AZbox Elite /english/
This section is for programmers and first owners AZbox Elite HD
Here wright bugs and comments.
Re: AZbox Elite /english/
Bugs
TP 11797 H 27500 3/4
JOJ TV stand on screen after switching to next channel Z1 / without sound / only picture
After flashing 0.9.1120 TD 210 /from today/ it´s everything OK
Added SAT & TP list
Now i wait for better EPG from Skylink /23,5°E/
Added SAT & TP list
Dreamer
Hello,
I am missing DiseqC 1.1 support for more than 4 LNBs. I own an multibeam dish with 7 LNBs and AZbox supports only 4 LNBs via DiseqC 1.0. Please, would be possible to add there the DiseqC 1.1 support too?
Thanks,
Dreamer
Thanks,
Dreamer
EPG for SkyLink and czechlink on ASTRA 23.5 ° E used the wrong character set. It has to be ISO8859-2.
This applies to:
TSID ONID
3205 3 # ASTRA 23.5° SKY Link 11 797 H JOJ Plus
3209 3 # ASTRA 23.5° SKY Link 11 876 H Sp5
3215 3 # ASTRA 23.5° SKY Link 11 993 H CS Link TV
3014 3 # ASTRA 23.5° SKY Link 12 525 V CT24
3015 3 # ASTRA 23.5° SKY Link 12 565 H STV1
3107 3 # ASTRA 23.5° SKY Link 10 803 H STV3
3106 3 # ASTRA 23.5° SKY Link 10 788 V STV3HD
3111 3 # ASTRA 23.5° Ocko TV 10 862 H Ocko
The default setting is missing video RGB output
This applies to:
TSID ONID
Naposledy upravil(a) grantec dne 17 led 2009, 17:19, celkem upraveno 1 x.
Dreamer
The default encodings for EPG is multibyte ISO_6937 not ISO8859-2, but there aren't correctly displayed fonts. I guess in AZbox is missing or bad font table?grantec píše:EPG for SkyLink and czechlink on ASTRA 23.5 ° E used the wrong character set. It has to be ISO8859-2.
This applies to:
TSID ONID
In the video output signal missing VSS does not allow the receiver to identify the correct image format. It's not the HDMI or SCART output.
http://en.wikipedia.org/wiki/ISO/IEC_6937
Naposledy upravil(a) Dreamer dne 19 led 2009, 18:20, celkem upraveno 1 x.
Dreamer
External HDD ext3 support ???
Hello,
why is not supported ext3 partition on external HDD? Can you add the ext3 support please? BTW. the azbox itself uses ext3 internally, so why not also externally?
Thank you,
Dreamer
Thank you,
Dreamer
What is missing
What is missing AZbox HD:
The management of program channels
functional home sharing (LAN/LAN )
azbox
AzMaster
New thread on www.azboxworld.com for AZ HD
http://www.azboxworld.com/index.php?pag ... 381216078f
for your attention
for your attention
Wish...
It´s possible make image with better picture SD channels?
