Repair Hdboxu 7110
Ahojte.Dnes mi klepol Hdbox7110 pri aktualizaci fw cez usb.
Skušal som HDB Clean aj Putty ale nič nezabera.Porter nahra fw do 80%.
Dempsey pisal postup cez Putty skušal som to presne podla jeho navodu.
Zadal som prikaz help napisalo ponuku ako Dempsey.
Dalej prikaz usbboot,usb start, usb_loaderzačala sa
aktualizácii fw z USB.Presne ako Dempsey až po tento prikaz
" ==> erase firtst 0 last 1
..==> protect 0
% Ó7111> FrTs
Dalej by malo nasledovat
"init started: BusyBox v1.14.2 (2010-08-12 22:27:17 KST)
root::0:0:root:/root:/bin/sh
ERROR: Module rt5370 does not exist in /proc/modules
Starting app: ==============================
== Start Main Application =============
##### Get System Information OK! #####
STFAE_Init......
STFAE_Init 1
STFAE_Init 5
STFAE_Init 6
STFAE_Init 7
STFAE_Init 14
STFAE_Init 15
STFAE_Init 16
STFAE_Init 17
STFAE_Init 18
STFAE_Init 19
STFAE_Init 20
STFAE_Init 21
STFAE_Init 23
STFAE_Init 24
STFAE_Init 25
STFAE_Init 26
STFAE_Init 27
STFAE_Init 28
STFAE_Init 29
STFAE_Init 32
STFAE_Init 32
STFAE_Init 33
STFAE_Init 34
STFAE_Init 35
STFAE_Init 36
STFAE_Init 37
STFAE_Init 38
VOUT_FindI2cNumForHDMI 2
STFAE_Init 42
STFAE_Init OK
Front_IrInit : et6202_fd(ffffffff)
fd_front 30
# VFD type : 10002, ver : 1
_micom_type : 65538
..... [WiA8293_IicInit] error 0
DVB-CI mode 1 disable
..... pes start [0][0], buffer 0
..... pes start [0][0], signal 0
..... pes start [1][0], buffer 0
..... pes start [1][0], signal 0
..... pes start [0][1], buffer 0
..... pes start [0][1], signal 0
..... pes start [1][1], buffer 0
..... pes start [1][1], signal 0
Init Wi OK
Appl> Fri Jul 1 00:06:00 UTC 2011
Ale mne napiše
Unknown command ',2944K@0xc20000(Device),1M@0x1b00000(CONFIG),4M@0x01c0
),32M@0(All),4224K@0xf00000(APP_ORG),4224K@0xf00000(APP_BAK)' - try 'help
Dempsey vieš ničo poradit ako dalej?
Neuspešna aktualizacia fw
Re: Neuspešna aktualizacia fw
Skús pred tou aktualizáciou cleaner
jofo.d
Už aj clener som skušal.Skusal som aj ten postup cez Putty mazanie to prebehne presne podla tohoto postupu čo je v radoch a navodoch tu na fore.STi710x> protec off 1:224-255
Un-Protect Flash Sectors 224-255 in Bank # 1
................................ done
STi710x> erase 1:224-255
Erase Flash Sectors 224-255 in Bank # 1
STi710x> protec on 1:224-255
STi710x> boot
Ale aktualizacia cez porter tak do 80%.a cez putty usb napiše to čo je mojom prispevku.
Aj cez clener prebehne mazanie.
STi710x> boot
easyspider
Příspěvek od easyspider »
Aky tam davas firmware ?Je to Flash.v6.HD BOX.FS7110HDPVR.ird?
Xtrend ET 9500 ,Opticum9500HD, 4xLNB,Skylink + UPC,Philips 37PFL7605H,Sony DAV SC5.
pro72
Ahoj, stalo se mi v podstatě něco podobnýho jen mě se rozběhl, ale nešlo ani usb ani lan. Proběhl jak pokus pomocí Portru tak Putty a výsledek stejný někdy se rozeběhl bez funkčních usb a lan někdy ani nenajel. Nakonec když jsem různě z něho smazal co se dalo tak za pomoci Putty, naběhl na původním 2.09.87 co tam byl, tady všechno funguje. Jakmile, ale zkusím nahrát nějaký nový firmware tak nejde, což mě hlava nebere.
Tady jsem to psal: http://www.forum.satdigitalne.cz/viewto ... 316&t=9769
