Přechod Freesat z družice Thor na družici Astra23
Vše ohledně Oscamu
Pavel74 Czech Republic
Příspěvek od Pavel74 »
Prosím o pomoc s nastavením OSCamu.
Po přetočení paraboly na Astru23 a aktivace karty mi přestalo fungovat nastavení v OSCam. Bohužel tomu moc nerozumím konfiguraci mi dělal kamarád který je teď mimo.
oscam.version:
Unix starttime: 1711458603
Starttime: 26.03.2024 14:10:03
Version: oscam-build-DreamOSat-1.20_svn-r11734-799
Compiler: mipsel-oe20-linux-gnu
Box type: vuzero (generic)
PID: 990
TempDir: /tmp/.oscam
GBox tmp_dir: not defined using: /tmp/.oscam
ConfigDir: /var/keys/oscam_atv_ymod/
WebifPort: 8888
Build: by. audi06_19 || info@dreamosat-forum.com
SuPPort: https://www.dreamosat-forum.com/board/
Web interface support: yes
LiveLog support: yes
jQuery support intern: yes
Touch interface support: no
SSL support: no
DVB API support: yes
DVB API with AZBOX support: no
DVB API with MCA support: no
DVB API with COOLAPI support: no
DVB API with COOLAPI2 support: no
DVB API with STAPI support: no
DVB API with STAPI5 support: no
DVB API with NEUTRINO support: no
DVB API read-sdt charsets: no
DVB API with ICAM v9 stream relay support: yes
Anti-cascading support: yes
Debug mode: no
Monitor: no
Loadbalancing support: no
Cache exchange support: yes
Cache exchange AIO support: yes
CW Cycle Check support: yes
LCD support: no
LED support: no
Clockfix with realtime clock: yes
IPv6 support: no
Emulator support: yes
Built-in SoftCam.Key: yes
camd 3.3x: no
camd 3.5 UDP: yes
camd 3.5 TCP: yes
newcamd: yes
CCcam: yes
CCcam share: yes
gbox: yes
radegast: yes
scam: yes
serial: yes
constant CW: yes
Pandora: yes
ghttp: yes
Reader support: yes
Nagra: yes
Nagra Merlin: yes
Irdeto: yes
Conax: yes
Cryptoworks: yes
Seca: yes
Viaccess: yes
NDS Videoguard: yes
DRE Crypt: yes
TONGFANG: yes
Bulcrypt: yes
Griffin: yes
DGCrypt: yes
cardreader_phoenix: yes
cardreader_drecas: yes
cardreader_internal_azbox: no
cardreader_internal_coolapi: no
cardreader_internal_coolapi2: no
cardreader_internal_sci: yes
cardreader_sc8in1: yes
cardreader_mp35: yes
cardreader_smargo: no
cardreader_pcsc: no
cardreader_smartreader: no
cardreader_db2com: yes
cardreader_stapi: no
cardreader_stapi5: no
cardreader_stinger: yes
oscam.server:
# oscam.server generated automatically by Streamboard OSCAM build-DreamOSat-1.20_svn SVN r11734-799
[reader]
label = FreeSat_Astra23
protocol = internal
device = /dev/sci0
autospeed = 0
caid = 0624
rsakey = 79EA25A763DA2C3E02B456A13962E60BCE63E628A2C177BE951CED96A9C6131A146F98D5867B7AE6682324FD6481913C0241F065C8D3457E54BB59B7B5DE0362
force_irdeto = 1
needsemmfirst = 1
detect = cd
mhz = 450
cardmhz = 2700
group = 1
emmcache = 1,3,15,0
blockemm-unknown = 1
[reader]
label = emulator
enable = 0
protocol = emu
device = emulator
disablecrccws_only_for = 0E00:000000
caid = 0500,0604,0D00,0E00,1010,1801,2600,2602,2610
detect = cd
ident = 0500:020A00,021110;0604:000000;0D00:0000C0;0E00:000000;1010:000000;1801:000000,001101,002111,007301;2600:000000;2602:000000;2610:000000
group = 1
emmcache = 2,1,2,1
emu_auproviders = 0604:010200;0E00:000000;1010:000000;2610:000000
v Logu mám:
2024/03/26 14:10:03 00000000 s (main) System name = Linux
2024/03/26 14:10:03 00000000 s (main) Host name = vuzero
2024/03/26 14:10:03 00000000 s (main) Release = 3.13.5
2024/03/26 14:10:03 00000000 s (main) Version = #1 SMP Wed Jan 21 15:08:36 CET 2015
2024/03/26 14:10:03 00000000 s (main) Machine = mips
2024/03/26 14:10:03 00000000 s (main) Stb model = dm8000
2024/03/26 14:10:03 00000000 s (main) Stb vumodel = vuzero
2024/03/26 14:10:03 00000000 s (main) Stb boxtype = vuzero
2024/03/26 14:10:03 00000000 s (main) creating pidfile /tmp/.oscam/oscam.pid with pid 16107
2024/03/26 14:10:03 00000000 s (config) services reloaded: 0 services freed, 16 services loaded, rejected 0
2024/03/26 14:10:03 00000000 s (emu) OSCam-Emu version 799
2024/03/26 14:10:03 00000000 s (config) userdb reloaded: 24 accounts loaded, 0 expired, 0 disabled
2024/03/26 14:10:03 00000000 s (main) signal handling initialized
2024/03/26 14:10:03 00000000 s (config) 1306 provid's loaded
2024/03/26 14:10:03 00000000 s (config) 8728 service-id's loaded in 203 ms
2024/03/26 14:10:03 00000000 s (config) WARNING: You risk high CPU load and high ECM times with more than 2000 service-id's!
2024/03/26 14:10:03 00000000 s (config) HINT: --> use optimized lists from https://wiki.streamboard.tv/wiki/Srvid
2024/03/26 14:10:03 00000000 s (config) 140 tier-id's loaded
2024/03/26 14:10:03 00000000 s (net) newcamd: initialized (fd=6, port=7701)
2024/03/26 14:10:03 00000000 s (net) -> CAID: 0D97 PROVID: 000004, 000008, 00000C, 000010
2024/03/26 14:10:03 00000000 s (net) cccam: initialized (fd=7, port=7702)
2024/03/26 14:10:03 00000000 s (reader) FreeSat_Astra23 [internal] creating thread for device /dev/sci0
2024/03/26 14:10:03 00000000 s (main) waiting for local card init
2024/03/26 14:10:03 12AD2A48 r (reader) FreeSat_Astra23 [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=4.50 MHz)
2024/03/26 14:10:03 12AD2A48 r (reader) FreeSat_Astra23 [internal] Reader sci internal, detected box type: vuzero
2024/03/26 14:10:03 56242BE5 h (webif) webif: decompressed 171235 bytes back into 451928 bytes
2024/03/26 14:10:03 56242BE5 h (webif) HTTP Server running. ip=0.0.0.0 port=8888
2024/03/26 14:10:04 12AD2A48 r (reader) FreeSat_Astra23 [internal] card detected
2024/03/26 14:10:05 12AD2A48 r (reader) FreeSat_Astra23 [internal] ATR: 3B 78 12 00 00 54 C4 03 00 8F F1 90 00
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [internal] Hist. Bytes: TĦ#3;
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [internal] detect irdeto card
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [internal] caid: 0653, acs: 0.05, country code: CZE
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [internal] providers: 4, ascii serial: ##########, hex serial: ######, hex base: ##
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [internal] WARNING: For Irdeto cards you will have to set 'mhz= 600' in oscam.server
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [internal] active providers: 4 (0093ff,ffffff,ffffff,ffffff)
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [internal] found card system irdeto
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max allotted of 1
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] entitlements for provider: 1, id: 0093FF
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: 1B59, date: 2024/03/25 - 2024/04/25
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: 1B5B, date: 2024/03/25 - 2024/04/25
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: 7FFE, date: 2024/03/14 - 2024/04/13
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: 7FFD, date: 2024/02/28 - 2024/03/09
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: FFD8, date: 2014/11/21 - 2014/12/01
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: 1B5C, date: 2024/03/25 - 2024/04/25
2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: 1B5F, date: 2024/03/25 - 2024/04/25
2024/03/26 14:10:14 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] ready for requests
2024/03/26 14:10:14 00000000 s (main) init for all local cards done
2024/03/26 14:10:14 00000000 s (emmcache) loaded 0 emmcache records from /var/keys/oscam_atv_ymod/oscam.emmcache in 1 ms
2024/03/26 14:10:14 00000000 s (emmcache) loaded 0 emmstat records from /var/keys/oscam_atv_ymod/oscam.emmstat in 0 ms
2024/03/26 14:10:14 00000000 s (anticasc) anti cascading disabled
2024/03/26 14:10:14 00000000 s (gbox) local gbox failed init
2024/03/26 14:10:14 3DCC59F6 c (client) encrypted cccam-client 10.0.7.1 granted (usr1, au=auto (2 reader))
2024/03/26 14:10:14 0ADEA774 c (client) plain dvbapi-client granted (dvbapiau, au=auto (2 reader))
2024/03/26 14:10:14 1676C960 c (client) encrypted cccam-client 178.209.155.129 granted (jakubr2, au=off)
2024/03/26 14:10:14 77C17878 c (client) encrypted cccam-client 178.209.147.193 granted (HanaD1, au=off)
2024/03/26 14:10:14 0ADEA774 c (dvbapi) dvbapi channelcache loaded from /var/keys/oscam_atv_ymod/oscam.ccache
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum number of filters is 64 (oscam limit is 64)
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Detected /dev/dvb/adapter0/ca0 device, total available descramblers: 16
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Demuxer 0 ecmpid 0 CAID: 0B02 ECM_PID: 060C PROVID: 000000
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Demuxer 0 ecmpid 1 CAID: 181D ECM_PID: 060A PROVID: 000000
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Demuxer 0 ecmpid 2 CAID: 0624 ECM_PID: 0604 PROVID: 000000
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Demuxer 0 ecmpid 3 CAID: 0653 ECM_PID: 060B PROVID: 000000
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Demuxer 0 ecmpid 4 CAID: 0500 ECM_PID: 0606 PROVID: 051910
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Demuxer 0 found 5 ECM pids and 5 STREAM pids in CA PMT
2024/03/26 14:10:14 0ADEA774 c (dvbapi) Demuxer 0 no suitable readers found that can be used for decoding!
2024/03/26 14:10:19 0ADEA774 c (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
2024/03/26 14:10:20 3DCC59F6 c (ecm) usr1 (0624@000000/A000/3CF4/4B:435B52B0D70365C3FE6908F6A01FA6ED): rejected group (0 ms) (no matching reader)
2024/03/26 14:10:24 0ADEA774 c (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
2024/03/26 14:10:30 3DCC59F6 c (-) -- Skipped 1 duplicated log lines --
2024/03/26 14:10:30 3DCC59F6 c (ecm) usr1 (0624@000000/A000/3CF4/4B:F2F905DB536DE40A1FF516620A8CC82C): rejected group (1 ms) (no matching reader)
005jon Slovakia
Re: Přechod Freesat z družice Thor na družici Astra23
Příspěvek od 005jon »
Freesat má kartu 0653 a ty si zapísal že oscam má použit caid = 0624
opraveno ale stále mi to nejde - tady je oscam.server
[reader]
protocol = internal
device = /dev/sci0
caid = 0623
force_irdeto = 1
needsemmfirst = 1
detect = cd
mhz = 600
cardmhz = 600
group = 1
emmcache = 1,3,15,0
Warder Slovakia
Dostal poděkování: 102 poděkování
Příspěvek od Warder »
1, pozri si este raz a poriadne riadok caid - ze co tam mas ozaj napisane ;)
2, nie som si isty, ci ten oscam od dreamosat vie poriadne pozadovany caid 0653
3, https://forum.satdigitalne.cz/viewtopic ... 95#p126495
:89:
:89:
[reader]
protocol = internal
device = /dev/sci0
caid = 0653
force_irdeto = 1
needsemmfirst = 1
detect = cd
mhz = 600
cardmhz = 600
group = 1
emmcache = 1,3,15,0
config opaven ale ještě to neběží přikládám log
2024/03/27 11:54:28 00000000 s (main) System name = Linux
2024/03/27 11:54:28 00000000 s (main) Host name = vuzero
2024/03/27 11:54:28 00000000 s (main) Release = 3.13.5
2024/03/27 11:54:28 00000000 s (main) Version = #1 SMP Wed Jan 21 15:08:36 CET 2015
2024/03/27 11:54:28 00000000 s (main) Machine = mips
2024/03/27 11:54:28 00000000 s (main) Stb model = dm8000
2024/03/27 11:54:28 00000000 s (main) Stb vumodel = vuzero
2024/03/27 11:54:28 00000000 s (main) Stb boxtype = vuzero
2024/03/27 11:54:28 00000000 s (main) Build = by. audi06_19 || info@dreamosat-forum.com
2024/03/27 11:54:28 00000000 s (main) SuPPort = https://www.dreamosat-forum.com/board/
2024/03/27 11:54:28 00000000 s (main) creating pidfile /tmp/.oscam/oscam.pid with pid 18429
2024/03/27 11:54:28 00000000 s (config) services reloaded: 0 services freed, 16 services loaded, rejected 0
2024/03/27 11:54:28 00000000 s (emu) OSCam-Emu version 800
2024/03/27 11:54:28 00000000 s (config) userdb reloaded: 24 accounts loaded, 0 expired, 0 disabled
2024/03/27 11:54:28 00000000 s (main) signal handling initialized
2024/03/27 11:54:28 00000000 s (config) 1306 provid's loaded
2024/03/27 11:54:28 00000000 s (config) 8728 service-id's loaded in 138 ms
2024/03/27 11:54:28 00000000 s (config) WARNING: You risk high CPU load and high ECM times with more than 2000 service-id's!
2024/03/27 11:54:28 00000000 s (config) HINT: --> use optimized lists from https://wiki.streamboard.tv/wiki/Srvid
2024/03/27 11:54:28 00000000 s (config) 140 tier-id's loaded
2024/03/27 11:54:28 00000000 s (net) newcamd: initialized (fd=6, port=7701)
2024/03/27 11:54:28 00000000 s (net) -> CAID: 0D97 PROVID: 000004, 000008, 00000C, 000010
2024/03/27 11:54:28 00000000 s (net) cccam: initialized (fd=7, port=7702)
2024/03/27 11:54:28 00000000 s (reader) FreeSat_Astra23 [internal] creating thread for device /dev/sci0
2024/03/27 11:54:28 00000000 s (main) waiting for local card init
2024/03/27 11:54:28 055F26F1 r (reader) FreeSat_Astra23 [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=4.50 MHz)
2024/03/27 11:54:28 055F26F1 r (reader) FreeSat_Astra23 [internal] Reader sci internal, detected box type: vuzero
2024/03/27 11:54:28 51162C19 h (webif) webif: decompressed 190607 bytes back into 491048 bytes
2024/03/27 11:54:28 51162C19 h (webif) HTTP Server running. ip=0.0.0.0 port=8888
2024/03/27 11:54:29 055F26F1 r (reader) FreeSat_Astra23 [internal] card detected
2024/03/27 11:54:30 055F26F1 r (reader) FreeSat_Astra23 [internal] ATR: 3B 78 12 00 00 54 C4 03 00 8F F1 90 00
2024/03/27 11:54:37 055F26F1 r (reader) FreeSat_Astra23 [internal] Hist. Bytes: TĦ#3;
2024/03/27 11:54:37 055F26F1 r (reader) FreeSat_Astra23 [internal] detect irdeto card
2024/03/27 11:54:37 055F26F1 r (reader) FreeSat_Astra23 [internal] caid: 0653, acs: 0.05, country code: CZE
2024/03/27 11:54:37 055F26F1 r (reader) FreeSat_Astra23 [internal] providers: 4, ascii serial: ##########, hex serial: ######, hex base: ##
2024/03/27 11:54:38 055F26F1 r (reader) FreeSat_Astra23 [internal] WARNING: For Irdeto cards you will have to set 'mhz= 600' in oscam.server
2024/03/27 11:54:38 055F26F1 r (reader) FreeSat_Astra23 [internal] active providers: 4 (0093ff,ffffff,ffffff,ffffff)
2024/03/27 11:54:38 055F26F1 r (reader) FreeSat_Astra23 [internal] found card system irdeto
2024/03/27 11:54:38 055F26F1 r (reader) FreeSat_Astra23 [irdeto] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max allotted of 1
2024/03/27 11:54:38 055F26F1 r (reader) FreeSat_Astra23 [irdeto] entitlements for provider: 1, id: 0093FF
2024/03/27 11:54:38 055F26F1 r (reader) FreeSat_Astra23 [irdeto] chid: 1B59, date: 2024/03/26 - 2024/04/26
2024/03/27 11:54:38 055F26F1 r (reader) FreeSat_Astra23 [irdeto] chid: 1B5B, date: 2024/03/26 - 2024/04/26
2024/03/27 11:54:38 055F26F1 r (reader) FreeSat_Astra23 [irdeto] chid: 7FFE, date: 2024/03/27 - 2024/04/26
2024/03/27 11:54:38 055F26F1 r (reader) FreeSat_Astra23 [irdeto] chid: 7FFD, date: 2024/02/28 - 2024/03/09
2024/03/27 11:54:38 055F26F1 r (reader) FreeSat_Astra23 [irdeto] chid: FFD8, date: 2014/11/21 - 2014/12/01
2024/03/27 11:54:38 055F26F1 r (reader) FreeSat_Astra23 [irdeto] chid: 1B5C, date: 2024/03/26 - 2024/04/26
2024/03/27 11:54:38 055F26F1 r (reader) FreeSat_Astra23 [irdeto] chid: 1B5F, date: 2024/03/26 - 2024/04/26
2024/03/27 11:54:38 055F26F1 r (reader) FreeSat_Astra23 [irdeto] ready for requests
2024/03/27 11:54:39 00000000 s (main) init for all local cards done
2024/03/27 11:54:39 00000000 s (emmcache) loaded 0 emmcache records from /var/keys/oscam_atv_ymod/oscam.emmcache in 1 ms
2024/03/27 11:54:39 00000000 s (emmcache) loaded 0 emmstat records from /var/keys/oscam_atv_ymod/oscam.emmstat in 0 ms
2024/03/27 11:54:39 00000000 s (anticasc) anti cascading disabled
2024/03/27 11:54:39 00000000 s (gbox) local gbox failed init
2024/03/27 11:54:39 54068BC3 c (client) encrypted cccam-client 10.0.7.1 granted (usr1, au=auto (2 reader))
2024/03/27 11:54:39 1430C9B5 c (client) plain dvbapi-client granted (dvbapiau, au=auto (2 reader))
2024/03/27 11:54:39 1430C9B5 c (dvbapi) dvbapi channelcache loaded from /var/keys/oscam_atv_ymod/oscam.ccache
2024/03/27 11:54:39 1430C9B5 c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum number of filters is 64 (oscam limit is 64)
2024/03/27 11:54:39 1430C9B5 c (dvbapi) Detected /dev/dvb/adapter0/ca0 device, total available descramblers: 16
2024/03/27 11:54:39 1430C9B5 c (dvbapi) Demuxer 0 ecmpid 0 CAID: 0B02 ECM_PID: 060C PROVID: 000000
2024/03/27 11:54:39 1430C9B5 c (dvbapi) Demuxer 0 ecmpid 1 CAID: 181D ECM_PID: 060A PROVID: 000000
2024/03/27 11:54:39 1430C9B5 c (dvbapi) Demuxer 0 ecmpid 2 CAID: 0624 ECM_PID: 0604 PROVID: 000000
2024/03/27 11:54:39 1430C9B5 c (dvbapi) Demuxer 0 ecmpid 3 CAID: 0653 ECM_PID: 060B PROVID: 000000
2024/03/27 11:54:39 1430C9B5 c (dvbapi) Demuxer 0 ecmpid 4 CAID: 0500 ECM_PID: 0606 PROVID: 051910
2024/03/27 11:54:39 1430C9B5 c (dvbapi) Demuxer 0 found 5 ECM pids and 5 STREAM pids in CA PMT
2024/03/27 11:54:39 1430C9B5 c (dvbapi) Warning reader FreeSat_Astra23 received no emms for the last 1711536879 seconds -> skip, this reader needs emms first!
2024/03/27 11:54:39 1430C9B5 c (dvbapi) Demuxer 0 impossible to descramble PID 3 CAID 0653 PROVID 000000 ECMPID 060B PMTPID 05DC (NO MATCHING READER)
2024/03/27 11:54:39 00000000 >> OSCam << cardserver log switched, version build-DreamOSat-1.30_svn, build r11751-800 (mipsel-oe20-linux-gnu-libdvbcsa)
2024/03/27 11:54:39 1430C9B5 c (dvbapi) Demuxer 0 restarting decoding requests after 2 ms with 1 enabled and 4 disabled ecmpids!
2024/03/27 11:54:39 1430C9B5 c (dvbapi) Demuxer 0 restarting decoding requests after 4 ms with 1 enabled and 4 disabled ecmpids!
2024/03/27 11:54:40 1430C9B5 c (dvbapi) Demuxer 0 restarting decoding requests after 2 ms with 1 enabled and 4 disabled ecmpids!
2024/03/27 11:54:40 1430C9B5 c (dvbapi) Warning reader FreeSat_Astra23 received no emms for the last 1711536880 seconds -> skip, this reader needs emms first!
2024/03/27 11:54:40 1430C9B5 c (dvbapi) Demuxer 0 impossible to descramble PID 3 CAID 0653 PROVID 000000 ECMPID 060B PMTPID 05DC (NO MATCHING READER)
2024/03/27 11:54:40 1430C9B5 c (dvbapi) Demuxer 0 restarting decoding requests after 4 ms with 1 enabled and 4 disabled ecmpids!
2024/03/27 11:54:41 1430C9B5 c (dvbapi) Demuxer 0 restarting decoding requests after 2 ms with 1 enabled and 4 disabled ecmpids!
2024/03/27 11:54:41 1430C9B5 c (dvbapi) Warning reader FreeSat_Astra23 received no emms for the last 1711536881 seconds -> skip, this reader needs emms first!
2024/03/27 11:54:41 1430C9B5 c (dvbapi) Demuxer 0 impossible to descramble PID 3 CAID 0653 PROVID 000000 ECMPID 060B PMTPID 05DC (NO MATCHING READER)
2024/03/27 11:54:42 1430C9B5 c (dvbapi) Demuxer 0 restarting decoding requests after 5 ms with 1 enabled and 4 disabled ecmpids!
2024/03/27 11:54:42 1430C9B5 c (dvbapi) Warning reader FreeSat_Astra23 received no emms for the last 1711536882 seconds -> skip, this reader needs emms first!
2024/03/27 11:54:42 1430C9B5 c (dvbapi) Demuxer 0 impossible to descramble PID 3 CAID 0653 PROVID 000000 ECMPID 060B PMTPID 05DC (NO MATCHING READER)
2024/03/27 11:54:42 1430C9B5 c (dvbapi) Demuxer 0 restarting decoding requests after 2 ms with 1 enabled and 4 disabled ecmpids!
Warder Slovakia
No a teraz sprav krok 2 a to vymenu Oscamu, ja doporucujem ten od Samur -a.
:89:
Už jsem to rozběl
tady je nastavení
[reader]
protocol = internal
device = /dev/sci0
caid = 0653
boxkey = A1C6F3D8B5E1F2C1
force_irdeto = 1
needsemmfirst = 1
needsglobalfirst = 1
detect = cd
mhz = 600
cardmhz = 600
group = 1
emmcache = 1,3,15,0
Ještě jsem zjistil že některé programy mi neběží - například Nova Lady, Prima Krimi
nevíce co mám ještě špatně?
zde je log
2024/03/28 11:02:16 1430C9B5 c (ecm) dvbapiau (0653@000000/1B5B/36EF/3C:25463559CD8962C67B4726DB422B10C8): found (91 ms) by FreeSat_Astra23 - Prima Love (lg)
2024/03/28 11:02:26 1430C9B5 c (ecm) dvbapiau (0653@000000/1B5B/36EF/3C:B50F614DE6E3234481FC427E3E428A45): found (91 ms) by FreeSat_Astra23 - Prima Love (lg)
2024/03/28 11:02:32 1430C9B5 c (dvbapi) Demuxer 0 stopped descrambling for program 36EF (Prima Love)
2024/03/28 11:02:33 1430C9B5 c (dvbapi) Demuxer 0 ecmpid 0 CAID: 0B02 ECM_PID: 060C PROVID: 000000
2024/03/28 11:02:33 1430C9B5 c (dvbapi) Demuxer 0 ecmpid 1 CAID: 181D ECM_PID: 060A PROVID: 000000
2024/03/28 11:02:33 1430C9B5 c (dvbapi) Demuxer 0 ecmpid 2 CAID: 0624 ECM_PID: 0604 PROVID: 000000
2024/03/28 11:02:33 1430C9B5 c (dvbapi) Demuxer 0 ecmpid 3 CAID: 0653 ECM_PID: 060B PROVID: 000000
2024/03/28 11:02:33 1430C9B5 c (dvbapi) Demuxer 0 ecmpid 4 CAID: 0500 ECM_PID: 0606 PROVID: 051910
2024/03/28 11:02:33 1430C9B5 c (dvbapi) Demuxer 0 found 5 ECM pids and 5 STREAM pids in CA PMT
2024/03/28 11:02:33 1430C9B5 c (dvbapi) Demuxer 0 trying to descramble PID 3 CAID 0653 PROVID 000000 ECMPID 060B ANY CHID PMTPID 05DC VPID 05E6
2024/03/28 11:02:33 055F26F1 r (reader) FreeSat_Astra23 [irdeto] Maybe you don't have the entitlements for this channel
2024/03/28 11:02:33 1430C9B5 c (ecm) dvbapiau (0653@000000/0001/3723/3C:AE860CF9512A5D92D18194133DD729D1): not found (55 ms) by FreeSat_Astra23 - Nova Lady (lg)
2024/03/28 11:02:33 1430C9B5 c (ecm) dvbapiau (0653@000000/1B5A/3723/3C:77A1ECB06626D15CF9A392ED90F52445): not found (43 ms) by FreeSat_Astra23 - Nova Lady (lg)
2024/03/28 11:02:34 055F26F1 r (reader) FreeSat_Astra23 [irdeto] Maybe you don't have the entitlements for this channel
2024/03/28 11:02:34 1430C9B5 c (ecm) dvbapiau (0653@000000/1B5B/3723/3C:C21FCDD48594B422BC1FD5FB37625872): not found (58 ms) by FreeSat_Astra23 - Nova Lady (lg)
2024/03/28 11:02:34 1430C9B5 c (dvbapi) Demuxer 0 restarting decoding requests after 3 ms with 1 enabled and 4 disabled ecmpids!
2024/03/28 11:02:34 1430C9B5 c (dvbapi) Demuxer 0 trying to descramble PID 3 CAID 0653 PROVID 000000 ECMPID 060B ANY CHID PMTPID 05DC VPID 05E6
2024/03/28 11:02:34 1430C9B5 c (ecm) dvbapiau (0653@000000/0001/3723/3C:AE860CF9512A5D92D18194133DD729D1): not found (3 ms) by FreeSat_Astra23 - Nova Lady
2024/03/28 11:02:34 1430C9B5 c (ecm) dvbapiau (0653@000000/1B5A/3723/3C:77A1ECB06626D15CF9A392ED90F52445): not found (2 ms) by FreeSat_Astra23 - Nova Lady
2024/03/28 11:02:35 1430C9B5 c (ecm) dvbapiau (0653@000000/1B5B/3723/3C:C21FCDD48594B422BC1FD5FB37625872): not found (16 ms) by FreeSat_Astra23 - Nova Lady
2024/03/28 11:02:35 1430C9B5 c (dvbapi) Demuxer 0 restarting decoding requests after 3 ms with 1 enabled and 4 disabled ecmpids!
2024/03/28 11:02:35 1430C9B5 c (dvbapi) Demuxer 0 trying to descramble PID 3 CAID 0653 PROVID 000000 ECMPID 060B ANY CHID PMTPID 05DC VPID 05E6
2024/03/28 11:02:35 1430C9B5 c (ecm) dvbapiau (0653@000000/0001/3723/3C:AE860CF9512A5D92D18194133DD729D1): not found (3 ms) by FreeSat_Astra23 - Nova Lady
2024/03/28 11:02:35 1430C9B5 c (ecm) dvbapiau (0653@000000/1B5A/3723/3C:77A1ECB06626D15CF9A392ED90F52445): not found (3 ms) by FreeSat_Astra23 - Nova Lady
2024/03/28 11:02:36 1430C9B5 c (ecm) dvbapiau (0653@000000/1B5B/3723/3C:C21FCDD48594B422BC1FD5FB37625872): not found (3 ms) by FreeSat_Astra23 - Nova Lady
2024/03/28 11:02:36 1430C9B5 c (dvbapi) Demuxer 0 restarting decoding requests after 3 ms with 1 enabled and 4 disabled ecmpids!
2024/03/28 11:02:36 1430C9B5 c (dvbapi) Demuxer 0 trying to descramble PID 3 CAID 0653 PROVID 000000 ECMPID 060B ANY CHID PMTPID 05DC VPID 05E6
2024/03/28 11:02:36 055F26F1 r (reader) FreeSat_Astra23 [irdeto] Maybe you don't have the entitlements for this channel
2024/03/28 11:02:36 1430C9B5 c (ecm) dvbapiau (0653@000000/0001/3723/3C:6D5F10B48F0C743F74F9F4AC3685F766): not found (42 ms) by FreeSat_Astra23 - Nova Lady (lg)
2024/03/28 11:02:36 1430C9B5 c (ecm) dvbapiau (0653@000000/1B5A/3723/3C:8AB22731431B0F254F96C4AB85DD5478): not found (43 ms) by FreeSat_Astra23 - Nova Lady (lg)
2024/03/28 11:02:37 055F26F1 r (reader) FreeSat_Astra23 [irdeto] Maybe you don't have the entitlements for this channel
2024/03/28 11:02:37 1430C9B5 c (ecm) dvbapiau (0653@000000/1B5B/3723/3C:2D7430B198B7C8760A6D780E1FBD11F7): not found (58 ms) by FreeSat_Astra23 - Nova Lady (lg)
2024/03/28 11:02:37 1430C9B5 c (dvbapi) Demuxer 0 restarting decoding requests after 3 ms with 1 enabled and 4 disabled ecmpids!
2024/03/28 11:02:37 1430C9B5 c (dvbapi) Demuxer 0 trying to descramble PID 3 CAID 0653 PROVID 000000 ECMPID 060B ANY CHID PMTPID 05DC VPID 05E6
2024/03/28 11:02:37 055F26F1 r (reader) FreeSat_Astra23 [irdeto] dvbapiau emmtype=global, len=13 (hex: 0x0D), cnt=0: written (28 ms)
2024/03/28 11:02:37 055F26F1 r (reader) FreeSat_Astra23 [irdeto] dvbapiau emmtype=shared, len=63 (hex: 0x3F), cnt=0: written (70 ms)
2024/03/28 11:02:37 1430C9B5 c (ecm) dvbapiau (0653@000000/0001/3723/3C:6D5F10B48F0C743F74F9F4AC3685F766): not found (75 ms) by FreeSat_Astra23 - Nova Lady
2024/03/28 11:02:37 1430C9B5 c (ecm) dvbapiau (0653@000000/1B5A/3723/3C:8AB22731431B0F254F96C4AB85DD5478): not found (3 ms) by FreeSat_Astra23 - Nova Lady
Dal poděkování: 5 poděkování
Pavel74 píše: 28 bře 2024, 11:07 Ještě jsem zjistil že některé programy mi neběží - například Nova Lady, Prima Krimi
zde je log
pokial NovaLady nebezi uz pod Layer2b, tak tento ChID by mal dekodovat dany program
Tak jsem nahrál novou verzi a stále mi neběží z celé nabídky 6 programů - Nova Lady, Prima Krimi, Prima show, Prima star, ...
Unix starttime: 1712747753
Starttime: 10.04.2024 13:15:53
Version: oscam-1.20_svn-r11734-799
Compiler: mipsel_cak7-icam-l2b_(samur)
PID: 7379
ConfigDir: /etc/tuxbox/config/
WebifPort: 8888
SSL support: no
DVB API read-sdt charsets: yes
Anti-cascading support: no
Debug mode: yes
Monitor: yes
Loadbalancing support: yes
Cache exchange support: no
CW Cycle Check support: no
LCD support: no
LED support: no
Clockfix with realtime clock: no
IPv6 support: no
Built-in SoftCam.Key: no
camd 3.3x: no
camd 3.5 UDP: yes
camd 3.5 TCP: yes
newcamd: yes
CCcam: yes
CCcam share: yes
gbox: no
radegast: yes
scam: no
serial: no
constant CW: yes
Pandora: no
ghttp: no
Reader support: yes
Nagra: yes
Nagra CAK7 (Merlin/Cameleon/Cayman): yes
Irdeto: yes
Conax: yes
Cryptoworks: yes
Seca: yes
Viaccess: yes
NDS Videoguard: yes
DRE Crypt: yes
TONGFANG: yes
Bulcrypt: yes
Griffin: yes
DGCrypt: yes
cardreader_drecas: no
cardreader_sc8in1: no
cardreader_mp35: no
cardreader_smargo: yes
cardreader_pcsc: no
cardreader_smartreader: yes
cardreader_db2com: no
# oscam.conf generated automatically by Streamboard OSCAM 1.30_svn SVN r11752-800
# Read more: https://svn.streamboard.tv/oscam/trunk/ ... m.conf.txt
[global]
logfile = /tmp/oscam.log
nice = -1
waitforcards = 0
readerrestartseconds = 1
lb_mode = 1
lb_save = 100
lb_nbest_readers = 2
lb_nfb_readers = 4
lb_min_ecmcount = 3
lb_reopen_seconds = 120
lb_reopen_invalid = 0
lb_retrylimit = 200
lb_stat_cleanup = 24
lb_max_readers = 4
ecmfmt = P: c:p:s:d:i: #ECM_L:l #CW=w HOP:j
disablecrccws_only_for = 1811:003311,003315;098D:000000;0500:030B00,042820;0604:000000;1819:00006D;0100:00006D;1810:000000;1884:000000;0E00:000000
[cache]
[newcamd]
port = 7701@0000:000000
key = 0203040506050403020304050605
mgclient = 1
[cccam]
port = 7702
nodeid = E565A20D109514D2
version = 2.3.0
[streamrelay]
stream_relay_enabled = 1
stream_emm_enabled = 5
stream_relay_ctab = 098D,09CD
[dvbapi]
enabled = 1
au = 1
pmt_mode = 6
request_mode = 1
delayer = 60
ecminfo_type = 4
user = dvbapiau
read_sdt = 1
write_sdt_prov = 1
extended_cw_api = 1
[webif]
httpport = 8888
httprefresh = 10
httppollrefresh = 10
httphidetype = sh
httppiconsize = 30
httpshowmeminfo = 1
httpshowuserinfo = 1
httpshowreaderinfo = 1
httpshowcacheexinfo = 1
httpshowecminfo = 1
httpshowloadinfo = 1
httpallowed = 127.0.0.1,192.168.0.0-192.168.255.255,10.0.0.0-10.255.255.255,255.255.255.255
http_status_log = 1
[reader]
protocol = internal
device = /dev/sci0
caid = 0653
rsakey = 1B4368AD00D5AE23977576FCB202D84897994B358F006B42CB4BCC2301D1FAE2BCF4C397ED4DC7DE6DCE4A1A3D88682DB672827831FA8E6B6E29E7AD37D0A21F
force_irdeto = 1
needsemmfirst = 1
detect = cd
mhz = 450
cardmhz = 2700
group = 1
emmcache = 1,3,15,0
disablecrccws = 16,
LOG
2024/04/10 13:29:53 106D8FDB c (ecm) dvbapiau (P: 0653:000000:3723:060B:1B5B: #ECM_L:3C #CW=00000000000000000000000000000000 HOP:00): rejected group (1 ms) - Nova Lady (no matching reader)
2024/04/10 13:29:54 106D8FDB c (-) -- Skipped 1 duplicated log lines --
2024/04/10 13:29:54 106D8FDB c (dvbapi) Demuxer 0 restarting decoding requests after 2 ms with 2 enabled and 3 disabled ecmpids!
2024/04/10 13:29:54 106D8FDB c (dvbapi) Demuxer 0 trying to descramble PID 2 CAID 0624 PROVID 000000 ECMPID 0604 ANY CHID PMTPID 05DC VPID 05E6
2024/04/10 13:29:54 00000000 >> OSCam << cardserver log switched, version 1.20_svn, build r11734-799 (mipsel_cak7-icam-l2b_(samur))
2024/04/10 13:29:54 106D8FDB c (ecm) dvbapiau (P: 0624:000000:3723:0604:A000: #ECM_L:5C #CW=00000000000000000000000000000000 HOP:00): rejected group (1 ms) - Nova Lady (no matching reader)
2024/04/10 13:29:54 106D8FDB c (dvbapi) Demuxer 0 trying to descramble PID 3 CAID 0653 PROVID 000000 ECMPID 060B ANY CHID PMTPID 05DC VPID 05E6
2024/04/10 13:29:55 106D8FDB c (ecm) dvbapiau (P: 0653:000000:3723:060B:0001: #ECM_L:3C #CW=00000000000000000000000000000000 HOP:00): rejected group (1 ms) - Nova Lady (no matching reader)
2024/04/10 13:29:55 7475486E r (reader) FreeSat_Astra23 [irdeto] dvbapiau emmtype=shared, len=63 (hex: 0x3F), cnt=0: written (75 ms)
2024/04/10 13:29:55 106D8FDB c (ecm) dvbapiau (P: 0653:000000:3723:060B:1B5A: #ECM_L:3C #CW=00000000000000000000000000000000 HOP:00): rejected group (0 ms) - Nova Lady (no matching reader)
2024/04/10 13:29:56 106D8FDB c (ecm) dvbapiau (P: 0653:000000:3723:060B:1B5A: #ECM_L:3C #CW=00000000000000000000000000000000 HOP:00): rejected group (1 ms) - Nova Lady (no matching reader)
2024/04/10 13:29:56 106D8FDB c (ecm) dvbapiau (P: 0653:000000:3723:060B:1B5B: #ECM_L:3C #CW=00000000000000000000000000000000 HOP:00): rejected group (1 ms) - Nova Lady (no matching reader)
2024/04/10 13:29:56 106D8FDB c (-) -- Skipped 1 duplicated log lines --
2024/04/10 13:29:56 106D8FDB c (dvbapi) Demuxer 0 restarting decoding requests after 1 ms with 2 enabled and 3 disabled ecmpids!
2024/04/10 13:29:56 106D8FDB c (dvbapi) Demuxer 0 trying to descramble PID 2 CAID 0624 PROVID 000000 ECMPID 0604 ANY CHID PMTPID 05DC VPID 05E6
2024/04/10 13:29:57 106D8FDB c (ecm) dvbapiau (P: 0624:000000:3723:0604:A000: #ECM_L:5C #CW=00000000000000000000000000000000 HOP:00): rejected group (1 ms) - Nova Lady (no matching reader)
Pavel74 píše: 26 bře 2024, 14:20 2024/03/26 14:10:13 12AD2A48 r (reader) FreeSat_Astra23 [irdeto] chid: 1B59, date: 2024/03/25 - 2024/04/25
Pavel74 píše: 10 dub 2024, 13:30 2024/04/10 13:29:56 106D8FDB c (ecm) dvbapiau (P: 0653:000000:3723:060B:1B5B: #ECM_L:3C #CW=00000000000000000000000000000000 HOP:00): rejected group (1 ms) - Nova Lady (no matching reader)
bud nemas zaplatene/aktualizovane alebo uz nebezi pod static mode
Zaplacené to mám, jsou to programy ze základní balíčku. Přes internet jsem provedl i znova aktivování karty.
Jediné co mě napadá, a nevím. Jestli to dokáže dekódovat VU zero s kartou nebo jestli nemusím zakoupit nějakou čtečku karet.
drenem
Příspěvek od drenem »
skusit pouzit novu mips verziu od samura OSCam-11759-801 miesto starej "oscam-1.20_svn-r11734-799" a vymazat rsa a boxkey z readera
Zpět na „Oscam“
