Druhý Tuner v E2
Re: Druhý Tuner v E2
nie- myslel som tym,ze ide rozbalit aj ta usb verzia -rotsfs .
Inak - Oscam funguje - dual decode ti poviem, ked aktivujem PIP .
Ten prednastaveny skin treba zmenit za brusheadalu skin. Ide na AAF a aj HDF -korektne. Je sice trosku pomalsi, ale zas ide.
Odkial si stahoval Oscam ? to si si tam dal vlastnu vyrobu ?
ufs910 ma byt pre IPboxHD , my pouzivame typ dbox2 . Cita z oboch citaciek .
takze PIP - nehrozi. :)
HBO HD ma problem - najskor som myslel,ze je to vykreslovanim titulkov, lenze tam je problem aj pri programe bez titulkov- trhany pohyb,prerusovane audio .
Ide sa odlahcovat - zakazeme start CIFS file system, start bootloga a podobnych kraviniek - co nepotrebujeme.
dalsia zaujimavost - horna citacka na sci1 ma nizsiu latenciu - pohybuje sa okolo 160ms, kdezto primarna spodna sci0 nad 200ms .
skusime to taktovanie, ale oscamaci tvrdia,ze cim vyssia frekvencia lokalneho oscilatora- tym dlhsie odozvy - co by teoreticky malo byt opacne,ze ?
Ale zas 1000 nemusime ist, nam staci 600 , nepotrebujem karty hned odpalit. este sa zidu .OVERCLOCKING
Dreambox and other internal readers
For Dreambox and other internal readers the highest possible clock
rate will be auto detected. The mhz parameter lets you override the
values chosen by OSCam, if it differs from 357 and 358, but usually
you will not set any value for mhz.
For certain Dreamboxes (especially PPC clones) the default mhz
parameter leads to slow ECM times and/or "not found" ECMs. By set
ting mhz to values like 200, 300, 400, ... 1600 you can find a value
that works for your receiver and your card. The higher the mhz
value, the slower the ECM time (strange enough).
If you choose the value too low, your card is not recognized (no ATR
or "card not supported"). If you choose the value too high, you get
slow ECM times. Our experience is that either no mhz line, or a line
mhz = 1000 works best.
OSCam tries to set the baudrate automatically. A standard serial port
has limited baudrate settings, so SC overclocking might not work. When
using a serial reader the best way for overclocking is connecting it to
a FTDI based USB to serial port adapter.
If overclocking does not work, verify the effective baudrate in the
logfile. If it deviates too much from the requested baudrate, the SC
will not be recognized (no ATR) and the value for mhz should be
adjusted again. The higher the baudrate, the more accurate the effec
tive baudrate can be.
nejak extra stabilny image to ale nieje. Mam uz v korenovom dva crash.logy . Pri restarte GUI nepripoji tunery , treba tvrdy restart pouzivat. Obavam sa ako potom dopadne casove nahravanie z hlbokeho spanku...
k tym citackam - 6,00MHZ ma celkom priaznivy vplyv na odozvu - dostal som sa pod 120ms, co je viac ako dostacujuce. Samozrejme na hornej - spodna je nejaka leniva.
mmirousek
stahl jsem si co nabízí ho ipkg list. Upravil jsem jen oscam.server a použilgrantec píše:nie- myslel som tym,ze ide rozbalit aj ta usb verzia -rotsfs .
tvůj oscam.conf co jsi tady někde zveřejnil. No nic zítra ještě otestuju znovu.
čítačky mě ani tak moc nezajímají, nemám žádnou kartu. U mě je primární
share z newcamd. USB disk se ti připojí ? mě to přes mountmanager nešlo
i když je v systému vidět (fdisk -l) a ručně se připojil (mount /dev/sdb1 /hdd).
ale nešlo na něj nahrávat. Ale možná je problém že jsem neaktualizoval , jak jsi psal výše.
- dempsey
Tak ja som to skúsil tak že som oscam stiahol ako plugin. Grantec upravil conf - stiahol som a zmenil skin na alu a potom spustil oscam a reštartol box. Skylink ide /0D03/ a docela svižne :)
Jasne,ale vcera som to daval asi pre klasicky fw, ci nie ? Uz ani neviem. Klasicky fw ide na STAPI - tam je typ boxu pre nas udf910 , enigma ide na dvbapi a tam je pre nas typ boxu dbox2 .mmirousek píše:stahl jsem si co nabízí ho ipkg list. Upravil jsem jen oscam.server a použil
mmirousek
použil jsem tento: viewtopic.php?f=222&t=5064#p40718
no už se těším dom. Jak vidím už je i AAF, to zas bude drahá polovička bručet :lol:
mmirousek
dempsey píše:Tak ja som to skúsil tak že som oscam stiahol ako plugin. Grantec upravil conf - stiahol som a zmenil skin na alu a potom spustil oscam a reštartol box. Skylink ide /0D03/ a docela svižne :)
No pokud rozumím , tak jsi rozjel akorát kartu ve čtečce pře oscam.
Já dnes zkoušel rozjet jen napojení na newcamd server a to se nezadařilo.
- dempsey
Áno v čítačke. Večer sa skúsim pripojiť na niečo zvonku.
mmirousek
No nevím kde soudruzi z NDR udělali chybu. Dnes jsem nahodil nové AAF + update přes AAF panel.grantec píše:takze PIP - nehrozi. :)
Doladil HBO HD. Přes Mgcamd135 se napojil na newcamd server a krom toho že dual decode jak jsem
očekával nejde , tak HBO HD trhané jako slideshow. Takže stejný problém jako jsi měl u HDF. Ostatní HD normální.
Zkusil jsem i zde rozběhat Oscam jako klienta newcamd - bezúspěchu.
v tych enigmach je vzdy rovnaky zaklad , teda neutrino. ak uvedene specifikum nieje zvladnute v zaklade , nemoze fungovat ani v modifikovanych verziach. V zaklade sa s tym ale moc spekulovat neda- jedine snad s pomocu CI modulu a karty. Momentalne riesim novy 2TB disk, ktory ma realne len cosi 1.826 TB :) , takze sa s tym trochu zdrzim ,aj ked nema tie 2TB. Hroza, co vsetko dnes ludia potrebuju .
mmirousek
hehe, to neřeš , jak rostou velikosti disků , tak roste potřeba je mít.
Pamatuji když jsem v hluboké minulosti koupil 500MB disk za 14tis. a myslel
jsem si jaký jsem frajer s obrovskou kapacitou :lol: , teď mám v bedně
4TB a pořád mám nedostatek místa. HD filmy, HD seriály to si cosi obsadí
a když člověk nemá čas se na to hned podívat , disky se rychle plní.
mmirousek
ahoj, už jsi se k tomu dostal to zkusit ?dempsey píše:Áno v čítačke. Večer sa skúsim pripojiť na niečo zvonku.
- dempsey
Mal som v kuse zapnutý Vitamin kôli testu, ale môžem to teraz skúsiť.
- dempsey
Nerozchodil som to.Venoval som tomu asi pol hodinku a nestačilo to
