fw 0.9.3877
St.
fw 0.9.3877
Příspěvek od St. »
V update listu je novy fw 0.9.3877
Re: 0.9.3877
kua- sak to clovek nestiha menit....
ericek74
Re: 0.9.3877
Příspěvek od ericek74 »
OpenSAT is proud to present
AZBox HD Firmware - rev. 0.9.3877
(2009.11.20)
RELEASE NOTES
# FIXED
- Redraw routine for subtitle when the drawing fails.
- Corrected an issue when some movies are restarting play in Movie player.
- Corrected the continues play bug in Music Player.
- Corrected the large artwork bug in Music Player.
- Corrected an audio play bug when using Photo Slide Show
- Corrected the duration time issue in Movie Player.
- Corrected a bug regarding the single EPG.
- Corrected some bugs regarding photo viewer (zoom in/out, rotation, move, etc.)
- Corrected a problem related to the bookmark function and high bitrate movies.
- Corrected a problem with the play time in YouTube.
- Corrected a VFD problem regarding accent characters
- Corrected a problem when some GUI elements were overlapping (TV module).
# ADDED
- Added the ability to delete a group of channels in the channel manager.
- Added some setup functions in the movie player.
- Added language selection in teletext.
- Added the 'all' option in the backup/restore feature
- Added a jump key in File Manager.
- Added a possibility to show the play or remaining time in the VFD.
- Added more GMT offsets
- Added 480i video resolution for component and HDMI video output.
# IMPROVED
- Increased the channel zapping speed
- Better detection of the duration time of MP3 files (when file includes artwork).
- Increased the video quality by correcting the mosaic problem at movie player.
- Changed the PAT parser on media player to ensure the stability when parsing multiple PIDs.
- Modified the channel manager to close when a channel was selected.
- Insert some additional info at the recording buffer header.
- Modified the TS parser to extract the exact time from PTS (Movie Player).
- Modified the plug-in message queue for better synchronization and speed.
http://www.azupd.com/0.9.3877/patch.bin
Best Regards,
The OpenSAT/AZBox Team
St.
Re: 0.9.3877
Příspěvek od St. »
jak byla zminovana podpora mysi v browseru, tak jsem ted zkusil pripojit Gyration a ono to jede ;o)
St.
http://www.gyration.com/index.php/us/pr ... emote.html
Hdtv09
Re: 0.9.3877
Příspěvek od Hdtv09 »
...problém v přehrávání se zvukem DTS stále přetrvává(alespoň u mě zvuk vypadává) :cry:
Re: 0.9.3877
zmena v prepinani programov. tab. zmizne hned po prvom kliknuti na channel. netreba klikat 2x.
j3nda
Re: 0.9.3877
Příspěvek od j3nda »
Menu ladeni kanalu uz zase funguje i v cestine a NTFS disky uz to take nacita ok takze horsi nez 093686 to urcite nebude, ted jen aby to odstranilo to zadrhavani zvuku a obrazu - zatim mi to pripada dobry, tak uvidime, pokud by se to povedlo byl by to od dob 092371 dalsi skutecne pouzitelny fw.
Zakoold
Re: 0.9.3877
Příspěvek od Zakoold »
Uz davnejsie som si vsimol ze pri volbe resoluton dialkovym ovladanim ostane vidiet na obrazovke v pravom hornom rohu kusok tej volby.
A nerobi to len v tomto FW ale mislim ze uz od 2371.
A pomoze len reboot.
marek66
Re: 0.9.3877
Příspěvek od marek66 »
Zakoold píše:Uz davnejsie som si vsimol ze pri volbe resoluton dialkovym ovladanim ostane vidiet na obrazovke v pravom hornom rohu kusok tej volby.
Mne nic take nerobi a predpokladam ze ani ostatnym
20hdi4007
Re: 0.9.3877
Příspěvek od 20hdi4007 »
marek66 píše:Uz davnejsie som si vsimol ze pri volbe resoluton dialkovym ovladanim ostane vidiet na obrazovke v pravom hornom rohu kusok tej volby.
Jo,jo mně to taky dělá
AZBOX HD Premium, fw 0.9.3877,SG2100,Philips 37PFL9732D/10.
schmegea
Re: 0.9.3877
Příspěvek od schmegea »
Ta tečka tam zůstává i mě. Zmizne až při rebootu, tlačítko resolution proto od září už nepoužívám.
j3nda
Re: 0.9.3877
potvrzuji taky mi to dela a pri pouziti vetsiho pisma mi tam zustava nejen tecka, ale vetsi kus nabidky i na prave strane, ale to pro me neni az tak zasadni, take se mi stavalo kdyz jsem se dlouho hrabal v menu nastaveni satelitu, ze se mi nabidka prekreslovala pres sebe, ale reboot pomohl
VraKo
Re: 0.9.3877
Příspěvek od VraKo »
Funkci tlačítka Resolution bych raději předělal na přepínání formátu obrazu 16:9, 14:9, 4:3, Letter, PanScan atd.
Re: 0.9.3877
Tá funkcia je tam na to aby si mohol zmeniť rozlíšenie bez pripojenia scart káblom. Na plazmách to nie je problém ale myslím že na Samsungoch LCD to problém je. Takto môžeš zmeniť rozlíšenie spolu s kontrolou toho čo robíš na displeji AZ
marek66
Re: 0.9.3877
Pozeram ze vsetci mate premium, ja mam elite, mne to nerobi
Aky pouzivate font pisma ?
