Enigma2 - test verzia
Rei
JIKARU
Re: Enigma2
- satsk
Re: Enigma2
no netusim ci je to The_Ripper verzia enigmy, ak ano tak za zmienku stoji tiez uviest:
"As I said before,
no audio/video/demux/tuners support. But it's on current stage that can be tested what is working for now.
Image is build with Makefile-opendreambox-1.5 for dm800(didnt try new OE 1.6), but for e2 to works, it will need some patches. I will try to upload main diff/write here what I changed.
Many Python code is disabled in mytest.py , Harddisk.py is used from Sh4 build, etc ...
so guys who wants/know Python can start playing/repairing because it want work with default Python code for Dreambox ... "
"As I said before,
AzBox Premium RSI E2 0.1.1 .:. DreamBox 800SE Ferrari SSL82F OpenBlackHole (from 28.2E to 30W)
- gorick
Re: Enigma2
Tak mam za sebou uspesny test tejto verzie E2 1.0.21.Mala by to byt len taka ukazka toho, co pride koncom mesiaca.Podarilo sa mi ju nahodit az na druhy pokus. Najprv som isiel podla navodu,na flashku som dal patch.bin E2,restart,po boote update(klasicky postup ako offic. firnware),ukazalo,ze reboot.V tej chvili som vytiahol usb a tu nastal problem. Na VFD displayi sa objavil nejaky nadpis geko a nic sa nedialo.Tak som to vyriesil tak, ze som vlozil opat usb s tym patchom.bin E2,restartol,na VFD napisalo Rescue mode,potom som zapojil kabel od routra.Na VFD mi nabehla IP adresa.V PC som spustil program AZUp,tam som vlozil tu IP adresu,stlacil update a nahralo mi to E2 este raz.Potom restartlo aj s USB-ckom a E2 krasne nabehla.Trosku som sa pohral v menu, slapalo to stabilne, svizne,pekne 2 skiny na vyber,osd v slovencine,naladilo mi to v pohode aj astru 23,5 programy,ale ziadny obraz sa neukazal.Podobne media player ukazal media na disku,ale neprehraval ich.Takze ako tu bolo povedane stale este no audio/video/demux/tuners support.Inak, ked to doriesia s tymi ovladacami bude to pecka. Navrat na official patch bez problemov s programom Azup ...
Merxxx
Re: Enigma2
Dear friends,
Here is the working version of em8634dvb.ko file.
I tested with all FTA channels on Astra 19.2 e , You can ask with any other satellite with FTA channels. Enjoy
This driver is for Elite/Premium.
Premium+ driver will be published soon ( stay tuned, next days )
Replace old em8634dvb.ko file located in :
/lib/modules/2.6.22.19-19-the_ripper/extra
with new one which i attached to this post.
Please post Your opinnion and so on.
Known BUG is that on the first channel ( FTA channel ) when receiver is turned on that there is just audio, so just zapp to another FTA channel and there will be no more problem .
This is experimental, but works enough well that You can watch FTA channels
Also i put Don@ channel list , and used simple configuration with one satellite
We wish you happy testing.
AzBox HD Elite, DM 500+ / 28,2-1W / FW: vždy nový
theruck
Re: Enigma2
a nedal by sa pouzit driver z VU+ alebo z dreamboxu? ze by si clovek kupil azbox a ak by chcel enigmu iba by vymenil tuner? teda pokial by niekto skompiloval ten driver pre ten chip v azboxe. ale mohlo by to byt jednoduchsie ako pisat novy driver na neznamy tuner.
- Duce
Re: Enigma2
A to si kde videl? VU+ a DM sú založené na úplne inej chipovej sade ako ako má AZbox, čiže aj drivre sú úplne iné, čiže na azbox ich musí najprv niekto napísať, myslím si že sa to práve teraz deje, len treba vydržať.theruck píše:a nedal by sa pouzit driver z VU+ alebo z dreamboxu? ze by si clovek kupil azbox a ak by chcel enigmu iba by vymenil tuner? teda pokial by niekto skompiloval ten driver pre ten chip v azboxe. ale mohlo by to byt jednoduchsie ako pisat novy driver na neznamy tuner.
AZ BOX HD PREMIUM, HD BOX FS-9300, HD BOX FS-9100,COOLSTREAM ZEE, AB IPBOX 200S, OCTAGON SF 908, SAT Elita 2000 HD, FW takmer vždy čerstvý,rotor-takmer celý orbit
theruck
Re: Enigma2
ved aj tam je tuner pichnuty v rovnakom slote ako v azboxe ne? pci-e ma rovnaku specifikaciu zrejme v oboch boxoch tak preto ma napadlo ze ci by to nebola cesta...
theruck
Re: Enigma2
tak to vyzera ze E2 na azboxe napreduje. mozno sa dockame skor ako fw od opensatu.
na zahranicnom fore niekto postol vytazenie cpu pri prehravani xvid-u.
Load of CPU running playing xvid avi file on AzBox HD E2 MediaPlayer :
1.9 i 1.5 % CPU
2120 *1786 root * * S * * 126m124.6 * 0 *1.9 /usr/bin/enigma2
1789 *1786 root * * S * * 126m124.6 * 0 *1.5 /usr/bin/enigma2
2128 *2126 root * * R * * 2836 *2.7 * 0 *1.1 top
2121 *1786 root * * S * * 126m124.6 * 0 *0.7 /usr/bin/enigma2
2122 *1786 root * * S * * 126m124.6 * 0 *0.5 /usr/bin/enigma2
2123 *1786 root * * S * * 126m124.6 * 0 *0.2 /usr/bin/enigma2
1850 *1786 root * * S * * 126m124.6 * 0 *0.2 /usr/bin/enigma2
2125 *1613 root * * S * * 2840 *2.7 * 0 *0.2 telnetd
1857 * * 2 root * * SW * * * 0 *0.0 * 0 *0.2 [usb-storage]
1791 *1786 root * * S * * 126m124.6 * 0 *0.0 /usr/bin/enigma2
1855 *1786 root * * S N * 126m124.6 * 0 *0.0 /usr/bin/enigma2
1552 * * 1 root * * S * *10036 *9.6 * 0 *0.0 smbd -D
1579 *1552 root * * S * *10036 *9.6 * 0 *0.0 smbd -D
Re: Enigma2
To je dobrá zpráva. Je vidět že Enigma umí využít hardwarové schopnosti Sigmy a procesor se těžce nudí. :)
Pubo
Re: Enigma2
Ahoj, aj ja som sa chcel mrknúť, ako vyzerá tá Enigma, po reštarte dlho Reboot a skončil som s tým geko. Ak bol vložený USB, tak to skončilo na Rescue ale žiadna IP sa neobjavila. Sú to už tri týždne, na fórach som prečítal čo sa dalo ale zatiaľ nič nepomohlo.
Keď si išiel nahrávať Enigmu, dal si sformátovať tú oblasť? Lebo ja nie (bolo mi ľúto o všetko prísť).
S mojim AZboxom HD Premium som sa spojil len cez RS232, dala sa mi i nastaviť IP,ale po reštarte atď. sa nakoniec spustil udhcpc (v1.16.1), ktorý nastavil IP na nuly a skončilo to "sending discover...".
A tak sa s ním nemôžem spojiť po eternete aby som sa dostal ďalej s Azup.
Mohlo by pomôcť nahrať niečo priamo na disk DOM v PC? Keď som nahral štar boxu bez USB, tak posledné dva riadky (keď je geko) sú:
switch_root: canKernel panic - not syncing: Attempted to kill init!
t execute /sbin/init: No such file or directory
Budem vďačný za každú radu.
Babangida
Re: Enigma2
Pokud na svem sitovem prvku nemas zaply DHCP server, tak ti i kdyz das Rescue Mode, tak nedostanes zadnou IP
V okamziku kdy uz IP dostanes, tak pomoci AZUP a v USB budes mis flesku se souborem patch.bin tak ti to opravi :)
theruck
Re: Enigma2
tak to vyzera ze na premium uz enigma 2 funguje celkom slusne. skoda ze mam plusko ktore zatial nefachci
- gorick
Re: Enigma2
Mozem potvrdit. Na Premiume som si nahodil verziu E2 1.0.25 a maka slusne.Jednoznacny posun vpred. Zatial mi idu FTA kanaly/prepinanie kanalov okolo 1s/ a po nainstalovani ipk balickov mediaplayer prehrava formaty audio: mpeg, aac, ac3, dts, wma a video: mpeg2, mpeg4 (xvid). Este ked doriesia kodovane kanaly,nech fachci aj karta a ostavam...theruck píše:tak to vyzera ze na premium uz enigma 2 funguje celkom slusne. skoda ze mam plusko ktore zatial nefachci
theruck
Re: Enigma2
mozes skusit prosim ta ci funguje uz aj nahravanie z EPG?
