AzBox Web Interface v1.0
This is new Web Interface for AzBox HD Elite and Premium devices by well known author telesat .
Readme files are included in Installer archive.
Thx by telesat
Re: AzBox Web Interface v1.1
-extrahuj utilitku z raru v PC
-rozklikni instaler
-vlož IP AZBOXu HD
-klikni na test IP spojenia
-klikni na test mena a hesla
-klinku na next a počkaj kým sa webif nainštaluje
po inštalácii sa box automaticky reštartne
Pre fungovanie screenshot-ov musí byť v boxe USB stick alebo HDD
a po inštalácii bude zrejme treba reštartnúť emulátor / ak ho používate /
-rozklikni instaler
-vlož IP AZBOXu HD
WEB IF Ver.1.1 © 2009 - Telesat Team
FIX : screen shot capture error , when you use 2 usb device.
WEB IF Ver.1.0 © 2009 - Telesat Team
This is the first version of Web If by me
My idea is that AzBox gets respectable Web Interface, and this is
just fundament which will be ( I hope ) upgraded more.
Short Tutorial for Installation :
Run the application, and choose location for install, default is /MMP,
If You dont know what Are You doing - just let it as it stay by default
Set-up parameters : IP address of AzBox, Username, Password
Press Next, wait that application verify if entered data is correct
If everything is ok, process of Installation will start and it will take
about 40 seconds. After installation process is finished, Your AzBox will
reboot itself and then Web Interface is ready for use
In Your favourite Browser ( IE, Firefox, Chrome, Opera ), enter
IP address of AzBox, and It will aks from You username and password which
are default in this case :
username = root
password = azbox
How to change password ( just for Web Interface ) :
connect on Your device by telnet and ssh and type this command :
hpasswd and press enter on keyboard
It will ask from You to enter new Password, enter it and press on keyboard Enter
It will ask You to enter same password for second time, to check if it is same as first entered
If Everything is ok, You will get message that Password is successifully changed
NOTE:
I would like to express big gratitude to NeotionBox ( iPod ) for support with Ideas ( which he has more
and which will be implemented in future releases of Web IF by me ).
Also gratitude to sofrenic for testing and all others which contribute in making of this Web Interface for AzBox HD.
Best regards,
telesat
monkus
Re: AzBox Web Interface v1.0
WEB IF Ver.1.2 © 2009 - Telesat Team
FIX : Compatibility with older FW , 0.9.2880 or lower.
Quick guide for installation:
Run the program, select a location to install, default is / MMP.
If you know what you are doing - leave it as it is by default
Data set:
AZBox IP address, username and pass
Click Next, wait for the program to check whether the data are OK
and hey, if all ok installation will proceed.
After that, when everything is over, you AZBox will restart.
Then the WebIf is ready to use.
In your favorite browser, enter the IP address of your AZBox.
Will ask your username and pass.
Default username and pass:
username = root
password = azbox
How to change your password (if only for the web):
Connect via telnet and ssh to you AZBox,
Enter command:
passwd
then press Enter.
You will be asked to enter a new password, type and press Enter
You will be asked to repeat the password, type the same again and press Enter.
If everything is ok, you'll get a message that is successfully changed Pasword
Data set:
username = root
password = azbox
Enter command:
passwd
then press Enter.
New web interface . Pre fw 0.9.4xxx a vyssie.
Hi Folks, I have simplified the mentioned web interface.
Many people do not get down with the Telnet or CHMOD it correctly or with the data in the reinladen / MMP directory. So I thought to myself, I'll do this once in a plugin. File.
But since I had no time to degree, it was enough for the last step, unfortunately, not yet.
Your However you must only extract the attached file and the folder to copy to webinterface plugin.
Then you can start it on Azbox under plugins. Through a simple input the IP address in the browser of the PC you can then zugreiffen. In my case the IP address in each config file will even automatically adjust.
If properly adjusted, only if you use USB1 or USB2 or interen HDD for the films by running the Web Interface is the way AzBox automatically.
I want to apologize to koivo joseba and that I have not been informed about it. The script itself has remained the same. The data can also be started from / SMP.
I've only done the automatic setting of the script for inexperienced users to Telnet and FTP to spare (currently FTP can not be saved because it does not. Plugin file, and not from the stick or the Internet can be installed).
What will I get in the future want to run (only after approval of the two):
- Install / tmp or the USB stick (in the coming days, if I have Linux on my PC)
- A Station in the interface, the Web radio from the web radio plugin loads station.xml
- Samba integrate plug-in, to ensure access to movies and other folders
- Automatic startup of the Samba box + shortcut to open the browser
If you discover errors or wish / have suggestions, contact me.
Edit: After Joseba thanked me, would think of no more problems Saves given him at least work (I hope).
I noticed that / SMP for a Firmware update will be emptied. Since the "Setup" is from me but then in the PLUGIN folder, you do not install it again. I'm now still working on Samba, so anyway since I had time testing ways (without web interface) running. This will start automatically.
To copy the startup script, the settings and then executes the commands. Possibly. I try to enter this setting to change in the web interface (such as the IP matters, etc.). However, this would be the attitude taken only after a reboot.
Related to the radio will be a bissl difficult. Have been running a web radio, just not at the AzBox. I want the program so that it appears from the file Station.xml recognizes and directly through the PC player plays out and will not be streamed from AzBox.
Streaming makes only LIVE TV and LIVE Radio that you can not get from the Internet sense. Possibly. It works even HTTPS_Streams.txt from "DISK2 Import and establish there a live TV channels from IP.
In addition, the AzBox it must not be able to stream it. Time will tell even then in the coming months. I'm going first time hit me from the ear and possibly even more creative ideas to collect my brother came up with the idea a WebFTP integrate, and with a WebMail account data from the plugin Mailee.
HTML and PHP is the strength of it. I learn to put the while been about 3 years ago, but he completed their hats with nem CMS (chat, forum, etc all have; worked for about 2 years off it) more than I do.
But something like streaming radio and TV streams (as I said only by Internet programs, so there is no misunderstandings), it should already be possible. WebFTP and WebMail will then look at my brother more times.
Only make the design for websites I should be better, but what they have already done since koivo joseba and is pretty smart (I think)
