SifTeam images
SifTeam images
SifTeam Enigma2 Gecko Edition/19.03.20011 (Azbox-Cteck et9000-Dreambox-Vuduo)
New Settings Loader Plugin
With this plugin you can download Settings Directly from major settings creators,like Morpheus,Cyrus without lost your Dtt channel list
Added possibility to install manual settings directly from zip/tar.gz/ipk file
Many thanks to Morpheus883 and Cyrussettings.com for joined the project. Other settings makers are welcome
New Lcn Scanner Plugin
Totally Rewritten
Reorder channels with national lcn list
Use it after a standard dtt scan on enigma2 service searching
If you enable "Italy" option lcn scanner will order your channel better with categories divisor,(if you want this option for other country just send a correct lcn xml file )
New SifPanel System
Now you can personalize your panel like you want.Just add or remove the parameters that you use often.
New Software Manager
Now before installing plugin or skin,you can see a preview with some screenshoots
New Default Black Skin
Autodetect usb dtt Drivers
Autodetect usb wifi drivers
Added Sm*rgo Support
DOWNLOAD
Alternativny download: SifTeam image-19.3.2011
Totally Rewritten
New SifPanel System
DOWNLOAD
Re: SifTeam image
SifTeam Enigma2 cteck et9000 Gecko Edition - 29\03\2011
CHANGELOGS:
Download:
CHANGELOGS:
Enigma2:
No Changes
Enigma2 plugins:
No Changes
Openembedded:
2011-01-26 Fraxinas <andreas.frisch@multimedia-labs.de>
* [hotplug-ng] update cvs src date (fixes bug #399)
224a
2011-01-28 Fraxinas <andreas.frisch@multimedia-labs.de>
* [libdreamdvd] update srcdate, enables direct audio and subtitle stream
selection (required by ##440, 441)
199a
2011-02-05 ghost <andreas.monzner@multimedia-labs.de>
* move to git, update srcdate/srcref to fix dm7020hd support
194a
2011-02-06 Andreas Oberritter <obi@opendreambox.org>
* openssl-native_0.9.8j: build fix for x86_64
2011-02-06 skaman <skaman@users.sourceforge.net>
191a
2011-02-05 Andreas Oberritter <obi@opendreambox.org>
* enable devfsd on dm7025
* linux-dm7025: build fix for ubuntu 11.04 / x86_64
186a
2011-02-08 Andreas Oberritter <obi@opendreambox.org>
* opkg: don't touch /usr/lib/opkg/alternatives on install
* minicom: build fix for ubuntu 11.04 / x86_64
* mc-4.6.2: build fix for ubuntu 11.04 / x86_64
2011-02-07 Andreas Oberritter <obi@opendreambox.org>
* remove cp437 from task-boot
* linux: enable codepage 437 to be able to boot from FAT
* dm7025: issue hdparm -d1 after setting dma mode
* zeroconf: set FALLBACK=yes
* opkg: fix interception of depmod calls
184a
* update-alternatives: don't touch /usr/lib/opkg/alternatives on install
2011-02-08 skaman <skaman@users.sourceforge.net>
176a
2011-02-10 ghost <andreas.monzner@multimedia-labs.de>
* gstreamer_0.10.32.bb: add gst-plugin-selector to RREPLACES and RCONFLICTS..
because it was moved from gst-plugins-bad to gstreamer core now
* enigma2.bb: update to 20110210 and define a git srcref removed no more
existing gst-plugin-selector
* checksums.ini: add checksums for gstreamer/gst-plugins-base 0.10.32,
gst-plugins-bad 0.10.21, gst-plugins-ugly 0.10.17 and gst-plugins-good
0.10.27
* gst-plugins-good_0.10.27.bb: fix PR, cleanup
* gst-plugins-bad_0.10.21.bb: fix PR
* gst-plugins.inc: set INC_PR to 0 because of gstreamer and plugins update
* gst-plugin-dvbmediasink: update to 20110210
* enigma2-plugins: update to 20110210 and define a git srcref
* enigma2-skins.bb: update skins to 20110128 and define a srcref for git
2011-02-10 Fraxinas <andreas.frisch@multimedia-labs.de>
* [gstreamer] switch to latest releases
* linux-dm8000: add nand flash driver fix (this fixes mtd/jffs2 ecc error
messages in kernel log)
173a
2011-02-11 ghost <andreas.monzner@multimedia-labs.de>
* enigma2.bb: fix typo (SRCREF -> SRCREV)
2011-02-11 skaman <skaman@users.sourceforge.net>
125a
2011-02-16 ghost <andreas.monzner@multimedia-labs.de>
* dreambox-dvb-modules.bb: update dm800/dm8000/dm500hd/dm800se hardware
drivers all --- - add support for two vtuners - use linuxtv api dvr devices
instead of proprietary pvr device(s) .. this is later needed for better ts
streaming support - small pcr fix - fixed small demux bug to prevent packets
from previous running service in recorded ts streams dm800se/dm500hd: -
updated audio/video decoder, video output, demux and hdmi output code dm8000:
- updated video decoder, video output, demux and hdmi output code take care
this driver update needs at least 2nd stage loader #81
118a
* recipes/udev/udev-124: add vtuner1 device to 41-od-linux-2.6.18-misc.rules
and remove pvr device
* checksums.ini: update secondstage-dm7025-81.bin checksum
* dreambox-dvb-modules.bb: add missing driver date changes
* enigma2.bb: push srcrev for latest dreambox drivers, add 7025 compatibility
diff, remove unused diffs
* enigma2-plugins.bb: push srcrev (needed for new dreambox hw drivers)
2011-02-15 ghost <andreas.monzner@multimedia-labs.de>
* dreambox-dvb-tools-v3.bb: update showiframe tool (switch to nonblock mode)
needed by dreambox-dvb-modules >= 20110215
* dreambox-secondstage.bb: update dm7025/dm800/dm8000/dm800se/dm500hd 2nd
stage loader to #81 - some usb stack fixes / improvements - changed mem
layout for dm800se/dm8000/dm500hd hardware drivers >= 20110215 - some html
fixes needed for modern web browsers (i.e. fixed ineffective "flash" button)
- fixed frequently dm500hd poweron problems - fixed possible ethernet
problems update writenfi tool to fix secondstage on the fly updates on dm8000
114a
2011-02-17 ghost <andreas.monzner@multimedia-labs.de>
* removed kernel-modules-nls-iso8859-1 from MACHINE_ESSENTIAL_EXTRA_RDEPENDS
.. its now directly included in the kernel
* enigma2: fixed 7025 ts playback
* better handling for dreambox-passthrough..
* move libebml and libmatroska checksums to checksums.ini
* remove old (broken) libmatroska and libebml
2010-10-01 Andreas Oberritter <obi@opendreambox.org>
* lib{ebml,matroska}-1.0.0: intitial recipes
2011-02-17 Andreas Oberritter <obi@opendreambox.org>
* linux-dm*: build ISO8859-1 into the kernel and select it as default NLS to
finally fix FAT mounts on boot
* recipes/enigma2: remove no more used enigma2.sh, push srcrev
* enigma2: use libpassthrough when available, push srcrev to fix radiomode
* add dreambox-libpassthrough to support DTS-HD -> DTS conversion for
passthrough (for TS/M2TS)
106a
2011-02-26 Andreas Oberritter <obi@opendreambox.org>
* secondstage: fix do_stage for 7025, consolidate functions
2011-02-25 Andreas Oberritter <obi@opendreambox.org>
* update secondstage to #82, update bootlogo.elf to #7
101a
2011-02-28 Andreas Oberritter <obi@opendreambox.org>
* secondstage: Use PV instead of PV_mipsel, because OVERRIDES follows inverse
logic in this OE version
* secondstage-dm7025: fix freeze before loading kernel (#83)
96a
2011-03-02 ghost <andreas.monzner@multimedia-labs.de>
* dreambox-dvb-modules.bb: update dm800/dm800se/dm500hd/dm8000 hardware
drivers - reentrancy fixes in demux and video/audio clip mode (fixed
frequently kernel oops) - fixed not visible PEP options on DM8000 - revert to
previous video output, hdmi and video decoder code (DM500HD/DM800SE/DM8000)
this should fix some problems introduced with 20110215 drivers - added
pcr/hdmi kernel debug output messages to debug hdmi problems (DM800)
2011-03-02 Andreas Oberritter <obi@opendreambox.org>
* bootlogo: update to #8
2011-03-01 Andreas Oberritter <obi@opendreambox.org>
* secondstage-dm500hd: display IP address on LED (#83)
90a
2011-03-04 Andreas Oberritter <obi@opendreambox.org>
* add driver for Realtek 802.11n USB wireless LAN controllers
68a
2011-03-08 Andreas Oberritter <obi@opendreambox.org>
* autofs: increase timeout from 1 to 5 seconds (refs #694)
58a
* task-opendreambox-wlan: build and suggest usb wlan modules on dm8000
* busybox: enable mkfs.vfat
* task-opendreambox-*: fix DEPENDS
53a
2011-03-09 ghost <andreas.monzner@multimedia-labs.de>
drivers to 20110309 - worked on dm800 hdmi connection lost problem - fixed
load average calculation again (broken since 20110302 drivers) - worked on
h264 buffer underflow problems on some h264 services
2011-03-09 Andreas Oberritter <obi@opendreambox.org>
* autofs-4.1.4: bump PR (fixes 607126c04ef908f0f7bfb1c46cd72d6a2ad7a277)
2011-03-09 skaman <skaman@users.sourceforge.net>
22a
2011-03-15 ghost <andreas.monzner@multimedia-labs.de>
* dreambox-dvb-modules.bb: update dm8000 hardware drivers - fixed lef/right
audio channel switching via HDMI (broken since 20110302 drivers)
5a
2011-03-18 Mladen Horvat <acid-burn@opendreambox.org>
* netbase: fix non working wpa_supplicant detection in network restarts. Push
PR. refs #724
0a
2011-03-27 skaman <skaman@users.sourceforge.net>
* Fixed AGAIN libdvdcss2 depends
2011-03-26 skaman <skaman@users.sourceforge.net>
* Added libdvdcss2 depends
2011-03-24 Bobsilvio <bobsilvio@users.sourceforge.net>
* Update usbloader for new option dib0700
2011-03-23 skaman <skaman@users.sourceforge.net>
* Updated et9000 drivers (20110322)
2011-03-22 skaman <skaman@users.sourceforge.net>
* Removed latest opkg patches from dmm
* Removed svdownloader
* Increased enigma2 PR (missed in last merge)
* Fixed broken v4l-dvb-compat.patch
2011-03-21 skaman <skaman@users.sourceforge.net>
* Updated v4l-dvb SRCREV
* Increased PR in enigma2 task
* Added et9000, bm750 and vuplus checksums
* Added libdvdcss2 as dependency in dvdplayer task
* Updated bm750 and vusolo drivers (20110321)
* Increased bootlogo PR (required from last merge with dmm)
* Updated et9000 drivers (20110319)
* Fixed kernel-module-nls-iso8859-1 dependencies from last merge
Libsif:
No Changes
Opkg:
No Changes
Extuner:
No Changes
Usbloader:
* Added option force_lna_activation=1 for driver dib0700Kód: Vybrat vše
http://hotfile.com/dl/112564136/9f39997/openee-gecko-image-et9000-20110329102702.zip.htmlOctagon SF8008 4k twin, oATV 7.1, Egami 10.1.
Re: SifTeam image
SifTeam Enigma2 Gecko Edition for Clarke Tech ET9000 19/04/2011
CHANGELOGS:
Enigma2 plugins:
No Changes
Libsif:
No Changes
Opkg:
No Changes
Extuner:
No Changes
DOWNLOAD
CHANGELOGS:
Enigma2:
2011-04-17 skaman <skaman@users.sourceforge.net>
* Increased video wizard timeout from 20 to 30 seconds
2011-04-12 skaman <skaman@users.sourceforge.net>
* Test for fix recording on azbox
2011-04-11 skaman <skaman@users.sourceforge.net>
* Fixed demux start pid on azbox
2011-04-09 skaman <skaman@users.sourceforge.net>
* Fixed broken support in videomode for not azbox stb
2011-04-02 skaman <skaman@users.sourceforge.net>
* From azbox-enigma2-project r40: Add missing variable in accel.h header file
* From azbox-enigma2-project r39: Fix detection of the AC3 pid on some
NorthAmerica channels, thx to everyone who tested
* From azbox-enigma2-project r36: Removed #define
* From azbox-enigma2-project r35: Added New Sigma BLIT function
* From azbox-enigma2-project r32: Fix Radio Mode for Sigma CPU, sharing Video
Decoder/STC clock now okey
* From azbox-enigma2-project r31: add prebuffering and some other changes
* From azbox-enigma2-project r29: AC3+ detection added
(ENHANCED_AC3_DESCRIPTOR)
* From azbox-enigma2-project r28: Added few more AC3 stream type values for
detection ...
* From azbox-enigma2-project r27: Start PCR pid even if it's
timeshift/playing TS stream from file (PCR pid needed for Sigma to start
automatically play/STC clocks).
* From azbox-enigma2-project r26: Fix DMX_ADD_PID ioctl, now it's working for
Sigma DVB driver
* From azbox-enigma2-project r25: Added Ultra Model detection
* From azbox-enigma2-project r24: Added Azbox receivers enums
* From azbox-enigma2-project r23: Added Azbox box detection and demux device
selection
* From azbox-enigma2-project r22: Added tuner selection for Elite/Premium
model
* From azbox-enigma2-project r20: fix in dvbtime
* From azbox-enigma2-project r19: Setting DEMUX source on Audio/Video "fd"
after open (it's not default mode on open in Sigma driver)
* From azbox-enigma2-project r18: Changes in eTSMPEGDecoder::showSinglePic
for Sigma
2011-03-27 Bobsilvio <bobsilvio@users.sourceforge.net>
* Fixed problem (first reboot) wlan with rt3070 and rt2870Enigma2 plugins:
No Changes
Openembedded:
2011-04-19 skaman <skaman@users.sourceforge.net>
* Increased task-boot PR
* Fixed bad modules dependency in et5000 machine
2011-04-18 skaman <skaman@users.sourceforge.net>
* Added et5000
* Updated azbox bootup script
* Updated azbox kernel to 20110418
* Added module scsi_wait_scan as azbox essential depend
* Updated azbox driver to 20110418
* Fixed again azbox kernel name and updated kernel and drivers
* enigma2.bb: increased SRCREV
* Restored underscore in kernel name and changed workaround (thanks to
dr_gogeta86)
2011-04-16 skaman <skaman@users.sourceforge.net>
* Increased the right initscript PR!!
* Changed azbox kernel version from the_ripper to the-ripper (thanks to
tideglo)
* Fixed azbox-build-e2 util (always thanks to the author dr_gogeta86)
* Fixed broken azbox inittab
2011-04-13 skaman <skaman@users.sourceforge.net>
* usbloader.bb: updated SRCREV
* Updated azbox drivers to 20110407
* Added e2_packer for azbox (thanks to dr_gogeta86)
* Fixed reboot on azbox
* Updated ccid to 1.4.3 and pcsc-lite to 1.7.2
* enigma2.bb: updated SRCREV
* Updated rt3070 driver (thanks to dr_gogeta86)
* Updated et9000 drivers to 2011009
* enigma2.bb: update SRCREV
* Fixed not applied patches in et9000 kernel (thanks to biondo79)
2011-04-07 skaman <skaman@users.sourceforge.net>
* Added cdfs to et9000 kernel
* Added newline at end of file to et9000 bootup
* Enabled crypto modules in azbox kernel
* Reverted busybox defconfig
2011-04-01 skaman <skaman@users.sourceforge.net>
* Temporary removed r8712 rt73 and zd1211b drivers from azbox
* Added wifi as machine feature in azbox
* Upgraded azbox modules to 20110331
* Increased PR in wlan task
* Added azbox in wlan task (thanks to dr_gogeta86)
* Fixed azbox modules install path
* Added missing defines in dmx.h header (thanks to tideglo)
* Removed fuse-module depency on azbox for upnp
2011-03-31 skaman <skaman@users.sourceforge.net>
* Updated busybox defconfig (thanks to dr_gogeta86)
* Removed old comments fro linux-azbox.bb
* Upgraded gst-plugin-dvbmediasink sources for azbox
* Added necessary patch to linux dvb headers on azbox
2011-03-30 skaman <skaman@users.sourceforge.net>
* Upgraded azbox kernel to 2.6.29 and driver to release 20110330
2011-03-30 Bobsilvio <bobsilvio@users.sourceforge.net>
* Fixed errated checksum for skins dmconcinnity
2011-03-29 Bobsilvio <bobsilvio@users.sourceforge.net>
* Added new skin enigma2-skins-dmconcinnity-hd-trasnparent (margy82 mod)
* Update Usbloader for new dictionary
* Added more vid/pid and convert ra in wlan (thanks bigroma)Libsif:
No Changes
Opkg:
No Changes
Extuner:
No Changes
Usbloader:
* Increased row buffer size
* Small fix in csv parser Resaved dicionary.csv
* Test to fix dictionary end lines
* Updated rt3070sta wireless devices
* Added Vid/Pid, driver rt2870sta and rt3070staOctagon SF8008 4k twin, oATV 7.1, Egami 10.1.
Re: SifTeam image
Sifteam E2 gecko r42 ET9000
Description:
Image version: gecko-20110528160307
E n i g m a 2 version: gecko-git20110603-R42
Machine: et9000
File name: gecko-openee-image-et9000-20110528160307.zip (47.03 MB)
MD5: 6af39e59859b51c084fc2c6da8c7154b
update: default skin; bootlogo; driver
Drivers are updated to 16.05.2011
- Media playback improved
- Fix Xvid
- Rotor fine tune Fix
download SIF OpenEE Et9000 Gecko 20110528174925
alternativny download
Description:
Machine: et9000
- Fix Xvid
Re: SifTeam images
SIF TeAm Enigma2 Koala Et9x00 4-3-2012
Support for Cteck et9000-5000 Xtrend et9200-6000
1)Moved to enigma2 openpli project (thank you openpli team)
2)Sifteam cloud system (You can connect your sifteam forum account on your stb, in the future release you can backup your image,share channels settings etc etc in your personal account storage)
3)New Graphic skin. Thank you so much to daconi.
4)Redisegned SifTeam Panel Menu
5)Redesigned Software Manager.Added possibility to rank your favourite plugin, you can consult top rated,most downloaded plugin etc etc
6)Added Bouquets and Channels Menu. Now you can download your favourite channel list settings.
7)Exclusive possibility to use Original Sky Ita channel list numeration starting from number 100 like skybox stb
8)Added OpenWebIf
9)New System to detect and install Usb devices
10)Many fixes to Mount Disk manager
11)Added Temporary-Static Mount.
12)Added uuid use on fstab
13)Support autoresize for picons (100x60 e 130x80)
14)Airplay Server coming soon
Tu stiahni
8)Added OpenWebIf
Re: SifTeam images
SIF TeAm Enigma2 Koala Et9x00 24-6-2012
- Sifteam cloud system (You can connect your sifteam forum account on your stb, in the future release you can backup your image,share channels settings etc etc in your personal account storage)
- Graphic skin by daconi.
- SifTeam Panel Menu
- Software Manager.Added possibility to rank your favourite plugin, you can consult top rated,most downloaded plugin etc etc
- Bouquets and Channels Menu. Now you can download your favourite channel list settings.
- Exclusive possibility to use Original Sky Ita channel list numeration starting from number 100 like skybox stb
- OpenWebIf
- System to detect and install Usb devices
- Mount Disk manager
- Temporary-Static Mount.
- Airplay Server
- Add NEW Support for Gigablue 800SE, Gigablue 800UE, Gigablue 800 Solo, Gigablue Quattro
- Fixed many bugs
Tu stiahni
- OpenWebIf
- Airplay Server
- Fixed many bugs
Re: SifTeam images
SIF TeAm Enigma2 Jackal Et9x00 24-11-2012
Opensif
CHANGELOGS:
New Image based on OpenEmbedded 3.0 by OE-Alliance
Tu stiahni Sif Jackal img.
Opensif
CHANGELOGS:
Re: SifTeam images
SIF TeAm Enigma2 Jackal Et9x00 17-01-2013
Opensif
CHANGELOGS:
New Horizon skin by MMark
Updated odin drivers to 03/13/2013
Updated gbquad drivers to 17/12/2012
Updated dmm drivers to 07/12/2012
Updated technomate drivers to 08/12/2012
Updated xtrend drivers to 10/11/2012
Added support for vusolo2, odinm7, tmsingle, ventonhde, ebox5000, xp1000, ixussone
Fixed a867 support for xtrend decoders (thanks to unixer - sifbox)
Added a867 support for dmm kernel
Added autobouqetmaker
New skin selector with sub-skins feature
Fixed VFD on ventonhdx
Added fan and lcd management for ventonhdx (thanks to a4tech/ventonsupport)
Fixed now/next title for tvsat services
Fixed hard disk manager
Removed cloud support
New default elements for blue panel
Fixed package status in Software Manager
Fixed network mount for samba shares
Many others small fixes!
Many thanks to skaman, oe-alliance , sifteam forum and betatesters for giving feedback and support.
Tu stiahni Sif Jackal img zo 17.1.2013.
Opensif
CHANGELOGS:
Re: SifTeam images
SIF TeAm Enigma2 Jackal Et9x00 12-4-2013
Opensif
CHANGELOGS:
Updated all drivers
Added support for ixussone, xp1000, venton hde
Tu stiahni opensif-3.0-et9x00-20130412
Opensif
CHANGELOGS:
Updated all drivers
