fw 0.9.4931 modifikovaný telesat-om
9.9.4931 - telesat® - mod & AZBox4YU
This image is a modifictaion of original 0.9.4931 and it is, in a first place, for dummies.
The idea is that dummy, which is usng AZBox for a first time, can get basics for normal use of it,
without any knowledge of linux/stb.
Installing this FW you are getting:
- new skin, which is, by my opinion, more elegant from the original one;
- ch list for the most watched satellites for usals DiseqC motor
- plugins: liveonsat, livefeeds, tevee4yu, WeatherForecast, SudoQ, tuxchess_0.2, colorbars, PassReset
- CAMs and camreader: Mbox, MGCamd, MultiCAS, CheopsCAS and NewCS (CardReader)
by default Mbox and Newcs are active, cofigured to work together,
which means that the only thing that you should do is to put your original card in the slot and the image will appear
You can choose CAMs by pushing '>>|' button
You can get ECM info if you push '>>' button
- font 'telesat_Uni4AZ.ttf' - subtitles have better visibility (space is ok)
- Network is set on automatic assigning of network parameters - DHCP
After your first restart, on VFD you will get IP address, which is assigned to AZBox
- Network services activated: SSH, Telnet, FTP
- SAMBA activated and set right
- Settings for downloading plugins and CAMs - reset
After you install FW and your first restart, you'll get setup menu.
Choose 'TV channel', then 'Tuner A.DVB-S' and 'Antenna Setup', go down to 'Positioner Setup - USALS', press OK and enter your USALS parameters.
After you go out from the menu, remove your USB stick, reboot your AZBox pressing POWER button down for 5 seconds.
Your AZBox is now ready to be used.
Gratitude goes out to the AZBox4YU team:
Chemstar - for the preinstalled plugins
iPod - for the idea
Roger Rabbit - moral support
Mickey - testing
Thief - proof-reading
telesat - the one responsible for the existance of this FW
ATTENTION :
IF update with new FW is succesful - you will get SETUP menu, in other case - pls renew update !
http://rapidshare.com/files/400714762/9.9.4931.rar.html
iPod - for the idea
Mickey - testing
ATTENTION :
dedecek_
Re: fw 0.9.4931 modifikovaný telesat-om
Vyhodil jsem pár pluginů a adonů, vyměnil setting za svůj a chodí to dost dobře.
Potvrzuji, funguje dobře. Kdyby se upravil seting pro naši potřebu, tak by to asi novým majitelům pomohlo překonat těžký začátek. Na jedno natažení tam je vše potřebné.
frcko73
nejake neduhy....sa pytam,kym ho nahodim.....
Žádné neduhy ale ani přínosy, funguje to stejně jako ty poslední, akorát úvodní logo má červené Z a trochu jinak vypadá info okno.frcko73 píše:nejake neduhy....sa pytam,kym ho nahodim.....
frcko73
takze si ponecham ten co mam.......diky za info
tatulda
Zdravim vsechny.
Chtel bych se optat na nahravani na HDD. Tento FW opet (alespon u mne) pri nastaveni nahravani z EPG a naslednem uspani nic nenahraje. V dany cas se probudi, blika kontrolka nahravani, nicmene po jeho ukonceni na disku nic neni. Toto mi delaly uz i nektere dalsi nedavne firmwary (a myslim, ze jsem nebyl sam). V podstate posledni FW, ktery opravdu fungoval je 4785, (4890, 4923 jsem nezkousel). Nevi nekdo, jak tento problem vyresit? Vypada to, ze po probuzeni na nahravani pri kontrole jeste HDD neni zcela pripraveno, a tak se nic nenahraje... Mozna staci jen nekde neco lepe nastavit.
Diky za pomoc.
Diky za pomoc.
- shibal
Pokud box nenahrává, tak problém bývá také v settingu programů (nebo někdy i v ne právě dobré verzi pluginů).
Předpokládám, že si tam nechal ty pluginy, co byly přímo v instalaci, neříkám, že jsou zlé, jen by to chtělo aby se ozval i někdo, komu jeden nahrávání i na ty "původní z instalace".
Každopádně bych ale asi zkusil jiný setting programů.
tatulda
Diky za odpoved. Nainstaloval jsem vse beze zmeny, jak bylo v patch.bin. Jedine, co bylo treba zmenit, bylo prestavit nastaveni anteny na druzice Astra (19.3, 23.5). Vyhodil jsem USALS a nastavil zpet Diseq 1.0 LNB 1 resp. LNB 2. Pote bylo jeste treba preskenovat DVB-T programy a doplnit/ opravit chybejici satelit. programy, (jako trena Skylink CT HD).
Mam CI modul na Skylink kartu, takze drive jsem jel dokonce bez vsech pluginu.
Tedy naladeno to mam myslim spravne, koukat se na sat. programy mohu take bez problemu, jen je potiz s tim nahravanim, (tedy asi s tim probuzenim disku, co ja vim). Kdyz to prubudim manualne, disk je zivy a jede bez potizi.
Neni nejaka pomoc? (Nekteri uzivatele referuji, ze jim to nahrava dobre; mne to nakonec z beziciho stavu take nahrava dobre....)
- shibal
Napadá mě jediná možnost které pomáhá, když disk "zlobí" - zkusit přepnout ten disk na SATA150.
(jo, a nenapsal si jaký disk to je, třeba ti někdo díky tomu řekne své zkušenosti)
tatulda
Mam nasledujici HDD:
WD5000BEVT 500GB, naformatovany na Ext2.
Jsem celkem nedotceny Linuxem, takze to doporucene SATA150 mi bohuzel nic nerika... Stejne je to ale divne, protoze s FW 0.9.4785 to jelo vse dobre a (jak uz jsem rikal drive), rozhodne nejsem jediny, ktery ma problemy s nahravanim z sleep rezimu, (napr. http://forum.satdigitalne.cz). Pokud nestartuji z sleepu, tak opet nahravam/prehravam z daneho disku bez potizi.
Diky za pomoc.
Diky za pomoc.
- shibal
SATA je komunikační rozhraní, kterým je připojen HDD k nějakému zařízení, ten disk co máš je zaplý aby komunikoval ve standardu SATA300 (novější - rychlejší), nicméně si s tím Azetko někde trošku nerozumí, takže je třeba hardisku říct ať používá starší standard SATA150. Dělá se to buď softwarově pomocí ulity, nebo nastavením nějakého jumperu (přepínače) na disku. Ta druhá možnost bude asi i tvůj případ - Westernery mají myslím jumpery (když tak mě někdo opraví).
Takže vypni box, otevři, vyndej HDD, podívej se na popisy na jeho etiketě, kde by mělo být schémátko, které složí jednotlivé jumpery na HDD.
Dal jsem vyhledat slovo SATA150 na tomto webu, a našel jsem toto (přepnutí na SATA150 se tam řeší, i když z jiného důvodu). viewtopic.php?f=76&t=4743&hilit=SATA150&start=15
Je opravdu důležité aby byl disk v SATA 150. Myslím že 90% problémů s nahráváním je způsobeno tímto. Ale i jiné problémy s bootováním, nevysvětlitelným padáním atd. Pokud se mu tento režim nevnutí natvrdo, tak se pokaždé domlouvá s řadičem na vhodné rychlosti a podaří se jim to pokaždé jinak. Proto box jeden den jede jak víno a druhý den zlobí a zlobí. Lidi si potom myslí, že je to vlastnost fw.
tatulda
wilo
Ja mám tiež WD 1 TB a po prepnutí na SATA150 som odstránil problém s prehrávaním MKV súborov. Predtým mi MKV išlo ca. 10 minút a koniec. Box komplet vytuhol, pomohol len reboot. Teraz mi prehrá všetko bez problémov na 95 %. Momentálne mám fw. 4466. Nahrávanie nepoužívam.
AZBox HD Premium (OpenRSI 3.0, Kernel 3.9.2), interný HDD: Western Digital WD10EADS 1000GB
MultiCAS + MboxCAS, DG 380 DiSEqC H-H Mount, 120 cm Antenna
TV:LG 60PB690V, Blu-Ray: LGBP640
