Open PLi images + Nightly Builds
Re: Nightly Open PLi Builds
Upgrade your box to etxx00 with et9x00 image
!!Only for ET9000 box.
The files in attachment upgrade your box to etxx00 model.
This means your box will be compatible with all models in the same range.
!! the file firstly install the bootloader this means you need to reboot the box after bootloader is loaded and second time it will load the new image on the box.
Download_openpli-2-1-beta-et9x00-20111006-usb
ClarkeTech-Xtrend-Team proudly presents
World Exclusive
OpenPli2.1 beta Image based on Linux3.0.3 for ET9x00
little overview:
- Improved dvb-usb like Vtuner, webcam -
- Improved wifi usb devices -
- Improved file system: UBIFS and EXT4 -
- Improved streaming -
- Improved picture quality and sound -
- Improved overall preformance by about 10% -
- and much more !!! -
And again, ClarkeTech-XTrend-Team has done before all others!
Others only talking, WE DO IT
!!! Attention !!! - Plz du not Update yet - Updateserver are online in 2-3 Days !!! Attention !!!
--- This is only a Beta Version plz report all bugs what you found here ---
--- Es handelt sich noch um eine Betaversion, daher bitte jegliche Fehler wo ihr findet hier Posten danke ---
!!! Needs the latest Bootloader (30.09.2011)
Special Thx to: wallie2000, tam2010, dispatcher, Biki3, z-pg-3, janosch, Pcd, CoolST, clarkemaster, memo and all other devs!
---------->>> Edit 18.10.2011 <<<---------
>>> New special DVB-USB Devices support Image with extra Drivers (as attachment: openpli-2.1-et9x00-20111018115722_usb_dvbusb_vtuner.zip) <<<
- this version support all green Devices from this List: http://www.linuxtv.org/wiki/index.php/DVB-T_USB_Devices
Download openpli-2.1-et9x00-20111016151229_usb of offico support forum
Download z ulozto
Download openpli-2.1-et9x00-20111018115722_usb_dvbusb_vtuner of offico support forum
Download z ulozto
World Exclusive
little overview:
Re: Open PLi images + Nightly Builds
OpenPli 2.1 Linux3.1.0 beta Image World Exclusive 06.11.2011
World Exclusive
OpenPli2.1 beta Image based on Linux3.1.0 for ET9x00
little overview:
- framebuffer console -
- vtuner fixes -
- Improved wifi, dvb-t, dvb-s2 usb devices -
And again, next strike from ClarkeTech-XTrend-Team & OpenPli Team !
!!! Needs the latest Bootloader (30.09.2011) !!!
Download z offico fora
Download z ulozto
World Exclusive
little overview:
- vtuner fixes -
Open PLi 3.0: new alpha experimental images!
http://openpli.org/
-len pre fajnsmekrov a dobrovolnych testerov
-zatial nevhodne pre normalne pouzivanie!
-vacsina pluginov a rozsireni zatial nefunguje!
EDIT: k dispozicii uz oficialne vydanie a moznost stiahnutia zo stranok nightly build Open PLi images.
http://openpli.org/
http://openpli.org/download/et9x00/Octagon SF8008 4k twin, oATV 7.1, Egami 10.1.
Open PLi 3.0 s kernelom 3.4.3
- urcene na testovanie pre skusenych uzivatelov!
The changelog will be
- kernel 3.4.3
- optimize handling vtuner usb data (using VTUNER_SET_ADAPTER)
- fix scaling sharpness setting (adjusting the setting could
invalidate other settings)
- et5x00/et6x00: fix recording led status during multiple recordings
- support stretched video clipping area, allowing to zoom into 3D
content (/proc/stb/vmpeg/0/clip_stretch)
- support discrete on/off codes on rctypes 4 and 6
- improve stream client buffer level control
- improve cardreader
(Hopefully this forum will start sending bugreports to korea. Now the feedback of this forums (and xtend-home) is very poor till nothing. The German problems are not reported so how to fix??
OpenPLi-4.0-beta-et9x00
- bez info...
- vyskusat samozrejme mozeme...
Tu stiahni Open PLi 4.0 pre et9x00
- bez info...
