OpenVPN pre AZbox HD
Installation :
Put files from archive in /tmp directory .
Give CHMOD 755 permission on all files.
Connect on AzBox by telnet and You should run this commands :
1. insmod -v tun.ko (Output after You run this command will be Using tun.ko
2. To check if all is ok run first command lsmod
3. Run second check with command dmesg
4. Now run OpenSSL to make Your cert's and use upper link to find more infos how to run OpenVPN.
OpenVPN
Stáhni Plugin.
