Dreamsky 9300 HD-PVR
joe
Příspěvek od joe »
Dreamsky 9300
Tuner & Channel
Input Connector F-type, IEC 169-24, Female
Frequency Range 950 ~ 2150 MHz
Signal Level -65 ~ -25 dBm
LNB Power & Polarization Vertical : +13.5VHorizontal : +18VCurrent : 500mA Max. Overload Protection
22KHz Tone Frequency: 22 ± 4kHz Amplitude: 0.6 ± 0.2V
DiSEqC Control Version 1.0/1.2 Compatible, USALS
Demodulation QPSK, 8PSK
Input Symbol Rate QPSK : ~ 45MSps8PSK : ~ 37MSps
FEC mode DVB-S : Auto, 1/2, 2/3, 3/4, 5/6, 7/8DVB-S2 : Auto, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9, 9/10
MPEG Transport Stream A/V Decoding
Transport Stream MPEG-2 ISO/IEC 13818Transport Stream Specification
Profile Level MPEG2 : MP@ML, MP@HLMPEG4 : ASP@L5, w/o QMC, GMCH.264/AVC : HP@L4, MP@L4
Aspect Ratio 4:3, 16:9, Letter Box
Video Resolution 1080i, 720p, 576p, 576i
Audio Decoding MPEG I/II, MPEG4
Audio Mode Mono/Stereo
Memory
Flash Memory 8M byte
Graphic(MPEG) & System DRAM 128M byte
A/V & Data In / Out
Video TV-SCART : CVBS, RGBRCA : CVBS, ComponentHDMI
Audio Audio L/R, S/PDIF(Fiber-Optic)
USB USB 2.0 Host (5V, 500mA Max)
Common Interface 2 Common Interface Slot
Smart Card 1 Smart Card Slot
Power Supply
Input Voltage 12V DC
Type DC Adaptor
Power consumption Max. 60W
Physical Specifications
Size 240mm x 43mm x 155mm
Weight
Operating Temperature 0℃ ~ +45℃
Storage Temperature -10℃ ~ +70℃
edit grantec: kua, kua, takto to vypada ako cinsky radiobudik - len je to tazsie :D
ShaMan
Re: Dreámsky 9300 HD-PVR
Příspěvek od ShaMan »
grantec píše:Pridam moju otazku (porusim pravidlo- nikdy sa nepytat) . Na akej platforme je postaveny prijimac ? Vie uz niekto ?
NEC EMMA ..xxx.. nějaký nový HD čip
Konkretne: Processor NEC MC1097F1
a nieje az tak uplne novy.
Nejake to photo - zaujimave je umiestenie CI a CAS rozhrania.
Trochu malo miesta HDMI -USB - kvalitny HDMI kabel sucasne s USB nema sancu - v tom si mozu projektanti podat ruku s DGS . Celkovo ale kvalitne prevedenie - po stranke zvoleneho materialu .
Ako nahradny zdroj sa hodi 12V/3A od Emosu - povodne urceny pre videostraznika . Stoji cca 900KC.
univerzalne heslo je :0000
editacia Biss : Menu , 4132
Nahravanie sw:
nakopirujte sw na USB kluc, pripojte do USB do prijimaca.
Stlacte na dialkovom -> Menu -> General Settings -> Systémové informácie -> OK -> Cervene ->
heslo 0000 -> aktualizacia USB -> OK -> OK .
Vyckat az kym sa neobjavi END na displayi !!
vlado.ucho
Příspěvek od vlado.ucho »
Zaujímavý prijímač,ale niekto spomínal, že je dvojtunerový.Taktiež je zaujimávé napájanie 12 V.vhodné aj mimo domu,alebo siete 220V.Toto blbé umiestnenie je aj na Octagone 918,ale s konektormi Lan a HDMI.Pritom na zadnom kryte je placu dosť.
nejaké sat.prijímače,Octagon SF-918-HD-PVR-Ferguson Ariva-200-HD-PVR- ,Dreamsky DSR-7000-7500,motor Digi power SG-2100A,alu.parabola 90 cm, Titanium LNB-0,2 dB-kopa iných plechových škatúľ..Od Turksatu po Hispasat, ak chcem, aj ďalej.
Vyvoj sw zabezpecuje bielorusky team v spolupraci s korejcami. Prijimac zatial! nezvladne USALS a protokol DIseqC1.1 . Nieje este celkom ani vyriesene nahravanie na USB a podpora rozdelenych diskov s roznymi filesys.
Nejake screen (v litovskom jazyku) prikladam. Prijimac ma samozrejme aj anglicke menu .
Re: Dreamsky 9300 HD-PVR
Mňa prekvapili jeho rozmery. Pre porovnanie som ho položil na CT 5000 a Azbox Elite.
furko Slovakia
Dal poděkování: 5 poděkování
Příspěvek od furko »
dempsey už ho máš? keď testneš daj vedieť ako sa správa cez share pretože na realskom fore nič moc. :115: ale mohli sa trošku pohrať s tým desingom a displejom. :42:
Nie je tam nič moc preto, lebo to je ešte decko na ktorom toho moc nejde. Písať o jeho fw a tom čo dokáže je predčasné. Viem akurát že v pláne nie je klasické EMU ale len podpora BISS a share.
furko Slovakia
Inak to klasické EMU už aj tak pomaly končí tak sa ani nečudujem viac bude prijímačov-užívateľov ktorý pojdu cez sharing po nete tak nech to dotiahnú do konca :106:
Tomaško
Příspěvek od Tomaško »
Dempsey zapojil si lan a HDMI káble?Vraj si (asi) budú zavadzať.
zapojil, coby nie, sak LAN je vyssie. HDMI a USB uz tak jednoduche nemusi byt .
Ja tam viem pichnúť bez problémov všetky káble aj s USB
jimmy Czech Republic
Příspěvek od jimmy »
uvažuji o zakoupení tohoto přijímače, ale zarazil mě článek
http://www.jimmy_nepis_sem_odkazy.cz/clanky/dreamsky-dsr-9300-hd-pvr-jednotunerovy-satelitni/
, kde se v recenzi píše toto :
Našel jsem jeden problém, Přijímač, ač správně zobrazil vysílanou audiostopu, neuměl dekódovat zvuk vysílaný v Dolby Digital. Zaznamenal jsem to na kanálech Discovery HD, FilmBox HD, Brava HDTV a History HD. Na většině kanálů je v Dolby Digital vysílán i český zvuk a tak se budete zatím muset spokojit s angličtinou, nebo maďarštinou, či jinou audiostopou pokud je vysílána.
To znamená, že nelze v češtině sledovat FilmBox HD ? Nebo to jde pokud nezapnu Dolby ?
Nikde jinde jsem o tomto problému nečetl.
Jestli je tu majitel tohoto přijímače, může mi připsat hodnocení přijímače ?
S posledným fw 1.45 ide aj Dolby Digital.
USALS funguje
karty číta / neviem či prechádzajú EMM
Slovenské menu je výborné
newcamd protokol sa občas zdrhne keď rýchlo prepínaš - ak sa vrátiš a znovu prepneš - chytí sa
S kartami je to normálne použiteľný prijímač s VÝBORNÝM obrazom ale bez emu
Zpět na „Dreamsky DSR-9300 HD diskuze“
