC A TIME SHIFT LE ZADNE ODLOZENE NAHRAVANI NENI NASTAVENE A NAHRAVANI TAKY NENAHRAVA,POKUD ZAPNU NAHRAVANI ORIDA SE JESTE JINA IKONA A DETEKUJE ZE SAT NEHRAVA PRIJDE MI ZE TO SVITI JAKO E JE TO MOZNE,MAM V HD BOXU FS 9300 E2 V TE MI TO TAK SVITI,ALE MAM TAM I STARY SOFT A VENEM MI TO NESVITI ALE TAKY MI TO NEBERE HDD POKUD NEKDO MA ZKUSENOST BUDU RAD
- forsajd
Daj novu e2 na usb cez Maxiboot Installer http://www.forum.satdigitalne.cz/downlo ... hp?id=4896 na tej istej stranke http://www.forum.satdigitalne.cz/viewto ... 223&t=4792mas aj postup instalacie ked to budes mat tak sa ozvy.
- forsajd
Len neviem ci ti to pojde nainstalovat ked ze tam mas uz enigmu PKT vo flash viem ze cez flash enigma od AAF to vedela ale ci to vie aj PKT tak to netusim.forsajd píše:Daj novu e2 na usb cez Maxiboot Installer http://www.forum.satdigitalne.cz/downlo ... hp?id=4896 na tej istej stranke http://www.forum.satdigitalne.cz/viewto ... 223&t=4792mas aj postup instalacie ked to budes mat tak sa ozvy.
kirk
ahoj asi jsme si nerozumely ja mam hd box 9300 fsi takze mi ta nova e2 od tebe nesla nainstalovat mam tam posledni oznou e2 jedine co me zlobi jsou ty konky na displeii a ty jsou zusobene tim ze kdyz se podivam na casove nahravani tak je tam nastaveno nejde zrusit a navic kdyz je nastaveni cas nahravani nahravat nezacne ale automatickyse prepise na stejny den ale jinou hodinu a takhle to pokracuje porad
forsajd píše:Len neviem ci ti to pojde nainstalovat ked ze tam mas uz enigmu PKT vo flash viem ze cez flash enigma od AAF to vedela ale ci to vie aj PKT tak to netusim.forsajd píše:Daj novu e2 na usb cez Maxiboot Installer http://www.forum.satdigitalne.cz/downlo ... hp?id=4896 na tej istej stranke http://www.forum.satdigitalne.cz/viewto ... 223&t=4792mas aj postup instalacie ked to budes mat tak sa ozvy.
cimrosek
stáhnul jsem jí z toho odkazu a nechtěla mi najet na flashdisku,je asi pro octagon 1028,stáhnul jsem z tohoto odkazu pro octagon 1018,a ta mi na fs9200 jede.forsajd píše:Neviem aku E2 tam mas najlepsie spravys ked das najnovsiu E2 jku od PKT OCTAGON E2 HYPERION IMAGE http://www.sendspace.com/file/ysed32 zobere ti to pol hodinky z casu a potom ti poradim aj z HDDkirk píše:PO PRIPOJENI HDD MI NA DISPLEJI STALE SVITI IKONA REC A TIME SHIFT LE ZADNE ODLOZENE NAHRAVANI NENI NASTAVENE A NAHRAVANI TAKY NENAHRAVA,POKUD ZAPNU NAHRAVANI ORIDA SE JESTE JINA IKONA A DETEKUJE ZE SAT NEHRAVA PRIJDE MI ZE TO SVITI JAKO E JE TO MOZNE,MAM V HD BOXU FS 9300 E2 V TE MI TO TAK SVITI,ALE MAM TAM I STARY SOFT A VENEM MI TO NESVITI ALE TAKY MI TO NEBERE HDD POKUD NEKDO MA ZKUSENOST BUDU RAD
http://www.sendspace.com/file/urhf5a
