WICARDD
Napsal: 31 srp 2010, 15:21
Wicardd emulator
1. Cardreader + EMU + VIA, Crypto from standard softkey. BISS is not working . C BISS, a similar picture, as with mgcamd.
2. Very flexible configuration.
3. It works decently. Channels are switched very smartly.
4. When recording takes the keys from the cache.
5. SKY Germany - are not working HD channels. Something connected with the tunnel ...
In the config -
1."sid! = "means -" if sid is not equal "
2."Sid =" means - "if sid Equal"
Installation -
1. Copy the folder in / OpenXCAS
2. Executable - right 755.
3. In openxcas.conf add:
Code:
INFO = /tmp/ecm.info
REFRESH = 3
4. In module.seq - add
Code:
#wicardd
In the config -
Installation -
Code:
REFRESH = 3
Code:
#wicardd
