enigma2 v 1.0.26 - diskusia
Pripadni testeri, sem prosim piste skusenosti s e2 . k stahnutiu + navod tu
http://www.forum.satdigitalne.cz/viewto ... 665#p50665
Re: enigma2 v 1.0.26 - diskusia
Moze sa vyskytnut problem pri bootovani-zastavi sa na dlho pri 20 az 25%. Prijimac je ale dostupny cez ftp aj telnet. Pokial niekto nechce cakat na opravu, ktora by mala dnes vyjst v dalsom patch, tak tu je oprava:
BOOTING PROBLEM FIX !!!
After making flash, please imidiatelly go in RESCUE MODE ( Reboot box with USB Memory stick with patch.bin file inserted in RECEIVER ).
Telnet and FTP username and password are :
username: root
password: azbox
After RESCUE MODE show You IP of Your receiver , use putty and telnet to it and type this commands :
mkdir /D
mount /dev/hda1 /D
Connect with FTP to Your Reciever, and go :
/D/etc/init.d and place this bootup file which is there.
Overwrite : YES
Eject USB, Turn off and Turn on Your receiver and all will be ok.
http://www.azbox-enigma.eu/
username: root
password: azbox
mkdir /D
mount /dev/hda1 /D
Overwrite : YES
Na pripojenie do azboxu pouzite utilitu RCC.EXE
http://www.forum.satdigitalne.cz/viewto ... 104&t=3040
Vlozte USB kluc do azboxu. Musi byt na nom subor patch.bin
Zapnite prijimac vzadu vypinacom .
Pockajte na zobrazenie IPadresy na displayi prijimaca .
Ipadresu opiste do aplikacie RCC.EXE a kliknite na pripojit.
Otvorte zalozku Telnet a napiste prikaz :
odoslite prikaz tlacitlodm enter na klavesnici.
napiste prikaz (pozor dodrzat aj medzery !!!)
odoslat tlacidlom enter
V palikacii RCC.EXE kliknite na zalozku FTP
v adresorovej strukture azboxu sa postpne preklikajte do :
/D/etc/init.d
na pravej strane RCC si najde novy subor bootup (musi byt uz rozbaleny)
kliknite na ikonu prenosu do azboxu. rcc sa spyta, ci prepisat, stlacte YES .
to je vsetko
vytiahnite USB kluc a restartnite AZbox - vypinacom vzadu .
mkdir /Dnapiste prikaz (pozor dodrzat aj medzery !!!)
mount /dev/hda1 /DV palikacii RCC.EXE kliknite na zalozku FTP
/D/etc/init.d
to je vsetko
formis
Enigma se mi rozjela, MKV mi to přehrálo, bohužel bez zvuku, Tuner naladil jen pár stanic, žádný obraz ani na free kanálu. Na transponderu 12625 nenašel žádné stanice. Signál mi to ukazovalo pouze asi u 5ti transpordérů. Asi jsem lama.
nie si lama. sound je zatial problem ,aj tuner. ALe je to na dobrej ceste. Samozrejme,ze fta idu a idu dokonca aj kodovane - cez cccam to ide celkom fajn. Zatial to nevie naladit 12109 na Astra 23,5 . Nic sa nedeje , budu pribudat nove verzie s vylepsenymi funkciami .
opat patch na e2 - verziu 1.0.26
oprava problemu s tunerom
prekopirovat do adresara /tmp/ v azboxe
cez telnet (nepouzivat Putty - azbox nepouziva heslo pre root, Putty ohlasi chybu)
pockat na restart.
cd /
tar -xvzf /tmp/Patch-for-1.0.26.tgz
sync
shutdown -r nowNemáte oprávnění prohlížet přiložené soubory.
hdcz
Enigma 2 v1.0.27
Devices suitable for flashing : Elite and Premium
What is new :
- DiseQc FIX ( 1.0 , 1.1 , 1.2 Manual and USALS too )
- DVB-S2 FIX
- Integrated BlackShadow2 skin by Matrix10
- Fixed boot error
What is new :
- DVB-S2 FIX
- Fixed boot error
AZbox premium 500gb + Azbox Elite.
dedecek_
Vyzkošel jsem, naladilo to hromadu programů na 23,5 - volné programy běží - u některých problém se zvukem /zkreslení a hned nenaskočí/. Přehrávání mkv dobré.
Jak zprovoznit sdílení? Dík.
Topol211
v 1.0.27 mi na mojom elite nefunguje - nenaladi ziadne programy
vratil som sa spät k v 1.0.25
Nahral som tam setting cez dreamboxedit, chybaju tam favoritne programy :sad: -(mate niekto nejaky napad?) - vyriesene Nastavenie - System - Prisposobit - Mod Expert - Povolit vicenasobne bukety
Zdielanie funguje, treba tam nahrat toto
dedecek_
Grantec - stáhnul jsem si tvůj návod na instalaci Enigmy a návrat do původního SF. Vynikající a moc děkuju. Nádherně polopaticky napsáno.
Prosím, napiš, pokud to bude možné, stejným způsobem a slovensky nebo česky návod na instalaci a zprovoznění cccamu event. mgcamdu.
Vřelé díky za všechny lamy.
mikin68
Za ten mgcamd se taky primlouvam.
dedecek_ píše:Grantec - stáhnul jsem si tvůj návod na instalaci Enigmy a návrat do původního SF. Vynikající a moc děkuju. Nádherně polopaticky napsáno.
LG 42LV507S, Azbox Elite HD E2 RTi 1.7.0 usb Patriot 16Gb Skylink/Cslink CCcam 2.3.0
jirkaj
Beam
Premium + ma jinej tuner a je potreba na nej udelat driver, ktery case budem.
