nový se objevil ke stažení
http://www.sapro.cz/download/hdbox/download.php
FW 1.07.46
- ShaMan
- ShaMan
Re: FW 1.07.46
To je Changelog z 1.7.45 , který neměl být ani venku , byly tam chyby ...
Němci (Turci) z www. Octagon.gmc.to to pustili ven pro Octagon 1018
Changes :
- Update : Based of V10744
--> Pls. update firstly V01744 and after than V10745 ti your STB
- Subtitle off as playback default
- Subtitle crash and afterimage and not matching point of time : fixed
- Possible to handle favorite group number
- Add. Etc string FDU (Database)
- Bugs fixed for playfilelist
- Bugs fixed for screen saver
- Not locking Tuner when timer running : fixed
- Not locking immediately when exit Main menu during changing TP in scan menu : fixed
- Copy LNB and Diseqc setting when copy service
- Not working subtitle when subtitle off : fixed
- STB dead by left/right when no timeshift buffer : fixed
- PID changing problem when sound mode changes : fixed
- Not working Alarm in standby mode : fixed
- Fixed EPG - OK Key Toggle reservation rootine (clash inspection checking)
- LED control in stanby mode + normal mode (power on) : fixed
--> Menu - Configuration : Display setting und Output A/V setting
- Fixed message when recording message in standby condition
- Checking extra space for data transfer : fixed
- Fixed not to do duplication Timer recording for same Service
- Not matching Directory sink when FilePlayList start problem : fixed
- STB dead by opening specified JPEG problem : fixed
- Fast-Scan translation rename by Search-Mode (German OSD Language)
--> for TVvlanderen, CanalDigital and Telesat
IMPORTANT : Advice for Software and Setting Update
Please save/copy Swoftware & Setting files in MAIN Directory from your USB Stick !
Please make after SW update Factory Reset (System Recovery) !
Changes :
update server
nastavenie adresy servera pre upgrade fw:
Menu- Nastavenie siete -Server pro upgrade ,OK a zadajte adresu:
fortis.update.spacequadrat.de
ulozit cervenym
Prejdite sipkou dole a tlacidlom OK zobrazi zoznam dostupnych verzii - najnovsia je ako prva.
Pomocka pri zapise:
znakova tabulka sa meni zltym tlacidlom na dialkovom (male, velke pismena, cislice a znaky)
ulozit cervenym
Pomocka pri zapise:
