fw 0.9.1473
fw 0.9.1473
http://www.azupd.com/0.9.1473/patch.bin
Popis je z sat-mac:
0.9.1473
Zitat:
Release Notes
Fixed
- Problem with the loop output: when receiver is at standby mode, holding power suppl. on Antenna input connector On ,
then, receiver linked to the loop cannot manage to LNB.
Whoever if you turn off the electricity AZBox - receiver linked to the loop works ok
Fixed
- After a formating of a 1TB HDD, it created just a partition of 500GB.
Fixed
- Broken Characters at EPG, specially Polish EPG
Fixed
- No info about recording in VFD Display(LED)
Fixed
- Pause option is not working when using emu
Fixed
- Emulator stops receive ECM when press pause, it can rewind and play, but all after pause pressed is broken.
API stop to send ecm data
Fixed
- No After setting control word
Fixed
- broken TS packet on symbolrate 30000 FEC 7/8 in hellas sat2
Fixed
- OGG Vorbis don't supported at MKV files
Fixed
- mkv-files: selction of different audiotrack's is without effect.
Improved
- slow EPG at info during zapping
Added
- "argument" and "xcasapi" field in openxcas config file for newcs & mgcamd
module will be excuted with arguments
module with "xcasapi = FALSE" will be consider just daemon
Added
- OSD capture tool. Use 'admin_control' for capturing OSD screen shot
USAGE: admin_control /DATA/pitures/capture01.png
Not supported on browser, TTX, subttile, video
Re: Firmware 0.9.1473
Citlivosť DO a rýchlosť prepínania programov sa zlepšila
Diablo stále nejde
to neva- ved na tom diable uz tiez toho moc nejde :D nic sa neda robit - my sme sa nedozili- mozno nase vnucata :96:
V Home 3 - add plugin sa da stiahnut plugin mwkeytest . V adresari emu vytvori samostany adresar . Jedina funkcia , ktoru som zatial zistil je - test tlacitiek na DO. ....
Rychlost reakcie DO sa nezmenila - zmenila sa nanjvys presnost reakcii .
Pre Multicas 155C - citacka uz opat funguje korektnejsie ( plati pre skylink card) .
Opravene nahravanie - zial navrat z record listu (zoznamu nahranych programov) ukonci dekodovanie pomocou internej citacky.
garion
Příspěvek od garion »
1.) Me se zatim zda ze reakce DO jsou lepsi nez u predchoziho firmware.
2.) Zlepseni kvality SD kanalů aspon pro me oko :96:
Naposledy upravil(a) garion dne 11 bře 2009, 18:29, celkem upraveno 1 x.
AZBOX HD - elite, Skystar2 - VDR 1.60 (gentoo), Triple Dragon, DB500
A mame prpblemy s Lip sync . Na niektorych programoch je viditelny asynchron (audio/video). Na skylink - nie na digi.
V zozname nahravok je nespravne identifikovana dlzka nahraneho programu - vsade je 999. Nie je to dlzka nahravky,ale cas ochrany suboru pred zmazanim - standartne prednastaveny na 999 dni.
Zmena komprimacie na TP 11876/H (astra 23,5) ma velmi blahodarny ucinok na kvalitu obrazu - viditelne lepsi obraz napr. na HBO - co bol uz ku koncu s kvalitou des. Opat je to OK. Nevyhodu su docasne techn.problemy problemy na uplinku - to obcasne fragmentovanie nieje chyba prijimaca !! Po odladeni na strane prevadzkovatela to bude OK.
Na ktorých programoch sa Ti to zdá asynchrónne ?
danmark
Příspěvek od danmark »
krucinál kdo dělá ty firmware? nějaký pokustóni? zetím jsem si nevšiml ničeho k dobru ale ukončení dekodování při návštěvě record menu jsem si všml hned.
Clarke.Tech ET9000 HD+Samsung LE46B651+1TB Samsung Spinpoint
asynchro - HBO a Filmbox
pad Multicas nieje zakazdym - ale obcas sa pritrafi. Vsetko su to test verzie - netreba sa vzrusovat !
Kto najde admin_control je boh :115:
cslu
Příspěvek od cslu »
soubor je tu: MMP/usr/bin
cslu píše:soubor je tu: MMP/usr/bin
dik.
Prave testujem nahravanie na Eurosport HD a sucasne prehravanie (live) Nova HD. Zatial to funguje OK.
Tak nefunguje - tvari sa ze nahrava,ale nenahrava. Napriek tomu,ze oba su z rovnakeho TP.
Inak - stare nahravky sa v playliste neobjavia- novy fw si vytvori aj novy playlist. Na HDD samozrejme ostanu. Subor s videom ma priponu *.meta. Ak ho chcete prehrat v PC- staci mu zmenit priponu na napr. *.TS .
cslu
Příspěvek od cslu »
grantec píše: Opravene nahravanie - zial navrat z record listu (zoznamu nahranych programov) ukonci dekodovanie pomocou internej citacky.
ono to zatvrdne celkově , během nahrávání sd programů lze přepínat z transpoderu a zatím ok , vypozoroval jsem ,pokud hned po ukončení nahrávání chci přehrát nahrávku nebo přepnout na jiný program tak to zcela určitě spadne , je třeba chvíli počkat cca 20s pak to jde , další bug pokud je na playlistu více nahrávek některé jdou spustit až na podruhé.
danmark
nechapu jak to děláte ale mě při nahrávání a pokusu o přepnutí na jiný kanál vyskočí hláška, že přepnutí zastaví aktuální nahrávání, takže nemohu sledovat a nahrávat něco jiného.A postřeh který asi už všichni vědí ale který mě příjemně překvapil že se nahrává i v režimu standby.
