Aktualizácia - enigma2
005jon Slovakia
Příspěvek od 005jon »
Aktualizácia - enigma2 23.05.2017
To čo sa udialo za posledne 3 dny :89:
enigma2: 4.3.1r7
- allow to downscale with factors up to 225
- eMediaDatabase/DatabasePlaylist: allow to presizing cover arts, use 300x300 as default
- fixed linked and "satpos depend" tuner handling
- fixed motor turning with enabled power measurement
(broken since 4.3.1r5)
enigma2: 4.3.1r6
- fixed DVB-T(2) namespace problem
- fixed satfinder crash on change from predefined to manuel transponder
introduced in 4.3.1r5
- allow to input DVB-S(2) frequencies with one decimal place
needed to lock transponders with very low symbol rates
enigma2: 4.3.1r5
* updated all translations to latest pootle (2017-05-18)
* fixed ATSC DDP (AC3+) detection (IPTV streams)
* Scan/Tuners
- fixed DVB-S2 FEC selection in manual scan
- fixed some issues with DVB-S2 MIS/PLS code/mode handling
- show auto FEC, auto modulation, PLS, MIS settings in satfinder and positioner setup
- don't show DVB-S2 PLS/MIS settings/infos when the tuner does not support it
- fixed tuning on APSK16/32 transponders in some cases
- fixed DVB-T(2) 5V handling for combo tuners
- added "rotor turning speed in degree" option for motor-driven antennas
and use it for blindscan (to avoid foreign sat locks)
- allow the same service on different frequencies for DVB-T(2)
(for regions with multiple transmitters in reach)
dreambox-dvb-modules: update hardware drivers for dm900, dm820, dm7080
- silabs based tuners:
- improved combo tuner detection (dm820/dm7080)
- longer tune timeout when the symbolrate is lower 1000 (DVB-S/S2)
only interesting for channel searching
- dont return outdated SNR values until demod has no carrier lock
- add debug output for carried/final lock and timeout
- PositionerSetup: fixed crash when no transponder is tuned
* CeC: added very tiny vendor handler for Philips
* Movie Player: added a minimum treshold before we consider resuming playback (configurable)
* fixed broken IPv6 manual configuration
* fixed database based cover arts not showing up in MediaCenter/Audio
* fixed crash in MediaCenter/Video when switching between movies quickly (need some feedback on this)
For Developers:
* eServiceReference: fixed some issues with parsing of additional headers
* stop generating and using the index-meta files in favor of building a full index on (softwaremanager) startup based on all available plugin meta files
bambule
Profík
Profík
Re: Aktualizácia - enigma2
Příspěvek od bambule »
To je pro Dreambox?
Thomik1 Czech Republic
Dal poděkování: 34 poděkování
Příspěvek od Thomik1 »
bambule píše:To je pro Dreambox?
Když je to v sekci Diskuze Dreambox DM 900 HD Ultra 4K tak to asi nebude pro diway ? :D :D
bambule
Profík
Profík
Thomik1 píše:
........omluva ale v apple iphone SE......špatne videt jen obsa....priji....drea....disk ......prohližeč safari.
bambule
Profík
Profík
a to je podpora pro dm 900 a triple tuner?
bambule
Profík
Profík
dreambox-dvb-modules: update hardware drivers for dm900???
005jon Slovakia
Aktualizácia - enigma2 21.06.2017
To čo sa udialo za posledne 2 dny
-enigma2-defaultservices: update
-enigma2: fixed possible crash in manual scan
-dreambox-dvb-modules: update dm7080, dm820, dm900 hardware drivers
- longer tune timeouts for si2166b / si2169c / bcm4505 / bcm4506, optimized afc range for silabs tuners
enigma2: 4.3.1r8
- fixed sometimes broken stored unicable SCR values in config file
- fixed CEC handling on shutdown
- fixed rarely broken tuner on weak input signals
- add 16APSK/32APSK to ServiceScan info screen
- fixed broken scaling on edge cases (broken since 4.3.1r7)
- fixed alpha animation flickering
- fixed wrong stored transponders
- fixed crash in network manager cauased by a broken french translation
- optimized rounding of frequency and symbolrate in blindscan
005jon Slovakia
8 Aug 2017
enigma2: 4.3.1r13
- use colon as hour delimiter instead of a single point in multiepg
- multiepg fixes
- removed unneeded and not working combo pls scrambling support in single transponder service scan screen
- dont seek twice to position 0 on start of ts playback
- updated translations
- added support for some new jultec jess switches
4 Aug 2017
python-youtube-dl: bump version to 2017.07.30.1
Tue, 1 Aug 2017
enigma2: small cosmetical fix
1 Aug 2017
enigma2: update to 4.3.1r12
- fixed memory leak (seen on mkv playback with MP3 audio and much tags inside)
- fixed motor turning when the previous transponder was in high band (22khz was enabled)
- allow to override HDR10 and HLG support reported by connected AVR/TV via EDID in AV Setup
- allow to disable the use of 12bit and 10bit via AV Setup... 12 bit is unneeded because
no content with 12bit exists yet.
- add possibility to show a HDR icon in skin via ServiceInfo Converter and "isHdr" as conversion
- allow auto modulation in manual scan for BCM45208 and BCM73625(dm520x)
- allow blindscan (only Symbolrates > 10Ksyms) for BCM45208
- fixed DVB-S(2) "canTune" test for combo tuners when cable/terrestrial is used on the first channel, and the second DVB-S(2) channel is looped to the first channel
1 Aug 2017
dreambox-dvb-modules: update dm52x hardware drivers
- add some debug output for DVB-C/T(2) onboard tuner
- add auto modulation support for DVB-S2 to onboard tuner
- add longer tune timeouts for better low SR support with DVB-S(s) onboard tuner
- non critical pcr audio fix
1 Aug 2017
dreambox-dvb-modules: update dm900 hardware drivers
- allow to override HDR10 / HLG settings reported by EDID
- allow to disable 12bit and 12bit video mode
- send video mode changed event when content eotf changed (hdr ... no hdr)
18 Jul 2017
golang-plaincast: switch from com.dreambox to de.dreambox
1 Aug 2017
gstreamer1.0-plugins-base: fixed strange gstreamer critical warnings on media playbac...
gstreamer1.0-plugins-base: fixed strange gstreamer critical warnings on media playback with subtitles
(https://bugzilla.gnome.org/show_bug.cgi?id=748809)
