FW 1.07.61
FW 1.07.61
- mersa
Re: FW 1.07.61
Víte už někdo,co new fw přináší?
TV LG 50PZ250 - 3D
TV LG 50PZ250 - 3D
RadekV
Re: FW 1.07.61
Je to ale ze stranek Octagonu, takze se muze neco mirne lisit.
Changes :
- USB Wireless Lan support
--> The product with RT73 chipset are avaialbe for now
--> Linksys WUSB54GC USB Device 13b1:0020
D-Link DWL-G122 Rev B1 USB Device 2001:3c00
D-Link DWL-G122 Rev C1 USB Device 07d1:3c03
Conceptronic C54RUv2 USB Device 14b2:3c22
MSI US54EX etc...
- Record & Playback from CS Sharing fix.
- ORF smart card recognision problem fix
- When select & play many files at once, skipping some files (.TS, .avi, .mp3 etc.)
- During Multimedia file Play bug fix.
- OSD Language German improved
--> Correcture Translation
- OSD Language Turkish improved
--> Correcture Translation & add. special character Support
- OSD Language Dansk imrpoved
- During recording, the file size show as minus figure fix.
- During factory reset, the menu time calibration will not be avaialble
- CAS Menu modified
- USB detect while recording, the sw upgrade msg box will not be displayed
- When local offset, UI bug fix.
- Playlist sort option - "time" option as default
- During recording, the firmware upgrade svr menu will not be avaialble
- Record edit menu UI design improved
- In epg list, the gui modified
- By Stop Playback and recurrence Playback, Monitoring Playback from last stop place
- FAV list increased to 16 (After Factory reset aktive)
- During Record, Playback and Timeshift new function in Playbar, with RCU 0~9 buttons jump (percental %)
Changes :
MSI US54EX etc...
- CAS Menu modified
RadekV
Re: FW 1.07.61
Tak jsem v tomhle fw zkusil .mkv 1080, priponu to nebralo, tak jsem dal .avi a ejhle obraz i zvuk jede. Jen byl zvuk opozden o nekolik vterin.
- ShaMan
Re: FW 1.07.61
Asi určitě budou nějaké další úpravy pro Player , některé AVI už jely i ve starších softech ...RadekV píše:Tak jsem v tomhle fw zkusil .mkv 1080, priponu to nebralo, tak jsem dal .avi a ejhle obraz i zvuk jede. Jen byl zvuk opozden o nekolik vterin.
PEDRONIK
Re: FW 1.07.61
Tak je tam vidět že lze přehrávat plno věcí ve formátu avi, zkouším co mám nahrané a zatím co vzalo vše co jsem spustil jen nevím jak je to s formátem mkv, nemám totiž nic a tak to nemohu zkusit.
HD BOX FS-9200 PVR 28,2E 23,5E 19,2E 13,0E
RadekV
Re: FW 1.07.61
Kouknete na video dole: viewtopic.php?f=170&t=3865
Kdo jednou vlastnil Dreambox, tak pochopi, jak skvele by bylo, kdyby se jim Enigma2 povedla.
xdedek
Re: FW 1.07.61
Ahoj lidi, mám s tímto FW menší problém... :sad:
Když tam mám fw 61, tak po každým spuštění se přenastaví na 576i :sad:
vzhledem k tomu, že přístroj běžně využívá taťka a mamka, tak je celkem omezující jej vždy přepínat do režimu 1080i.
Pokoušel jsem se o tyto opravy:
Zazálohoval sem nastaví + kanály, resetoval na tovární, hodil zpět fw 55, jenže nepomohlo, pomohlo až přejití na první fw a to 29, kde i po vypnutí zůtává nastvení OK. Tak jsem zpět hodil fw 55, a nyní již nastavení na 1080i "drželo". Obnovil jsem tedy nastavení + seznam kanálů (nechce se mi to znovu ladit) a opět po spuštěn jede jen na 576i :sad:
Nevíte někdo náhodou co s tím?
Např kde má databázi s nastavením ukrytou? že bych se přes síť mrknul, zda není třeba přes atributy zakázán zápis?
Děkuju mnohorát z rady.
