fw 0.9.3661
monkus Slovakia
fw 0.9.3661
Příspěvek od monkus »
OpenSAT is proud to present
AZBox HD Firmware - rev. 0.9.3661
(2009.10.23)
http://server.az-box.co.uk/0.9.3661/patch.bin
neviem, ci je public, ak nie, nepouzivajte ho :-)
RELEASE NOTES
# FIXED
- Correct a bug regarding the message for screen capture.
- Correct a bug, do not proceed the progress bar at FTP up/download.
- Correct a bug when it occured the FTP login was failed.
- Correct some bugs of the file manager: Icon images / Multi language messages
- Correct a bug regarding DVB-T&C TS discriptor.
- Correct the gritch noise bug on the HDMI audio.
- Correct a bug regarding the setup display options.
- Correct the bug regarding LEDs on the front panel (AZBox Premium)
- Correct the alphabetical sorting bug of the favorite channel list
- Correct the bug to remember the last channel.
- Correct the scan SAT bug
- Correct the TV buffering problem.
- Correct the MKV player bug whick is not displayed videos
- Correct the time display problem at MKV player
- Correct a memory leak at the new audio driver
- Correct the audio bug which is occuring when the radio was played long time
- Correct the video bug which regarding display mode like as pan & scan display
- Correct a fast forward problem to go forward faster.
- Upgrade the YouTube player
# ADDED
- Add new driver for better A/V performance (under testing)
- Add a function to insert many function keys on the USB keyboard.
- Support multi-audio of TS files.
- Add subtitle ID and audio ID at the individual channel.
- Add a decoder recovery routine for correct the radio distortion bug.
- Add a function to be able to select the Dolby output mode (Line mode / RF mode)
- Add scripts when called at standby and wakeup
/DISK2/etc/standby.sh
/DISK2/etc/wakeup.sh
- Add new driver for Samsung ATSC tuner.
- Modify the azbox SDK and test application
- Add a radio wallpaper register module
- Add the page up/down function at file manager.
- Add a information bar for ATSC
# IMPROVED
- Modify the main menu position.
- Modify the DEMUX structure to be able to parse several PMTs in the same time.
- Increase IPTV ability to get several types of streams.
- Modified for EPG
+ EIT pool
+ EIT filters
+ Memory Pool
+ Memory menager etc.
- Modify the EIT parser to add a function regarding ATSC
- Modify the scanning PMT method for using multiple PMT filters.
- Optimization of the DEMUX_INFO structure for using the multiple PMT parser at movie player.
- Apply the multiple PMT parser at the movie player.
- Optimization the memory of the audio player.
- Support VBR at the MP3 player
- Modify web browser and RSS news cause by change the driver.
- Modify to set subtitle at center
- Modify to display full screen at photo viewer.
- Change some video decoder options to solve the mkv file player problems
- Change some audio decoder options to solve the glitch noise problems
- Change the recording file size to 4GB from 3GB (will be changed next release to detect the max file size from system)
- Modify the network setting timeout for wifi to 1 minute from 30 seconds.
Best Regards,
The OpenSAT/AZBox Team
paleaaro
Re: 0.9.3661
Příspěvek od paleaaro »
Vidim ze to delenie nahravok este nieje poriesene.
bibibo
Re: 0.9.3661
Příspěvek od bibibo »
Všetko pekné, že vychádza nový firmware raz za mesiac, ale zachitil niekto info kedy budú riešiť podporu druhého DVB-S2 a multitasking ? Asi zabudli čo slubovali.
Benny
Re: 0.9.3661
Příspěvek od Benny »
Vsichni si stezujou ze nejde DTS. Posrali to uz v predchozim FW, predtim to normalne slo a ejhle vyjde novy FW a stale nejde. Hovada, jinak uz to nazvat nelze. Vetsi fotky stale beze zmeny .....
Re: 0.9.3661
vsetko ma svoje priority a postupne verim ze to pojde k lepsiemu.
prve postrehy:
youtube OK
mkv mi uz idu vsetky, aj tie, ktore nesli vobec, alebo bez obrazu.
paleaaro
Re: 0.9.3661
Ako je to s rychlostou prepinania kodovanych stanic a reakciami?
Re: 0.9.3661
Niektorí testeri vôbec netestujú a tak asi prehodnotíme ich status na fóre...
Re: 0.9.3661
První dojem je dobrý.
PanScan - opraveno.
Youtube - opraveno.
MKV jedou všechny co mám, předtím některé nešly.
Nahrává, sdílí, nepadá.
Jdu zkoušet dál.
paleaaro
Re: 0.9.3661
dempsey píše:Niektorí testeri vôbec netestujú a tak asi prehodnotíme ich status na fóre...
ak to bolo na moju adresu tak to chcem vediet len koli tomu lebo momentalne som do 22:00 v praci, cize testovat tazko mozem.
Vyskusam az ked pridem domov.
tommix Slovakia
Re: 0.9.3661
Příspěvek od tommix »
USB bezdrôtová klavesnica - pridané ďaľšie funkcie. Už sa dájú ovládať skoro všetky funkcie.
AZBOX KEYBOARD
Zap - F12
Vyp - F11
Home - Home
Exit - Esc
You Tube - F5
Info - Shift + ;
Mute - Space
Rec - F10
Menu - Tab
Guide - ;
R (SUBT) - F1
G (TEXT) - F2
Y (LANG) - F3
B (i-KEY) - F4
Search - Insert
Caps/Num - <---
Check - Delete
Hľadanie EPG - Insert
Opencas - Shift + ä (angl.])
Naposledy upravil(a) tommix dne 26 říj 2009, 18:19, celkem upraveno 2 x.
AZBOX Premium
Tuner B : motor SG 2100
Tuner C : DVB-T
Re: 0.9.3661
Benny píše:Vsichni si stezujou ze nejde DTS. Posrali to uz v predchozim FW, predtim to normalne slo a ejhle vyjde novy FW a stale nejde. Hovada, jinak uz to nazvat nelze. Vetsi fotky stale beze zmeny .....
ja neviem, ale mne DTS ide. Teda z mkv filmu.
-pri prepinani programov uz necvaka zvuk :)
bibibo
Re: 0.9.3661
Dempsey, Tebe tuším za to platia aby si bránil AzBox za každú cenu. Podľa mňa je to nemysliteľné aby prebiehali stále testy aj keď sa AzBox už dávno predáva koncovým zákazníkom. To isté platí aj pre neoficiálne firmware. Neoficiálny asi ostane naveky. Takýmto tempom bude AzBox zachvíľu zastaralím prístrojom a konkurencia ho prevalcuje novými.
Benny
Re: 0.9.3661
vikino píše:
Tak to ses asi jedinej komu DTS jde jak ma. Vzhledem k tomu ze i na oficialnim foru priznali ze DTS nefunguje tak nevim jak si to dokazal....
Benny
Re: 0.9.3661
bibibo píše:
Osobne ani netusim na co status tester je kdyz naprosto bezny uzivatel ma pristup ke stejnym vecem.
20hdi4007
Re: 0.9.3661
Příspěvek od 20hdi4007 »
Tak jsem také nainstaloval a první poznatky
:HDMI a zvuk u Philipse vyřešeno :106:
IPTV stále neumí viz. odkaz http://streaming.o2active.cz/budejovice_vyssi ----------škoda, doufám že ten odkaz není reklama
mírné zlepšní u prohlížeče
Naposledy upravil(a) 20hdi4007 dne 26 říj 2009, 20:17, celkem upraveno 1 x.
AZBOX HD Premium, fw 0.9.3877,SG2100,Philips 37PFL9732D/10.
