CCcam
CCcam
CCcam pre AZbox HD
a) rozbalit na hdd v pc
b) prekopirovat do adresara /EMU/OpenXCAS/
c) Nezabudnite na atribut 755 !
Podpora len jedneho CCcam servera . Prva testovacia verzia!!! Pre diskusiu si zalozte samostatne vlakno - nediskutujte v downloade !
riddle
Re: CCcam
Cccam prerelease 2
Release notes of CCcam prerelease 2 for AzBox :
- Fixed and Improved stability
- Added basic cccam.info in /tmp
- Improvments for ( All OK ) :
* Viaccess
* NDS/Videoguard
* Cryptoworks
* Nagra
* Irdeto ( Partially fixed )
* Viaccess
* NDS/Videoguard
* Cryptoworks
* Nagra
Re: CCcam
CCcam Azbox Card info
Beta verzia programu pre windows na spravu kariet CCcam servera v AZboxe.
Ovladanie - intuitivne :)
Re: CCcam
New beta cccam azbox hd realese 3
nds fix
nds fix
Re: CCcam
CCcam Info Plug-In pre AzBox HD
Vytvor v /EMU adresár CCcaminfo a prekopíruj do neho súbory.Nastav atribúty CHMOD 755 pre všetko v adresári.
Dík pre NeotionBox
Dík pre NeotionBox
Re: CCcam
IncubusCamd Server - CCcamSerChg Server - CCcam In
Setup
3plugins extract and ftp send azboxhd /EMU folder
and files chmod 755 and cccamserv.conf edit
AzboxHD plugins menu and select plugin...
Setup
Re: CCcam
CCcam v 0.1 for AzBox HD
HD OK
fixed N3 OKchipi píše:funguje super i sa serverom 2.1.0
bravo The Ripper/Mower
HD OK
Re: CCcam
CCam instaler V1.2
Windows aplikacia - nainstaluje CCcam a zabezpeci pridanie Vami urcenej C-line.
Po instalacii (je bleskova) staci len restartovat emulator v azboxe.
Re: CCcam
Restart CCcam -u v azboxe na dialku - pomocou PC
subor rozbalit na PC , kliknut na davkovy subor (CCcam_PC_Reset.bat ) a postupovat podla instrukcii . IP adresu boxu, meno a heslo staci zadat 1. raz.
Re: CCcam
CCcam Release 0.2 Azbox HD
CCcam pre azbox HD . Pridany tunel 1702/1833 ( Premiere)
Vypnut pouzivany CCCam v boxe , rozbalit v PC a nahradit existujuci cccam_nodule v /EMU/OpenXCAS/CCcamCAS/ tu prilozenym suborom.
CCcam 2.0.11
How to start REAL CCCam 2.0.11
1. First download cccam-azbox-2-0-11.rar archive from this post.
2. Extract archive somewhere on HDD.
3. FTP to your Azbox receiver
4. Go to /EMU/ folder and make new folder called lib
5. Copy all files from extracted folder to /EMU/lib
6. chmod 755 all files.
7. Prepare your CCcam.cfg file and put it in /EMU/lib/.
8. Telnet to your Azbox receiver
9. Execute this -> /EMU/lib/ld.so.1 --library-path /EMU/lib /EMU/lib/CCcam.mipsel -dv -C /EMU/lib/CCcam.cfg&
And if all goes well your real CCcam should run
Happy hacking people.
First stage is complete.
Next one will be hard (how to start decoding)!!!
Making linux dvb api without source code of openxcasapi and how it deal with sigma chip
Still waiting for access to source code ...
CCcam.mipsel , v noci vydana verzia 2.1.2 uz obsahuje "zaplatu" - nieje mozne ju tymto sposobom spojazdnit.....
Note: Tato verzia CCcamu je uz dostupna aj z linku islaremota ...
Re: CCcam
This is way to add more C lines and to use them on AzBox HD.
First of all, You have to install Debian on AzBox HD, then when You installed Debian, install CCcam.mips on it.
After You installed Debian and CCcam.mips , edit CCcam.cfg of CCcam.mips which is located in Debian dir /var/etc .
There You can add as much as you want C lines.
Create also F line for cccam_module which will be used for CCcam.cfg of cccam_module
My line looking like :
F: azboxlocal azboxlocal
Default port for CCcam will be 16001 or 16000 ( * see in the CCcam.cfg ).
Now back to cccam_module and enter inside of /EMU/OpenXCAS/CCcamCAS
Edit file CCcam.cfg and add in this format :
C: 127.0.0.1 16001 azboxlocal azboxlocal
Re: CCcam
Doplnena verzia CCcam (dvbapi )
100% funkcne aj s timeshift.
Po zmene v CCcam.cfg je potrebny restart emulatora .
add: Pridany spustaci script . rozbalit a umiestnit do DISK2/etc/start.d/ a nezabudnut na atribut 755 Emulator sa da nastartovat len rebootom prijimaca !. V OpenXCAS je mozne mat sucasne spusteny len newcs. Samozrejme ,ze CCcam.cfg je uz prednastaveny na citanie internej karty .
Re: CCcam
TENTO PROGRAM NIEJE PRIMARNE URCENY PRE AZBOX HD napriek tomu si myslim,ze prave tu ma svoje miesto. Sluzi pre tich, ktorí by radi nahliadli do komunikacie CCcam serveru a klienta.
# CCcam protocol analyser v0.1 ALPHA #
This alpha code will provide you with the fundamental information needed to create a CCcam client/server. By extending this program you will gain a powerful tool when analyzing the protocol.
At this stage it includes the CCcam encryption and login process. It's not the full specifaction of the protocol, I only worked on it for about 3 days (reverse engineering and coding). By looking at the log generated by the tool you should figure out how the shares are transmitted to the client. The ecm part has some extra obfuscation, but you should be able to figure that out yourself…
Eclipse C/C++ project is included with the source code. You need the boost library installed, when building make sure to make a symbolic link boost_system-mt_s etc. this will allow static linking for a release build.
When you make use if this work, a small "thank you" notice in your release notes isn't much too ask. This code is placed under the GNU GPL V3. Also think about sharing your work with the community :)
- libco
E2-CCcam v2.1.1 Nativo AZBox HD
V súčasnosti najjednoduchší spôsob inštalácie CCcam v2.1.1 do boxu.
Stiahni prílohu do PC, rozbal. Dostaneš 3 súbory: cccam; img.png a install.txt
Cez totalcommander prekopíruj len súbor cccam do koreňovej zložky boxu nasledovne:
1. Keď otvoríš box v commanderi, nachádzaš sa v zložke /root. Musíš prejsť do koreňovej zložky dvojklikom na ..
Vtedy sa vypíšu všetky koreňové zložky. Tam nakopíruješ súbor cccam a pridelíš mu atribúty 755.
2. Otvoríš box cez PUTTY (tu je návod kto nevie ako na to: http://www.cssf.cz/showthread.php?t=29255, meno a heslo sú root azbox)
Dostaneš sa sem:
Napr.: E
Výpis:
5. Diaľkovým ovládačom cez HOME, Plug-ins, OpenXCAS, Activation&Priority Setting zakomentovať všetky emulátory (postaviť sa naň a stlačiť modré) okrem dvbapiCAS.
6. Reboot boxu (podržať tlačítko STB POWER kým sa na displayi neukáže REBOOT).
Po naštartovaní boxu CCcam funguje ako víno.
Dostaneš sa sem:
3. Zadáš príkaz:MMP login: root
Password:
MMP[~]$
Tým sa dostaneš do koreňového adresára.MMP[~]$ cd /
4. Príkaz:MMP[/]$
Výpis:MMP[/]$ /cccam
Vyberieš si jazyk.MMP[/]$ /cccam
Installation CCcam v2.1.1 Nativo
AZBox HD Elite & Premium
Script v1.3
EN: Choose a Language
ES: Selecciona un idioma
FR: Choisissez une langue
IT: Scegli una lingua
DU: Wählen Sie eine Sprache
E English
S Espańol
F Français
D Deutsch
A Albanian
N Norwegian
I Italiano
Enter an option :
Napr.: E
Výpis:
Dáš install.E
Script v1.3
MENU INSTALLATION
I Install
S Exit
C Change Lang
Click an option:
Pýta sa či inštalovať alebo nie S/N.I
Script v1.3
INFORMATION :
Is the installation of CCcam v2.1.1 Nativo
1. Download the package is compressed /tmp/
2. Is decompressed /tmp/CCcam_Nativo
3. Will move the files to their folders
4. 755 Permits will be given if necessary
5. It cleans temporary files /tmp
6. Is the reboot
I really want to install the package CCcam v2.1.1 Nativo: S/N
Je to nainštalované. Už len nastaviť CCcam.cfg, kde sa nachádza vidíte vyššie. Najlepšie použiť PSPad editor (http://www.cssf.cz/showthread.php?t=29253).S
Connecting to http://www.islaremota.com[91.121.30.87]:80
CCcam_v2.1.1_Install 100% |*****************************| 1731 KB 00:00 ETA
Downloaded installation package.
CCcam_SH-Install
CCcam_SH-Install/sh
CCcam_SH-Install/lib
CCcam_SH-Install/dvbapiCAS
CCcam_SH-Install/sh/S2cccam.sh
CCcam_SH-Install/lib/libstdc++.so.7
CCcam_SH-Install/lib/libresolv.so.2
CCcam_SH-Install/lib/libpthread.so.1
CCcam_SH-Install/lib/libnss_nisplus.so.2
CCcam_SH-Install/lib/libnss_nis.so.2
CCcam_SH-Install/lib/libnss_hesiod.so.2
CCcam_SH-Install/lib/libnss_files.so.2
CCcam_SH-Install/lib/libnss_dns.so.2
CCcam_SH-Install/lib/libm.so.6
CCcam_SH-Install/lib/libgcc_s.so.2
CCcam_SH-Install/lib/libdvbapi.so
CCcam_SH-Install/lib/libdl.so.2
CCcam_SH-Install/lib/libcrypt.so.1
CCcam_SH-Install/lib/libc.so.6
CCcam_SH-Install/lib/ld.so.1
CCcam_SH-Install/lib/CCcam.mipsel
CCcam_SH-Install/lib/CCcam.cfg
CCcam_SH-Install/dvbapiCAS/dvbapi_module
CCcam_SH-Install/dvbapiCAS/openxcas.conf
Decompression performed.
Start the installation script done.
Installation DVBApiCAS DM8000 done.
Installation CCcam v2.1.1 + Librerias done.
Cleaning temporary files done.
Script v1.3
Installation complete
Script by terrorman
thx
The_Ripper
NeotionBox
iko
pr2
tinos
demosat
and many many more
-> Now you can edit the /EMU/lib/CCcam.cfg
MMP[/]$
ICQ 563 123 279
