fw 0.9.1600
fw 0.9.1600
new fw -test :arrow: http://www.gigasize.com/get.php?d=oqg82g7p7oc
verzia 0.9.1600
Fixed
- WMA Pro don't work at all over SPDIF and HDMI
Fixed
- At channel info bar (Zapping bar) appear Actual and next program and not only actual like actually
FIxed
- Signal meter takes too long to update (10 seconds) or more. At this way signal meter is useless
Fixed
- Timeshift / Pause and record don't work at USB, using FAT32 or EXT3
Fixed
- Timeshift at HD channels don't work very fine, receiver looks like a crazy horse
Fixed
- Improve API, to don't stop EMUlators, API sometimes get's losted Stressed.
Fixed
- MKV, if MKV have 2 tracks DTS and AC3, at AC3 cannot be played
Fixed
- OGG Vorbis don't supported at MKV files
Added
- Possibility of change color of subtitles
Added
- Increase the maximum size of subtitles, at HD contents the maximum size allowed by azbox, still small
Added
- Possibility to change positions of subtitles, goal is be possible put subtitles at black line, when movie broadcasted at 16:9
Fixed
- mkv-files: selction of different audiotrack's is without effect.
Fixed
- Pic-viewer: scaler/ optimizer very slow, aspect ratio incorrect
Fixed
- Chinese charset instead of latin lower case letter, while using rename feature, create albuns, etc.
Added
- FTP CLIENT
Fixed
- FilmBox HD image freeze
Re: fw 0.9.1600
Testy z TP 12109 už nemrznú /karta v čítačke/ ako to bolo vo fw 1473
Možnosť nastavenia priehľadnosti OSD
Starý setting mi tento fw nezobral - tak som spravil nový...
Infobar sa rozrástol o znázornenie progresu aktuálneho a následujúceho programu / viď OSD screen /
jc.jaroslav
Re: fw 0.9.1600
Příspěvek od jc.jaroslav »
úpravy zvyšují komfort, ale nechce se mně předělávat seting, asi to ještě vydržím (dotazy rodiny proč jsou kanály zase jinak naladěný už nemám chuť komentovat :-)) Snesu vítky rodiny pokud
- funguje rescaling fotek vyššího rozlišení
- nahrává NOVA HD bez záseků
testoval to někdo?
andrejtom
Re: fw 0.9.1600
Příspěvek od andrejtom »
a ako je to z Diablom? Uz konecne funguje? Alebo treba este stale cakat.
Re: fw 0.9.1600
Diablo nefunguje.
andrejtom
Re: fw 0.9.1600
Tak to sa mi neoplati flashovat a znovu cele ladit. Dufam ze uz v dalsom FW to uz bude funkcne.
nick1612
Re: fw 0.9.1600
Příspěvek od nick1612 »
Jedou Vam na tom rumuni? Mi se to nejak nechyta
Clarke Tech ET9000 HD, AZBOX HD ELITE, 0.9.4890 vit.
LCD TV SONY KDL 46V5500
Re: fw 0.9.1600
Daj si aktualne kluce. Ziadny sw pre AZbox ti nikdy neprepise obsah adresara /EMU/ . Mozno len staci spustit emulator.
fw 0.9.1605
neubehlo vela casu a novy patch je na svete . S rovnakym popisom, len verzia je 0.9.1605 . Opat sa jedna o test verziu ! A opat pridete o programy. Kto ale ma chut - moze vyskusat.
http://reseller1359.res.dd3724.kasserve ... /patch.bin
nick1612
Re: fw 0.9.1600
Pred instalaci noveho FW to jelo, ale ted zaboha nic ,,, ted pomoci Multicasu to je OK, ale Mgcamd a Newcs porad nic,,, prehral jsem to znovu, dal jsem opet projistotu Tvuj posledni autoroll a nic ;-)
Neeeezeby me to nejak moc stvalo, ale proste nechapu, kde je problem a je treba to vykoumat.
nick1612
Re: fw 0.9.1600
Dnes se novymi softiky roztrhl pytel :-)
Tak jdu na to ,,,
Re: fw 0.9.1600
Davam verziu 0.9. 1605 , ked sa nahra -pozriem v com je problem . Aj hned pri prvom prispevku som pisal,ze sa jedna o test verziu ( bol som vo firme, ked som to sem daval) , tazke rovno nahravam 1605 a na tom vyskusam. Podla reakcii na 0.9.1600 by mohol byt problem aj pouzitom starom uboot . Mozno preto vysla tak rychlo oprava. Odkedy bol uvolneny SDK pre AZbox - roznych neof. verzii bude len pribudat a aku-taku istotu funkcnosti budeme mat len pri ofi verziach. Je to udel vsetkych linuxovych prijimacov . Na samotny vyvoj sw to ma ale velmi blahodarny vplyv.
Re: fw 0.9.1605
Pozor na DO - reakcie DO sa nam zrychlili , tak zbytocne neklikajte , aby ste sa nepresunuli do takeho menu, kde nechcete byt :D
V zozname naladenych programov sa da pohybovat obomi smermi , teda z posledneho preskocit hned na prvy.
Mgcamd + newcs nabehol autostartom .
Ako 8. polozka v menu pribudol ftp manazer pre pristup na sietovy disk a pracu so subormi na nom. Konfigurovat sa da pomocou DO . Vystup z ftp managera je cez tlacitko Home- nie exit !
A pribudla nam aj funkcna polozka v malom menu - Display setup. Aj cez HDMI dokaze zdeformovat obraz na Full screen . V rezime auto dodrziava format vysielaneho programu !
nick1612
Re: fw 0.9.1600
Rychost odezvy DO je opravdu lepsi. Skylink jede vporadku jak s Multicas tak s Mgcamd. Jen je mi neustale zahadou, jestli delam nekde neco spatne ja anebo co se deje s digi,,, porad jsem to nerozjel. Smazal jsem Mgcamd, nahral znovu, dokopcil autoroll, nastartoval a nejede a nepojede ... Co jsem tak asi udelal spatne? Anebo je chyba jinde ?
Re: fw 0.9.1600
SoftCam.Key pozri - ci je tam aktualny kye 01. zapis musi byt takto:
N 2111 01 EBE8D0D4D639194FB846D202C68ED392 ; 13-03-2009
