Editor settingu pre Coolstrem - pre 32bit a 64 bit WIN.
V menu nastaveni treba zvolit typ image - NEUTRINO .
Dreamset - editory zoznamu programov
Pluginy a utility pro přijímače Coolstream ZEE, NEO a Twin.
- matchboxx
Dreamset 2,34
Dreamset 2.34
setting zvolit pro
coolstream HD
neutrino v.3
můžete si také překonvertorovat Vaše settingy pro dreama, vu na formát pro coolstream
setting zvolit pro
coolstream HD
neutrino v.3
SecretPrivat.com - Don't hesitate
- matchboxx
Dogsettings
zajimavy editor i pro Neutrino HD, mozna lepsi nez Dreamset
- matchboxx
dreamset 2.36
Dreamset is a settings editor for digital satellite receivers running Enigma 1, Enigma 2 and Neutrino Plus firmwares like DreamBox. Triple Dragon receivers are also supported.
You can use Dreamset to edit Settings of the following formats:
Enigma-1
Enigma-2(Satellite/Cable/Terrestrial)
Neutrino NPlus
Triple Dragon
Also Dreamset can open and import settings of the following formats:
DGStation/Relook 200s/400s (dat)
Nokia 9800s/9902s Files (m98)
LyngSat script files (dat)
SatcoDx(sdx)
DVB (dvb)
Humax (hnf)
Dreamset offers a user friendly interface with a plethora of usefull operations which make settings modification easier.
Add,Change,Delete bouquets and favorite lists
Reorganize services in bouquets and favorite lists
Add,Change,Delete services,transponders,satellites
Flexible User Interface, multiple selection and Drag & Drop.
User defined Sorting of services in a list/bouquet and other sorting operations
Multilanguage support for names(Unicode Support).
Markers support.
Clipboard Copy/Paste of lists,services,channels,transponders (you can copy.paste from one Dreamset to another)
Import Favorite Lists from other settings like DreamBox,Nokia 9800,Humax.
Convert settings to other supported formats.
Multilanguage User Interface support.
DreamBox configuration editor (advanced).
Custom telnet and http commands
Dreamset can minimized to tray, right cklick to Dreamset Icon popups a menu with basic operations
Multibox Configuration, you can define more then one box and switch between them at once.
Signal monitor and DiseqC motor control from dreamset (dreambox plugin is installed in your box) only for Enigma 1 and Neutrino
verze 32bit
http://www.dreamset-editor.com/files/dreamset236.zip
verze 64bit
http://www.dreamset-editor.com/files/dreamset236x64.zip
Enigma-1
Neutrino NPlus
Triple Dragon
SatcoDx(sdx)
DVB (dvb)
Humax (hnf)
Markers support.
verze 32bit
verze 64bit
- matchboxx
Dreamset 2.39
19/5/2013 - ver 2.39
Fixed: Stream services
Fixed: Sort services (affects auto markers on internet settings also)
Fixed: Picons on HD services
pro w32bit a 64bit v priloze
pro neutrino idealni
Zpět na „Coolstream ZEE, NEO a Twin - Pluginy a utility“
