Dobry den
Mam OSCam: 1.20_svn Build: r11678-798 Compiler: sh4-FoReVeR-linux-gnu-stapi,
Vedeli by ste poradit s nastavenim OSCAM kedy pri niektorych programoch su caste vypadky (resp. viac nefunguju ako funguju) a ine programy idu v poriadku? Vacsinou mam problemy s programamy ktore su dekodovane s 0D96 ale aj s 0624.
Podla mna mam (mozem mat) chyby v:
oscam.dvbapi (P: 0D96, P: 0624, I: 0500, I: 1817,I: 1818)
oscam.conf ([dvbapi] enabled = 1, au = 1, pmt_mode = 5, delayer = 60, user = lokalny)
opakujuci vypis chyb:
2020/11/25 07:46:00 66218524 c (ecm) lokalny (0624@000000/A000/3B6F/4F:D4AB96AFFEF15E2EC47477EA4008643D): timeout (2001 ms) by xxx.net (F/4/4/4)
2020/11/25 07:46:02 66218524 c (ecm) lokalny (0624@000000/A000/3B6F/4F:D4AB96AFFEF15E2EC47477EA4008643D): not found (1626 ms) by xxx.net (F/4/4/4)
2020/11/25 07:46:02 66218524 c (dvbapi) Demuxer 0 restarting decoding requests after 3 ms with 1 enabled and 1 disabled ecmpids!
2020/11/25 07:46:02 66218524 c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 0624 PROVID 000000 ECMPID 0A0B ANY CHID PMTPID 09C4 VPID 09C5
2020/11/25 07:46:02 66218524 c (dvbstapi) overtake: clear pid: 0
a potom este takyto vypis (kde sa strieda 0624 a 0D96)
(ecm) lokalny (0624@000000/0000/3CF9/59:004F1CACB319039975DA52975F8F4F0C): not found (133 ms) by xxx.net (F/4/4/4)
2020/11/25 12:14:37 7A101C4F c (dvbapi) Demuxer 0 restarting decoding requests after 6 ms with 2 enabled and 1 disabled ecmpids!
2020/11/25 12:14:37 7A101C4F c (dvbapi) Demuxer 0 trying to descramble PID 2 CAID 0D96 PROVID 000004 ECMPID 07B4 ANY CHID PMTPID 076C VPID 076D
2020/11/25 12:14:37 7A101C4F c (ecm) lokalny (0D96@000004/0000/3CF9/80:1301FB211852076E7C61A57854B80E76): not found (134 ms) by xxx.net (F/4/4/4)
Dakujem za rady
OSCAM nastavenie pre problem s dekodovanim niektorych programov
Vše ohledně Oscamu
Warder
- Dostal poděkování: 102 poděkování
Re: OSCAM nastavenie pre problem s dekodovanim niektorych programov
Priatelu, kedze sa jedna zjavne o share tak kontaktuj svojho poskytovatela komu platis
smoula99
Keby to bolo mozne, tak by som to uz davno spravil. Jedine co poskytol boli skratky a zakladne udaje z ktorych som si vydedukoval nastavenie.
Skor nez som napisal, som hladal po nete a skusal som vsetky moznosti ktore popisovali iny ...
Myslel som, ze nie je problem poradit ... a hlavne ak sa niekto s tym stretol a "uspesne" to vyriesil
Warder
Takze este raz a naposledy. Komu platis u toho si somruj o pomoc a informacie
005jon
- Dostal poděkování: 208 poděkování
Problém je na druhej strane nie u teba, ty stým nič nespravíš ani my.
Kúp si kartu
Kúp si kartu
bobik
- Dal poděkování: 35 poděkování
Váš dotaz:
Dobrý den,
můžete mi prosím napsat jak bych zprovoznil nové kanály,jako např.HBO 2HD,nebo HBO 3HD, atd.,když třeba Viasaty HD,Film+HD,Arena Sport1 HD,jdou ,a ty prvně zmiňené nejdou.Balíčer Multi a servisní poplatek zaplacen.Modul nepoužívám,sat.recevier je DM 525 HD,image OPEN HDF.Karta Irdeto ICE.Oscam 11569.Děkuji
Dobrý den,
005jon
Tadiaľto cesta nevedie v bežnom OSCAMe to nefunguje
