nový fw?
- satelit1
nový fw?
zajímalo by mě kde vázne nový fw na HD-BOX
na Octagon vyšly již dva nové:
OCTAGON_SF1008_SEplus_HD_INTELLIGENCE_V21022-CIplus__07_03_12
OCTAGON_SF1008_SEplus_HD_INTELLIGENCE_V21024-CIplus__14_03_12
má někdo aktuální info?
děkuji
děkuji
supersat
Re: nový fw?
To jsou vesměs změny pro CI plus , soft bude brzy , pokud chcete přispět svou trochou do mlýna tak ...:
We will release official S/W this week and there will be added Internet Radio+ like Internet TV+.
At the moment, the url address is not possible to be installed by USB, so we would like to pre-installed popular web radio url address inside S/W.
If you have some reference data, you may give us some examples as following format till this afternoon.
Ex] Title : Fortis Radio.
URL : http://zoo.inlive.co.kr:8080
Description : Fortis FM Classic Music.
Category : you can choose among News, Music and International
005jon
- Dostal poděkování: 209 poděkování
Re: nový fw?
[TITLE]
Deluxemusic.tv
[URL]
rtmp://flash.cdn.deluxemusic.tv/deluxemusic.tv-live/web_850
[DESCRIPTION]
music.tv-
Noro C
Re: nový fw?
Tie adresy asi si kazdy vlozi aj sam lepsie by bolo keby zapracovali steam moznosti pozert tv cez pc z prijmaca ako je u e2
- satelit1
Re: nový fw?
na Octagon opet novej a na HD-BOX opet nic
Readme_OCTAGON_SF1008_SEplus_HD_INTELLIGENCE_V21028__23_03_12
for Octagon HD SF 1008 SEplus HDTV - INTELLIGENCE :
Changes :
- Upgrades & Imporvements :
--> Before Start update pls. stop PlugIns !
--> Weather Forecast function add.
--> Web Radio (Internet Radio+) function add.
--> Series Recording improved
--> Series Recording icon add. to EPG [S]
--> Voulume not working in specific channel solved
--> No Subtitle in BBC World channel solved
--> Tivusat Card Freezing solved
--> Poor SD quality in LED TV improved
--> DVB-T CH LCN not working well solved
--> DVB-T Signal overlapped search solved
--> Terrestrial CH Scan Hotkey Support add.
--> STB Hangup after Pausing and CH Up & Down solved
--> Dissapearing the setting when CI+ message shows solved
--> CI+ Popup Message for Sericelist Manager disabled
--> DVB-C Cable Frequency add.
--> Eternal CI Standard initializing message solved
--> Defult timer setting value changed to Recording
--> DVB-C Service watching & Recorded file play playback problem solved
--> Hang up in continuous EPG in specific channel Solved
--> Noise & Picture Fall-out on certain TV set solved
--> Dolby Digital setting issue solved
--> Background color of Subtitle language changed
--> Freezing with quick zapping solved
--> Cyfra mhw epg doesn't work solved
--> Diverse minor bugs fixed
--> [WebZeal Ver 2.7s / 2.7su ]
--> Arabic QWERTY Keyboard Map add.
--> Available to use English Character with Right Alt key add.
--> Hebrew Language Text Search add.
Changes :
Noro C
Re: nový fw?
Tak si z hdboxu urob octagon je to jednoduche a mozes testovat ako ja
- satelit1
Noro C
Noro C
Re: nový fw?
Tak ze testujem zatial ide ok pribudlo internet radio a pocasie a stabilita sa uvidi casom
- satelit1
supersat
Re: nový fw?
satelit1 píše:z HD-BOXu lze jiz stahnout pres net novej fw 2.10.28
To že si člověk pomalu už ani do kostela nemá část zajít , abychom to měli na stránkách rychleji než Turci z Octagonu ?
